inlet cleaning
blahheed
PostPosted: 00:26 - 26 Nov 2008    Post subject: inlet cleaning Reply with quote
have looked down the inlet port and looks a bit furry.
can this be disolved with petrol or some sort of cleaner?
PostPosted: 00:45 - 26 Nov 2008    Post subject: Reply with quote
Best to leave it alone - a rough surface in the inlet tract is preferable over a smooth one anyway.
Dalemac
PostPosted: 01:05 - 26 Nov 2008    Post subject: Reply with quote
plus you dont want any of the crap going into you engine.
Dale
YBR125 -> GPZ500S -> SL1000
chillpill
PostPosted: 01:14 - 26 Nov 2008    Post subject: Reply with quote
how comes ? wouldnt it just create turbulence for the air/fuel mix , you obviously know a lot more than me im just curious Wink
The Artist
PostPosted: 02:28 - 26 Nov 2008    Post subject: Reply with quote
turbulence = good. mixes better.
its why butterfly throttles work I think. They are designed to not be perfect otherwise fuel and air would not be mixed enough.
back up please.. Thumbs Up
sickpup
Old Timer
PostPosted: 12:19 - 26 Nov 2008    Post subject: Reply with quote
Stops droplets of fuel failing out of the air flow.
rotax81
PostPosted: 13:43 - 26 Nov 2008    Post subject: Reply with quote
its true. a rough port is better than a polished one.
ermmmm.... the best way i can describe it::
if you take a look at a river flowing, the middle of the river runs cleanly through and the edges are hardly moving. the edges have obstacles etc so vortexes create a nice smooth path for the middle.
a pickup creates more drag with the tailgate down (just another useless bit of info) lol
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
PostPosted: 14:41 - 26 Nov 2008    Post subject: Reply with quote
I don't know the mechanics of it but basically as Rotax said the molecules of air touching the surface it's flowing over (called the boundary-layer) are almost stationary. The smoother the surface, the better they stick to it, and the layer gets thicker as you move further down the surface. The rough surface of the port helps prevent this by stirring the molecules up.
sickpup
Old Timer
PostPosted: 14:57 - 26 Nov 2008    Post subject: Reply with quote
Just remembered. The rough edges that cause turbulence stop the fuel droplets falling out of suspension.
Coxyzxr
PostPosted: 15:00 - 26 Nov 2008    Post subject: Reply with quote
I got a very brittle, dry leaf stuck down one of my inlets once litrally fell out of the tree and into the inlet tract when I had the carbs off in the back garden. Tried getting it out with long nose and tweezers but it just fell apart into tiny pieces. I just bolted her back together and went for a spin.
That was the last I heard of old leafy... Crying or Very sad
Back on topic rough surface can also aid swirl. Don't listen to the old skool mustang crowd or gran turismo's tuning tips, port 'polishing' isn't a good idea for perfoamnce or fuel ecom.
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
chillpill
PostPosted: 12:37 - 27 Nov 2008    Post subject: Reply with quote
cool , a good bit of info right there Thumbs Up
Mr Hammers
PostPosted: 13:50 - 27 Nov 2008    Post subject: Reply with quote
Laughing Poor old leafy...
My long held belief (pre-BCF, obviously..) was always that polishing helps. Years ago i ported and polished my Ford X-Flow so much it looked liked it had been chromed and the inlet manifold block looked like they were cast as one piece, and while i can understand the turbulence theory, and it would seem to make sense, isn't the air/fuel being able to get from point A to point B quicker if it's route is unimpeded by a rough surface, even if the quality of mixture might suffer to some degree..?
A Guide To Powerbands
Coxyzxr
PostPosted: 14:44 - 27 Nov 2008    Post subject: Reply with quote
I see where you're coming from, the speed of the airflow isn't that important as far as I know since the intake tract is designed well enough to get as much airflow as it needs when it needs it. Not only that but once it's running you're getting an almost constant throughput of expelling of spent gases and intaking of fresh gases.
It's all about volumetric efficiency squeezing as much power out of each mixture combustion as possible and that means getting as much of the correct mixture of fuel/air as possible on each intake stroke therefore if we're losing fuel droplets to the inlet tract they arn't getting into the cylinder to maximise combustion.
Furthermore the dimpled interior of the intlet tract and the design and angle of it is normally designed to improve swirl which is where this gases flow into the cylinder in a certain way which improves cylinder filling an an equal manner so when the spark fires the gases ignite evenly and you get no 'dead pockets' or 'hot pockets' of gases pre-igniting or not igniting at all.
Mr Hammers
PostPosted: 13:03 - 28 Nov 2008    Post subject: Reply with quote
I'd have thought that the speed of the airflow was pretty important, after all, whatever the given explosive potential of the mix, it being mixed well or not, if the engine can process more of it the power it could produce.....nicht war..?
Assuming for the sake of argument that that is true, i suppose it then becomes a balance (or compromise...depending on how you look at it) between enough turbulence generated by a rough intake to mix it all up and not lose droplets of fuel....and, a fast throughout of mixture made possible by a smooth intake.
Here's a hastily drawn graph to demonstrate;
https://www.planetash.net/bcf/mix-graph.jpg
As the smoothness increases, the ability to force more of the mix goes up, but the actual efficiency (or explosive potential) goes down.
As the roughness increases, the ability to force more of the mix goes down, but the efficiency goes up.
And then, where the two meet is the best combination of rough/smooth and less/more mix processed.
Does any of this make any sense.... or am i talking out of my graphs...?
Edit: Dang. Can't help feeling that that graph is just..wrong. Tried doing another (oo i love graphs, me...) but i'm not sure this one accurately reflects the point either, tbh.
https://www.planetash.net/bcf/mix-graph-2.jpg
PostPosted: 21:41 - 28 Nov 2008    Post subject: Reply with quote
The whole point is that the rough surface allows a faster overall airflow, not the smooth one. Intake velocity IS important because with velocity comes momentum so more air-fuel mix gets into the cylinder past the closing inlet valve.
Mr Hammers
PostPosted: 12:58 - 03 Dec 2008    Post subject: Reply with quote
Right, right, i see what you're saying.
Since you posted i've read up as much as my spare time will allow, and i'm still confused, if not more so as i was before. While some places agree that 'smoother=stickier', others appear to say 'rough=turbulence=drag'.
I do accept on the face of it the premise that a rough surface means a faster overall flow, but it's so counter-intuitive that i'm struggling to really convince myself that this is true.
However i look at it, i can't help coming back to the 'but...but it *must* be faster if it's smooth!' mindset. That said, if i were a gambling man, i'd put my money where *your* mouth is, despite my inability to fully accept the fact that rough = fast.
Another thought then, assuming that there must be a point where too rough means it is definitely slower, how rough can a surface be before it starts to have a negative effect...?
stevo as b4
PostPosted: 23:54 - 03 Dec 2008    Post subject: Reply with quote
I'd suggest that port size and shape will have a far bigger effect on airflow for a given valve lift in (mm), than the effects between a highly polished port and a rough finished one.
Remember that as you port a cylinder head, you are slightly enlarging the ports by removing excess metal and removing rough edges and casting marks etc. The finish made by a rotary sanding drum will still be plenty rough enough to give turbulence, even when it looks fairly shiney IMO. Unless your polishing the port with a mop and polishing compound, then i don't think you need to worry about the ports being too smooth and allowing the fuel to drop out of the mixture etc.
fra-zzr
PostPosted: 00:42 - 04 Dec 2008    Post subject: Reply with quote
its the same principle you find in golf balls, although from a different perspective as its the air/fuel moving and the ball (inlet staying still) . The bumps cause drag initiailly but less chance of separation of fuel/air because of increased adhesion from the inlet face, so less wake
turbulent flow > laminar flow (polished face would give this)
Finally marine biology found a use Laughing
04' Hyosung Comet Gt125
96' zzr600
The last post was made 17 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.68 - MySQL Queries: 16 - Page Size: 111.98 Kb
