Clutch slip?
nasty
PostPosted: 11:17 - 02 Jan 2009    Post subject: Clutch slip? Reply with quote
Noticed a couple of times that my clutch has slipped over the last couple of weeks, the oil looks like it could do with a change, would this sort it?
Oh and I recently topped up the oil as it looked a bit low, but I may have put a little too much in, could this be the casue of the problem Embarassed
ZX6R F3 BTW.
ZX6R F3
PostPosted: 11:31 - 02 Jan 2009    Post subject: Reply with quote
Possible but unlikely an oil change will fix it (but no harm trying). And slightly too much oil should not have an effect on the clutch slipping.
Likely to be new plates time, but normally bike clutch plates are fairly easy to do (not sure about the ZX6R, never done the clutch on one).
PostPosted: 12:04 - 02 Jan 2009    Post subject: Reply with quote
Could just be that the cable needs adjusting to check that the cable's adjusted correctly, but other than that it looks like new plates time.
On some bikes you don't even need to drop the oil to change the clutch.
nasty
PostPosted: 13:41 - 02 Jan 2009    Post subject: Reply with quote
New clutch plates?? Bugger! Shocked
The bikes done just under 13,000 miles, so if the plates need changing what does that tell me? Is this normal wear or is it a sign the bike has been thrashed/neglected?
Thanks
Nick
ZX6R F3
PostPosted: 13:45 - 02 Jan 2009    Post subject: Reply with quote
Plates are generally pretty easy. Half the time easier than changing brake pads.
That is a pretty low for the life of plates in road use, but pretty easy to kill them from slipping the clutch (ie, fast getaways).
nasty
PostPosted: 14:04 - 02 Jan 2009    Post subject: Reply with quote
Ok, thanks Keith and Big_Ham Thumbs Up
So if I need to change the clutch plates, is there any specific type that would be better to go for? Would it be worth/neccessary changing the springs too?
What else would I need - Clutch cover gasket etc?
ZX6R F3
PostPosted: 14:07 - 02 Jan 2009    Post subject: Reply with quote
Think it was a bit over 9000 miles for my ZX-J model - but definitely had plenty of quick clutch-slipping starts.
They redesigned the engine for G/J/A etc models, however it was very easy to do - could do it in under half an hour when you know what you're doing, probably!
PostPosted: 14:09 - 02 Jan 2009    Post subject: Reply with quote
On a stock (or close to stock) bike I would avoid using HD springs unless you really need to (heavy clutch is a pain). There should be some specs for the free lengths of the stock springs in the manual, but personally I would doubt that they are worn out in such a low mileage.
Clutch cover gasket should be replaced. Tend to be cheap, but quite often people get away without changing them.
Many people advise sticking with OE clutch plates. That is up to you, but I have used others without problems.
nasty
PostPosted: 14:10 - 02 Jan 2009    Post subject: Reply with quote
I'll have to get my specs on and follow the Haynes manual for this I think, never done this before - should be interesting Laughing
ZX6R F3
The last post was made 16 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.52 - MySQL Queries: 16 - Page Size: 64.22 Kb
