Ford Ka
Cigaro
PostPosted: 13:47 - 25 Nov 2008    Post subject: Ford Ka Reply with quote
Well, the person who was meant to be selling me the Polo has sold it to someone else (no idea why, as I said I was picking it up Wednesday Rolling Eyes )
Looking at a 1.3 Ford Ka tonight. 1997, blue, 1.3, looks pretty tidy.
Anyone had any experience of these? Anything to watch out for?
MattHirst
PostPosted: 14:08 - 25 Nov 2008    Post subject: Reply with quote
https://www.ct.gov/dph/lib/dph/phho/barber_hairdessers/haircut.jpg
Lol only kidding, i know a few people that have had them as first cars (i know this isn't your first but still) and they were great little run arounds. My dad had one aswell, not sure what model but don't expect anyone above hobbit size to fit in the back Very Happy
PostPosted: 14:11 - 25 Nov 2008    Post subject: Reply with quote
Watch out for rot. They do rot a fair bit, and are prone to it starting just behind the doors (look at them and you will regularly see rust coming through as the paint and rust protection has been damaged).
jayvfr
PostPosted: 14:54 - 25 Nov 2008    Post subject: Reply with quote
As kieth says, rot and the obligatory ford tappet rattle. Don't be too put off if it sounds fairly "tappety" as it's a pretty old engine design and as such will sound a tad rattly most of the time. Gotta keep on top of it if you can but they do tend to be a little noisy.
Just make sure you do check what comes out of the exhaust when its cold (as always), I've known of a few that have skipped a service and started with the blue smoke pretty sharpish.
A quater of a NC30 and a whole tatty ZX6R J2, that's plenty...
VFR bits for sale, PM me for details!
PSN ID: money85
Whosthedaddy
PostPosted: 15:08 - 25 Nov 2008    Post subject: Reply with quote
1999 1.3 KA3 (black) (50,000 miles) with AC, full leather seats and CD player.
The wife has had since 6 months old and is really starting to look its age.
If you look all KA's seem to have dents in the rear panels were the rear arches flare out. Whether this is due to the owner knocking it when going through narrow places or the obligatory car park dings and dents. The wifes car is full of them, only one of which is due to both me and her driving it.
The CD player has broke and can't be fixed.
The AC unit has a broken or corroded pipe and is not economical to repair.
Tyres wear quite a bit and each corner has had a change more than once.
Exhaust back box seems to rot / break / snap from the link pipe and has had 3 so far
Gearbox was a little iffy and got stuck in 2nd and was damn expensive to get fixed!
The rear boot lid switch is intermittent depending on whether it has been opened recently by the manual means.
The passenger door has slipped a little meaning that the coach lines are a little off round the door.
Rot, as mentioned above, the bottom of the doors are the first to go.
The lacquer on the tyres has started to peel off.
The driving position is quite high and results in quite a lot of rolling into corners like on the bike.
Its cheap to insure
Is relatively nippy
Good mpg
Been abused for the time that its been owned by dog and 2 children and kept on going.
Just ignore the FZR
https://www.bikechatforums.com/files/fzr600_026_190.jpg
plugger147
PostPosted: 15:15 - 25 Nov 2008    Post subject: Reply with quote
Skipping service's isn't the problem, the blue smoke is usually from people not keeping a regular check on the oil and they have been know to use quite a bit.
Other than rot the only common repairs that I've come across are waterleaks from the plastic slam panel below the windscreen and the wire's on the plug going into the alternator snapping, both are something you can do yourself although the wires can be a pain to solder back on.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
PostPosted: 15:18 - 25 Nov 2008    Post subject: Reply with quote
Get one like this. Wink
https://www.okas.co.uk/stuff/ka.jpg
UnknownStuntm...
PostPosted: 15:34 - 25 Nov 2008    Post subject: Reply with quote
Most common problems on a Ka that I've heard of are the spark plugs rusting onto the heads, so check they're fairly recent plugs in there (and if you buy it, change them every year using plenty of copper grease) and the air bypass valve system can make the revs go a bit haywire - noticeable when you change gear, sounds like the engine is racing. That's a quick and easy fix most of the time, just a couple of new seals to fix an air leak.
Davo
Davo To The Rescue!
PostPosted: 15:48 - 25 Nov 2008    Post subject: Reply with quote
Had two KA's, only ever had a few issues with them.
As kickstart mentioned rotting around the door sills is fairly common.
Spark plugs need removing every so often as they rust in to the head very quickly (remove and re copper slip every 5000 miles).
There was a recall issued for this back some time ago, Ford replaced the throttle position sensor to cure this.
The biggest issue I had was the seals on the power steering system failing, needs a new steering rack to fix (£700 odd), so check the power steering fluid level (can be heard when moving from lock to lock).
Apart from that a good fun car to drive (even did a track day on it and took it to nurburgring), cheap to run & insure (group 2).
butterob
PostPosted: 16:23 - 25 Nov 2008    Post subject: Reply with quote
are you on about the idle air control valve? mines been idling shit as of late and i took this of gave it a clean etc put it back in and no joy... where are the seals??
btw that KA will be a bit out dated the 1.3 is the endura i believe which is a basic over head valve push rod. Its good reliably but don't expect anything amazing from it! Good car to keep you going though
j1 zx6r in green
g2 zx6r trackbike Trackdays done: Mallory park, Brands Hatch Indy, Snetterton 300
Whosthedaddy
PostPosted: 16:25 - 25 Nov 2008    Post subject: Reply with quote
A bit of WD40 cured the revving problem, it just appeared that the throttle cable was a little sticky when returning? It stopped it anyways.
butterob
PostPosted: 16:26 - 25 Nov 2008    Post subject: Reply with quote
forgot to mention i have a fiesta mk4 1999 not a KA!
j1 zx6r in green
Mudskipper
PostPosted: 16:46 - 25 Nov 2008    Post subject: Reply with quote
Steering rack went on mine (apparently common, though I do have a tendancy to corner cars beyond their handling capabilities Shifty) cost £250 to fix I think.
Apart from that it was fine, till the engine blew up of course. Again, I think that was probably my fault.
They are fun to drive, but painfully slow on motorways obviously.
UnknownStuntm...
PostPosted: 18:00 - 25 Nov 2008    Post subject: Reply with quote
Well as you look at the engine, it's the bit that sticks out over the top of the cam cover. Like a small can of redbull but without the redbull logo. Or the redbull inside. Anyway, there's a plastic plenum where it connects onto the inlet manifold at the back of the engine, just undo the 4 bolts and look for the little figure 8 seals. At first it looks like two O rings next to each other, about 3/4 inch diameter. There are two of these kiddies, one either end of the plenum. Sounds WAY more complex than it is - it's a 15 minute job including the cup of tea.
Phil_G
PostPosted: 01:16 - 26 Nov 2008    Post subject: Reply with quote
echo the others
rust
Inside the doors
Sill (mid way along) spreading upwards
windscreen "A" pillar tips (just under hte front wings)
Fuel filler neck (think Mk3 fiesta)
IF the rear windscreen wiper doesn't work properly/at all then try knocking the boot hinge pins with a drift and hammer as they earth the tailgate through these, which can lead to poor earthing, hence the erratic performance. If that sorts it then it is possible to run a proper earthing strap through the high level light conduit. There is apparently at least one point you can fix it to either end already moulded into the panel work.
ICV as well as throttle position sensor can go
suspension bushes fail prematurely
Bonus: Superb fun to drive on a lane. Just wind it up and let rip. They will out handle most cars I have driven pound for pound. I had no problems with space inside (im 6'2") and whilst not a rocketship on the bypass/motorway, it was more than capable of keeping up with traffic and exceeding the NSL. Cheap as hell to buy now and plenty about, so be fussy and buy the best you can.
We loved it, but found the dissolving bodywork somewhat distasteful. Ours was a UK sourced vehicle, washed regularly and bought from the dealership brand new. It was badly rusted (near enough holed!) within 4 years on the drivers sill, a pillar and passenger side door with the Drivers side door right through. When we tried to claim under warranty, it was rejected and a poor mechanic was blamed. We decided to take a hit and chopped it in for a Citroen which has had none of the Ka's issues, and has a vastly superior Anti corrosion warranty to Ford as standard.
1997 Kawasaki ER 500 A1:- Once again, Its merely crap Smile
Ben.
PostPosted: 02:07 - 26 Nov 2008    Post subject: Reply with quote
apperentley they are a death trap if you crash them
follow my racing season
Race bike - R6
Road bike - sv650
JonB
Afraid of Mileage
PostPosted: 08:32 - 26 Nov 2008    Post subject: Reply with quote
They have a 3 star NCAP rating which isn't overly bad. Better than the MK3 OR 4 fiestas which are only 2 star.
https://www.euroncap.com/tests/ford_ka_2000/77.aspx
UnknownStuntm...
PostPosted: 09:26 - 26 Nov 2008    Post subject: Reply with quote
Newsflash - this just in. You might die if you're in a car crash.
Also at 10, motorbikes are unsafe, the world is proved NOT to be flat after all, and there's a new way to spell the word APPARENTLY.
Rolling Eyes
Cigaro
PostPosted: 14:16 - 26 Nov 2008    Post subject: Reply with quote
Went for a Polo in the end.
Tidy little 1.4CL in black, 1999 T-reg, alloys, leccy windows and mirrors, 3 door... £950.
Most I've ever spent on a car, but it seems worth it.
UnknownStuntm...
PostPosted: 17:27 - 26 Nov 2008    Post subject: Reply with quote
WAAAAAAAAAAAAAAAAAAY better car you got there chap. Welcome to Club Dub (tm) Thumbs Up
AJI
PostPosted: 22:44 - 26 Nov 2008    Post subject: Reply with quote
Half_lyfe, don't be a half_wit. Any mid-nineties small car isn't going to fare too well if you stack it, but they're no more dangerous than any other small car of that age, and indeed were safer than the Fiesta/Polo/Corsa of the time in crash tests.
When my Fiesta (same engine as the Ka) had those exact same symptoms (revs flaring when gearchanging) it was the throttle position sensor.
Meh, they aren't too bad. Hold 80mph pretty easily without being too noisy and still have a bit of power in reserve. Good torque too for a small engine.
TARMAC - Automotive blog *UPDATED 26/3/09 - Abandoned fuel stations to go electric? ~ Buy my eBay stuff!
You're gonna go far, kid
The last post was made 17 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.82 - MySQL Queries: 16 - Page Size: 130.14 Kb
