callipre tool?
blahheed
PostPosted: 13:41 - 18 Nov 2008    Post subject: callipre tool? Reply with quote
where can i get a brake calliper piston tool
its like a long nose pair of pliers with half moon shape at the end which goes into the piston
PostPosted: 13:58 - 18 Nov 2008    Post subject: Reply with quote
Never heard of anything like that, what do you do with it/what's it for?
I've had hydraulic brakes apart loads of times and never had to use any specialist tools. Nothing more than some g-clamps, spanners and an old screwdriver to scrape muck out of the grooves where the seals sit.
Itchy
PostPosted: 14:04 - 18 Nov 2008    Post subject: Reply with quote
https://www.portlandtools.co.uk/Automotive_tools/Motorcycle_tools/Motorcycle_Brake_Piston_Removal_Pliers__VS1806_2093.html
Its sort of like a pair of pliers you put on the inside of the hollow brake pistons, when my CBR brakes seized I asked about them due to the impossibility of getting out opposed pistons using brake pressure to push them out since they are , opposed...
I bought the more expensive £72 version by laser which works fine and changes a 1 hour job to a 10 minute job (on the NTV).
As I thought that with the small surface area of the half moon bit it is likely to slip , while the laser version completely fills the hollow bit in the piston.
PostPosted: 14:10 - 18 Nov 2008    Post subject: Reply with quote
They are on my shopping list. What are your general experiences with them?
Itchy
PostPosted: 14:17 - 18 Nov 2008    Post subject: Reply with quote
I've only used them 4-5 times Sickpup has had one for ages and initially recomended one to me, but quite simply to remove a piston, its caliper off, split caliper,
Find an adaptor that fits, connect it to the puller, tighten the puller and pull , out comes the piston , just like that...
I suppose it depends on what your method was before as my method before to extract pistons was using the lever at the top to pump the brake pistons out to where I could get my thumb in it and yank.
Though this wasn't possible on the CBR since its got opposed pistons... though about 4 people in Bolton have borrowed it and found it useful.
PostPosted: 14:27 - 18 Nov 2008    Post subject: Reply with quote
Sickpup pointed the out to me ages ago. Just not got round to buying them.
Sliding calipers are pretty easy. Opposed piston calipers are a pain. At present I land up splitting the caliper and then using compressed air, which is not that simple (even finding a rubber nosed air gun to go onto the hole is not that easy) to do and can result in a piston flying off at high speed.
Mudskipper
PostPosted: 14:49 - 18 Nov 2008    Post subject: Reply with quote
Cheaper here:
https://www.pvrdirect.co.uk/productinfo.aspx?kw=piston&tier1=Sealey+Tools&tier2=Vehicle+Service&tier3=Brake+Service+Tools&catref=VS1806
PostPosted: 14:53 - 18 Nov 2008    Post subject: Reply with quote
Anyone know what the Sealey are like compared to the Lazer?
I've never actually done them myself (though have helped someone else do them once ages ago), but it's something I'll have to do at some point, I'm sure.
sickpup
Old Timer
PostPosted: 15:50 - 18 Nov 2008    Post subject: Reply with quote
I wouldn't even bother with the pliers just go for the Lazer puller kit.
If you want to borrow my puller set you are more then welcome.
PostPosted: 15:56 - 18 Nov 2008    Post subject: Reply with quote
Cheers for the offer. Although I really should just spend the money and buy one.
the grim reaper
PostPosted: 16:50 - 18 Nov 2008    Post subject: Reply with quote
I use a MTB track pump that does 150PSI and an old valve cut from an inner tube with some rubber left around it. Screw the rubber into the banjo bolt holes and blow the pistons out. Cable tie each one in once cleaned and away you go.
Cost about £30 for a decent track pump, which is also useful for my MTB Mr. Green
Grim
Thom
PostPosted: 19:05 - 18 Nov 2008    Post subject: Reply with quote
I think someone hasn't use the search facility as i just asked this about a week ago Razz
Theres a great pair i just bought and helped remove the stiffest of pistons but cost £20, made by sealey although i cant remember where i bought it.
The last post was made 17 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.17 - MySQL Queries: 16 - Page Size: 80.96 Kb
