Indicator help for NSR125
GhostRider
PostPosted: 19:11 - 18 Dec 2008    Post subject: Indicator help for NSR125 Reply with quote
Evenin'
So after I buggered my front left hand side indicator up after coming off the other week, I ordered a replacement. It doesnt look the same as the original, which was a small silver round shaped casing, this one is a big black thing that I've seen on most other pictures of NSR's for sale on ebay. So I connected it up and tested to see if it blinked.
It didnt, it lights up but then the rear left hand indicator does the same, and theres a weird whirring noise coming from the back end of the bike under the seat release mechanism, and thats how it stays.
The right hand side works fine. I had wondered if I need to replace both left and right front indicators with the same type of indicator, but when I disconnected the right hand side one, I got the same results from both indicators on the left side still.
Can anyone give me any insight as to what might be going on here?
Thanks,
GhostRider
robbo68
PostPosted: 19:48 - 18 Dec 2008    Post subject: Reply with quote
Hi, Did you fit the after market indicators to your nsr, do you now if they are led's or normal bulbs. They use different flasher units which are situated under the rear seat where the noise is comming from. if you have an led unit it will not work properly with std bulbs. All nsrs were fitted with the big black plastic ones which you have got like you see on most bikes sor sale.
Also just check the wireing to make sure you don't have a short?
alains
PostPosted: 20:04 - 18 Dec 2008    Post subject: Reply with quote
this a wrong model and the bulb inside is the wrong one . buy the right model (the bulb is included) or buy a bulb model Ba15s 12V 10W . put a pict of your new indicator , i will tell you . eventually ,i will be in the UK from dec 24th until dec 29th and i've got a pair , so i can sent you what you need if you tell me which side plus nama & adress (price £5 each+postage)
metal ken
PostPosted: 20:06 - 18 Dec 2008    Post subject: Reply with quote
sound like you have different aftermarket indicators fitted
The left and right side indicators are not connected,
if you can post a pic of the indicator on this thread i might have one that would fir your bike. look if it has a bulb, or LED's
Good luck, Ken Thumbs Up
My motorbike breakers metalken.co.uk
Current bikes, GSXR750 Fighter, GSXR7/12, RD350 race rep, KH400
GhostRider
PostPosted: 20:16 - 18 Dec 2008    Post subject: Reply with quote
Hi guys,
This is the one I ordered
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=160184781656
As far as I can tell its a bulbed indicator, same as the previousone. I will try and get a picture of the original indicator on here later.
GhostRider
alains
PostPosted: 20:28 - 18 Dec 2008    Post subject: Reply with quote
it looks the right model , take off the cover and look what power is marked on the bulb , it must be 12V 10W
GhostRider
PostPosted: 20:43 - 18 Dec 2008    Post subject: Reply with quote
Alains you're a top bloke, I checked the bulb, was 21W, but luckily I had a bag of spare bulbs lying around and found a 10W, stick that in and tested it, works like a charm now. Thankyou very much.
GhostRider
alains
PostPosted: 20:46 - 18 Dec 2008    Post subject: Reply with quote
no problem my dear Cool
The last post was made 17 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.94 - MySQL Queries: 16 - Page Size: 59.82 Kb
