Aprilia 125
qwertyjjj
PostPosted: 05:47 - 22 Jan 2009    Post subject: Aprilia 125 Reply with quote
Always wanted one of these but recently someone who had one said the electrics were rubbish.
The Honda just doesn't look as good IMO.
Any ideas?
PostPosted: 09:58 - 22 Jan 2009    Post subject: Reply with quote
Never heard of the electrics being crap. The more pressing concern would be a cash strapped 17 year old properly maintaining one of the most highly tuned road bikes ever made. Thumbs Up
frez
PostPosted: 10:00 - 22 Jan 2009    Post subject: Reply with quote
The Aprilia RS125 is very good. Like all two strokes it needs a regular top end rebuild (every 10k miles or so). It needs quality 2 stroke oil and warming up before thrashing it to ensure the engine doesnt fail sooner. The gear box oil should be replaced frequently to stop the gearbox getting too notchy.
The electrics are as good or bad as any other bike, I have not heard of any particular problems in this regard with the RS125.
The only common fault I have heard of is that the speedo drive frequently fails.
Check out the Aprilia forums for more information.
Graprilia
PostPosted: 11:10 - 22 Jan 2009    Post subject: Reply with quote
i had my RS for a year and a half , only had one problem with it the speedo drive , other than that is was problem free.
Just use quality 2 stroke oil not the cheap rubbish and make sure you allow the bike enough time to warm up.
Piaggo liberty 125 SOLD - CBR 125 - SOLD Aprilia RS 125 - SOLD CBR 400 NC29 - SOLD ZX6R currently own https://bikepics.com/members/Graprilia/
PostPosted: 11:25 - 22 Jan 2009    Post subject: Reply with quote
Plenty of 2 strokes will last far longer than that between rebuilds. It is not unusual for people to manage 30k on the original piston / rings on some 2 strokes (eg the NSR125).
Electrically they seem fine (although the lcd seems temperamental). On older ones the flywheel tends to crack and lose its magnets (and they are not cheap).
frez
PostPosted: 12:20 - 22 Jan 2009    Post subject: Reply with quote
My understanding is that the NSR125 has a bridge on the exhaust port, and that design feature means less ring wear compared to the RS125. So on that basis I doubt a RS125 would make 30k on its original assembly, of course there is always an exception to disprove the rule...
Aprilia recommend a top end rebuild at 10k, and that means it will probably last to over 15k without a problem if well treated.
PostPosted: 12:22 - 22 Jan 2009    Post subject: Reply with quote
That was my point. RS125s need regular rebuilds to keep them healthy (pistons and rings are service items), but this is not true of all 2 strokes.
frez
PostPosted: 12:44 - 22 Jan 2009    Post subject: Reply with quote
I don't mean to push too many buttons here Smile, but...
The biggest problem with many 2-stroke 125s are that they are owned by spotty 17 year olds gifted to them by their parents. They dont have a concept of the bike's value or as much interest in keeping it well maintained because they didn't work for the money and buy it themselves.
With a 4-stroke 125 like a CG, you can get away with jumping on it and whacking the throttle open cold, not checking the oil or adjusting the tapets, it will just get noisier and carry on working. OK, eventually the oil will get so low and dirty that serious damage starts to occur, but that will take a good long while.
With a 2-stroke 125, you let the 2-stroke oil run out and very quickly serious engine damage will result.
This is why 2-strokes get a bad name for reliability, not that they are unreliable, but that they break when not maintained.
PostPosted: 13:41 - 22 Jan 2009    Post subject: Reply with quote
Generally I agree. The CG is fairly tough, but then it is also slow compared to the equivalent 2 strokes. But run one out of oil and it will be dead just as much as a 2 stoke, and 4 strokes tend to cost rather more to repair (although Rotax engine parts are expensive and the barrels on the 122 and 123 engines are plated, which push up repair costs of the RS125).
But there are 2 strokes with about the same performance as the CG125 (for example the Honda H100). Cheaper to make, pretty much as reliable, easier to work on, less maintenance required and also good on petrol (and under the old insurance rules used in the 1980s, half the cost to insure of a CG125).
qwertyjjj
PostPosted: 14:01 - 22 Jan 2009    Post subject: Reply with quote
How much would a full rebuild cost?
What about the Hobda CBR125?
PostPosted: 14:31 - 22 Jan 2009    Post subject: Reply with quote
Depends what is damaged, but running low on oil on a normal 4 stroke (with plane bearings in the crank) would stand a good chance of wrecking the crank, cam/s and head casting, along with a fair chance of damage the the piston and bore, and possible damage to the gears.
Some 4 strokes used roller bearing cranks (like 2 strokes) and these are far more resistant to damage from low oil pressure.
Wrecking the heads from low oil / low oil pressure (from letting the filter block up) was particularly common on small Honda 4 strokes in the 1970s and early 1980s. The cams bearings were part of the head (there was no seperate replaceable bearing) hence when oil pressure was too low the cam just wore away at the head. Conventionally this meant a new head (there were people who would bore out the heads a bit and fit bearings).
Bike_craze1
PostPosted: 23:44 - 22 Jan 2009    Post subject: Reply with quote
Agreed, CG's are bulletproof.
Yamaha R125 - Cagiva Mito 125 - Honda CBR 600
CBT passed: 22/07/08 Bike Theory passed: 28/03/09
Bike Test passed: 15/04/09
qwertyjjj
PostPosted: 12:15 - 23 Jan 2009    Post subject: Reply with quote
But they don't look anywhere near as pretty Smile
So, even after taking good care of the bike, it needs rebuilds, and there's always the chance of seizures if you don't look after them properly. Why so many problems with bikes compared to cars?
frez
PostPosted: 13:11 - 23 Jan 2009    Post subject: Reply with quote
You dont get 2-stroke car engines in general production, and 2-stroke engines like on the RS125 need more regular maintenance than a 4-stroke engine.
A car can physically fit more in the engine bay than you can fit in a bike frame. This means bigger sumps with less need to change and top up oil, better cooling, and designs that are not compromised by size. So better mechanical reliability and less regular maintenance is generally the end result.
Bikes will give many years and miles of good reliable service if they are regularly maintained.
It depends how many miles you do on your bike, but I recommend checking the two stroke oil every time you fill up with petrol as it then gets to be a habit.
I also recommend doing a 10 minute check over the bike once a week; oil/adjust the chain, check the brake pads for wear, check the tyre pressures, check if the rear brake lever needs adjusting, top up fluids etc.
PostPosted: 13:18 - 23 Jan 2009    Post subject: Reply with quote
Added to which bike engines are in a lot higher state of tune. If the RS125 was in the same state of tune as a sporty small car (say the Alfa Mito 1.4 @ 155hp) then it would have the power of a CBR125.
Gashead Harry
PostPosted: 22:44 - 23 Jan 2009    Post subject: Reply with quote
They aint!
98' Honda CG125W --- 03' Yamaha DT50SM (Gone!) --- 05' (55) Suzuki GS500 K5
rocket_richie
PostPosted: 03:22 - 28 Jan 2009    Post subject: Reply with quote
The aprilia 125 is a cracking little bike fantastic ride and drops quicker than hookers knickers Laughing i had 1 for 2 years i got her when she had 9k on the clock. had a full engin rebuild 10k. i really miss hooning around with my mate on our mito/nsr/rs we had more fun on them
rs50 x2 rs125 zx6r f3 gs500e gsxr 400 zx6r f3
MaybeGuy
PostPosted: 04:04 - 28 Jan 2009    Post subject: Reply with quote
pfffFFAAAHAHHAHAHAHAHAHA
anyway...
you can get 2 stroke cars.
Tristan.
PostPosted: 04:13 - 28 Jan 2009    Post subject: Reply with quote
~ 30 brake for 125cc, so 240 brake per litre, seems a fairly high state of tune.
frez
PostPosted: 13:32 - 28 Jan 2009    Post subject: Reply with quote
mattsprattuk wrote:
anyway...
Not in general production, i.e. not commonly available for purchase from a major manufacturer.
MaybeGuy
PostPosted: 13:45 - 28 Jan 2009    Post subject: Reply with quote
frez wrote:
mattsprattuk wrote:
anyway...
they were in th 70s
frez
PostPosted: 14:06 - 28 Jan 2009    Post subject: Reply with quote
mattsprattuk wrote:
they were in th 70s
The East German Trabant was in production right up until 1991, but the last 'western' 2-stroke was the Auto Union 1000 I think, and that ended production in 1965.
But for the question posed in this thread about why cars are more reliable than bikes, I think 2-stroke cars can safely be ignored as a factor.
Tristan.
PostPosted: 21:36 - 28 Jan 2009    Post subject: Reply with quote
They still make a couple of 2 stroke small diesels. But as frez said they aren't tuned for power, so haven't got much bearing on this.
The last post was made 17 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.46 - MySQL Queries: 16 - Page Size: 128.78 Kb
