mx 125 jetting
Jack-Mx125
PostPosted: 19:15 - 22 Jan 2009    Post subject: mx 125 jetting Reply with quote
hi im new to this site
ive just bought a gianelli pipe for my mx 125 needs a bigger jet does anyone no anywhere i can buy them from?any help would be great thanks
sumpgard
PostPosted: 23:35 - 24 Jan 2009    Post subject: Reply with quote
why does it need a bigger jet have you checked the colour of your plug if its white raise the needle to give it more fuel this will richen the mixture you will only need a bigger jet when you run out of ajustment.
stevo as b4
PostPosted: 23:47 - 24 Jan 2009    Post subject: Reply with quote
I guess from any bike dealer or parts shop that sells Dellorto carbs and spares!
If you have an aftermarket pipe, then the pipe's manufacturer should be able to advise on the approximate jetting changes required, and in which direction if they are needed. If they can't then they will either tell you that it will not need any re-jetting work being one possibility, or else they have not tested the pipe properly on an actual bike, in which case you should send it straight back asking for a full refund.
asdf
PostPosted: 03:03 - 26 Jan 2009    Post subject: Reply with quote
Jets are available from here
https://www.pjme.co.uk/acatalog/Aprilia_RS125_Air_Filter__Fuel__Carburre.html
If you have the 28mm carb (standard) the main jet will be 120 (standard) so if i was you i would do a plug chop to make sure its not running fine before you buy jets. If it is a bit lean buy a few jets say 124,126,130 as all setups will need different jets.
KTM EXC 125 Supermoto, Honda Cub90
Past - Aprilia SR 50 Ditech, Derbi Senda SM DRD, Aprilia RS125 x 2, Aprilia RX 125
Jack-Mx125
PostPosted: 19:38 - 29 Jan 2009    Post subject: Reply with quote
nope tryied a 125 an a 130 hasnt made any differance :s im confused. thanks for your help anyway.
Charlie
PostPosted: 20:56 - 29 Jan 2009    Post subject: Reply with quote
Have you done a plug chop?
The general rule of thumb is, if you change the exhaust for a non standard, change the jet by 10%
But do the plug chop first.
Jack-Mx125
PostPosted: 21:25 - 01 Feb 2009    Post subject: Reply with quote
yeh i have no change thouogh :/
and ive also upjetted it from a 122 to a 130
The last post was made 17 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.42 - MySQL Queries: 16 - Page Size: 53.48 Kb
