| fatsamurai |
 fatsamurai Nitrous Nuisance
 Posted: 14:29 - 23 Nov 2008 Post subject: I am a fool.. |
I defied any common sense this morning and tried to get to work on my bike.
I got as far as Willerby Road (about 300 yards from my house) and promptly fell off. A quick inspection showed no real damage to the bike, other than a snapped indicator, easily fixed with a bit of araldite.
So I wheeled it home and went in for a cuppa whilst deciding how to get to work. I went into the garage after to give the bike a good look over. Big scrape to the engine casing, rounded off the bar ends and took a bit off the end of my brake leaver, exhaust looked okay but one of the rubber rings on the things that holds it has been worn away while it was sliding. All in all, not as bad as it could have been.
Hang on.. what's that dark puddle? SH*T. It's oil. A closer inspection showed that I have a fracture in the engine casing, here:
https://farm4.static.flickr.com/3239/3052700890_47594bdd8e_o.jpg
There doesn't seem to be any material missing, just a crack, but it's bleeding oil when the engine is running.
I need the bike for work, so i'll have to try and get it into a garage tomorrow. Any idea of what it will cost, or what's involved? I'm hoping that it will be a simple weld job.
What a twit.  ____________________ Hyosung GT125 [SOLD] -> Suzuki GSX 750W [SOLD] -> SV650S [Crashed] -> FZ6  |
| Itchy |
 Itchy Super Spammer
 Posted: 15:13 - 23 Nov 2008 Post subject: |
Me thinks the simplest way to fix it is not to weld it , but probably to replace the clutch cover , a new one for a CBR600F costs about £35 , with £5 for a gasket, cheaper on ebay...
Either drain the oil then replace it, or tip the bike on its side , and quickly replace it,
Unless its actually not on the clutch cover and is on the engine case itself that is then weld £50-60... ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| NiteMare |
 NiteMare Spanner Monkey
| Ariel Badger |
 Ariel Badger Super Spammer
 Posted: 17:58 - 23 Nov 2008 Post subject: |
As said photo needed. Clutch cover no problem, crankcase . ____________________ Bikers make great organ donors, get 115 on your licence today. |
| Ichy |
 Ichy World Chat Champion
 Posted: 18:26 - 23 Nov 2008 Post subject: |
FWIW its most likely the timing cover, there is more chance of it hitting the ground than the clutch cover. They are very durable but mine would leak at any chance it go, are there any marks on the outer surface?. I found the best way to sort it was to make my own gaskets from gasket paper. Maybe the paper is thicker but it seems to work better than the OEM ones. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| fatsamurai |
 Posted: 19:40 - 23 Nov 2008 Post subject: |
According to my manual, it's the pulse generator coil cover. I've check it and there is a crack running about 1 inch from the bottom, running down to the underside. It has not done any damage to anything on the other side of the gasket, thank god.
I'm going to clean it up tommorow and whack a load of araldite over the crack. Then i'll order a new cover. No point getting it welded as the cover is scratched to bits anyway.
That sound like an okay plan? ____________________ Hyosung GT125 [SOLD] -> Suzuki GSX 750W [SOLD] -> SV650S [Crashed] -> FZ6  |
| Ichy |
| NiteMare |
| nasty |
 nasty Traffic Copper
| fatsamurai |
 Posted: 10:37 - 24 Nov 2008 Post subject: |
Yeah, it was snowing and icy, plus it was early in the morning so the roads hadn't had chance to clear.
I'm going to give it a go with the araldite in a bit, it that doesn't work I will try some sort of chemical metal.
Cheers for the help, much appreciated. ____________________ Hyosung GT125 [SOLD] -> Suzuki GSX 750W [SOLD] -> SV650S [Crashed] -> FZ6  |
| fatsamurai |
| NiteMare |
| SoND |
 SoND World Chat Champion
 Posted: 20:34 - 24 Nov 2008 Post subject: |
Welding would have been a permanent fix, not the prettiest unless the time was spent to clean it all down but it's still doable. By the looks of it you like a tidy bike so maybe it's not for you then.  ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
The last post was made 17 years, 313 days ago. Instead of replying here, would creating a new thread be more useful? |
