| dardappa2004 |
 dardappa2004 Nova Slayer
 Posted: 15:01 - 09 Nov 2008 Post subject: whats wrong with my aprilia 125 |
hi there fellow bikers, i have a bit of a problem . . . . Basically when it rains the bike start and ride for about 4mins then will cut out. It sounds as if i hit the kill switch with the bogging down noise? i have already sprayed ht lead and coil in wd40 just in case and that still hasnt worked. This only happens if its raining or go through a big puddle.could it be dodgy ht lead and coil?
Any ideas would be much appreciated?
i |
| Ant132 |
 Ant132 World Chat Champion
 Posted: 15:14 - 09 Nov 2008 Post subject: |
This happened to me, wrapping the HT lead and front of the cap in electrical tape sorted it  ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
| stirlinggaz |
| dardappa2004 |
| Ant132 |
| stirlinggaz |
 Posted: 19:11 - 09 Nov 2008 Post subject: |
| dardappa2004 wrote: | thanks for quick replies, ill try wrapping it up completly the ht and coil?? and yes i do have an open air filter |
hi,
get the original airbox on!
the rs doesnt like open air filters, with the exception of a vectorcone.( i've tried most of them ,lol) but seemingly pipercross have stopped making the vectorcone, though i dont know why, its a cracking filter & i ran right through the winter with it with no problems.
open type filters are a bugger to set up, mess up the mixture & the foam ones dont like getting wet.
one compromise, if you really have to have an open filter, is to re-fit the airbox with all the internals removed & use it as a cover for the open air filter.
(both snorkels opened up & trumpet/neck cut right down).
if you still have the airbox, i'd start with that & see how you get on in the wet.
(there fairly cheap secondhand)
cheers,
GAZ |
The last post was made 17 years, 101 days ago. Instead of replying here, would creating a new thread be more useful? |
