| blahheed |
 blahheed Trackday Trickster
| stinkwheel |
 Posted: 13:58 - 18 Nov 2008 Post subject: |
Never heard of anything like that, what do you do with it/what's it for?
I've had hydraulic brakes apart loads of times and never had to use any specialist tools. Nothing more than some g-clamps, spanners and an old screwdriver to scrape muck out of the grooves where the seals sit. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Itchy |
 Itchy Super Spammer
 Posted: 14:04 - 18 Nov 2008 Post subject: |
https://www.portlandtools.co.uk/Automotive_tools/Motorcycle_tools/Motorcycle_Brake_Piston_Removal_Pliers__VS1806_2093.html
Its sort of like a pair of pliers you put on the inside of the hollow brake pistons, when my CBR brakes seized I asked about them due to the impossibility of getting out opposed pistons using brake pressure to push them out since they are , opposed...
I bought the more expensive £72 version by laser which works fine and changes a 1 hour job to a 10 minute job (on the NTV).
As I thought that with the small surface area of the half moon bit it is likely to slip , while the laser version completely fills the hollow bit in the piston. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Kickstart |
 Kickstart The Oracle
| Itchy |
 Itchy Super Spammer
 Posted: 14:17 - 18 Nov 2008 Post subject: |
I've only used them 4-5 times Sickpup has had one for ages and initially recomended one to me, but quite simply to remove a piston, its caliper off, split caliper,
Find an adaptor that fits, connect it to the puller, tighten the puller and pull , out comes the piston , just like that...
I suppose it depends on what your method was before as my method before to extract pistons was using the lever at the top to pump the brake pistons out to where I could get my thumb in it and yank.
Though this wasn't possible on the CBR since its got opposed pistons... though about 4 people in Bolton have borrowed it and found it useful. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Kickstart |
 Posted: 14:27 - 18 Nov 2008 Post subject: |
Sickpup pointed the out to me ages ago. Just not got round to buying them.
Sliding calipers are pretty easy. Opposed piston calipers are a pain. At present I land up splitting the caliper and then using compressed air, which is not that simple (even finding a rubber nosed air gun to go onto the hole is not that easy) to do and can result in a piston flying off at high speed.
| Mudskipper |
 Mudskipper World Chat Champion
| G |
 G The Voice of Reason
| sickpup |
 sickpup Old Timer
| Kickstart |
| the grim reaper |
 the grim reaper World Chat Champion
 Posted: 16:50 - 18 Nov 2008 Post subject: |
I use a MTB track pump that does 150PSI and an old valve cut from an inner tube with some rubber left around it. Screw the rubber into the banjo bolt holes and blow the pistons out. Cable tie each one in once cleaned and away you go.
Cost about £30 for a decent track pump, which is also useful for my MTB
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
| Thom |
 Thom World Chat Champion
 Posted: 19:05 - 18 Nov 2008 Post subject: |
I think someone hasn't use the search facility as i just asked this about a week ago
Theres a great pair i just bought and helped remove the stiffest of pistons but cost £20, made by sealey although i cant remember where i bought it. ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
Previous Bikes: 1990 Honda NSR125 'Rothmans' (The smoking one), 1990 Suzuki GS500e 'Caf? fighter' (The loud one), 1987 Kawasaki GPX400r (The quick one), 1997 XJ600s Diversion (The reliable one), 2000 Kawasaki ER-5 (The spontaneously combustive one) |
The last post was made 17 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
