derbi senda 70cc
benjy bwoii
PostPosted: 20:22 - 30 Jan 2009    Post subject: derbi senda 70cc Reply with quote
hello people you might be getting bored of my posts but i have a derbi senda with a leo vince v6 pipe n a malossi 21mm carb and airfilter and im looking to buy a metrakit 70cc big bore kit and my bike wont rev past 10 thousand revs but with a 70cc kit will it and what sort of jetting shall i run witht he standared airbox with the 70cc and what jetting for the airfilter and 70cc thanks people
Hutchysrs50
PostPosted: 20:46 - 30 Jan 2009    Post subject: Reply with quote
if you have a sports exhaust and 21mm carb, it should rev off the clock...
anyway...
with a 70cc/80cc head you would have to use a 110/120jet
i dont think the jetting should change because you changed the airfilter, just change the carb setup.
they do rev more with big bore kits, but you will have to buy a 14t/15t sprocket to avoide over revving.
Gilera SC 125 - Current
benjy bwoii
PostPosted: 21:09 - 30 Jan 2009    Post subject: Reply with quote
cheerz m8 could my ecu have a restricter on it not and with a 15t front sprocket what top speed could i see im hitting a genuine 60 mph now got clocked by my m8s car
Hutchysrs50
PostPosted: 21:20 - 30 Jan 2009    Post subject: Reply with quote
well..
then the bikes are kitted out well with pritty much everything a 16/ 17 year old would buy, they can reach 78mph...
you will probly be looking around 65 - 70mph.
the big bore kits dont actully make your bike faster... they just give it more torque so you can put bigger sprockets and then... get the better speeds and acceleration
Razz (Derbi Senda 50)
PostPosted: 20:15 - 01 Feb 2009    Post subject: Re: derbi senda 70cc Reply with quote
yea it will rev slightly higher but if you want it to rev to say 18.000 then you need to get a new crank (https://www.opvoeren.nl/shop/uk/onderdelen_res.asp?Merk=Derbi&Type=Senda <1999&Afk=desen&Srt=kruk&Srtn=Krukas&Srtuk=Crankshaft ) will rev to 18.000 but i would sugest not reving that high untill you have ran 500 miles through it and changed the oil and made sure you have some descent coolant in her.
Mark.
benjy bwoii
PostPosted: 17:41 - 07 Feb 2009    Post subject: Reply with quote
cheerz people does any one know why my bike wont rev past 10 and it struggles from 8-10 thousand revs.thanks.
PostPosted: 00:10 - 08 Feb 2009    Post subject: Reply with quote
well it all depends on how your running it and the setup.
try new sparkplug and give the carb a clean also you could increase the size of the jets !
good luck
benjy bwoii
PostPosted: 00:34 - 09 Feb 2009    Post subject: Reply with quote
well i have a leo vince v6 pipe on it and a mallosi 21mm carb with airfilter but when it gets to 10 it will just sit there wont rev no more could it be due to the pipes power band set up.thanks.
PostPosted: 08:42 - 09 Feb 2009    Post subject: Reply with quote
there could be a restricter in the end can.
benjy bwoii
PostPosted: 00:04 - 10 Feb 2009    Post subject: Reply with quote
i have taken the end can of and looked down it there is nothing i can see.thanks also would a metrakit sp 70cc be a good upgrade and what bhp could i reach with reliablility.thanks.
B10Hazard
PostPosted: 00:39 - 10 Feb 2009    Post subject: Reply with quote
most 50 cc bikes i know of dont rev past 10 maybe 11 thousands revs anyway, rs 50's, gpr, etc. Thay all have the same engine anyway. So without boring out your engine i dont think you will get more revs.
My bike doesnt have clock's but i could tell after boring out my engine the revs increased slightly.
good luck
No longer any socks
PostPosted: 18:11 - 11 Feb 2009    Post subject: Reply with quote
hello
i was wondering if anyone could tell me how to get the fork seals off thanx
There is a gap of 3 years, 65 days between these two posts...
radeshki
PostPosted: 18:16 - 16 Apr 2012    Post subject: senda Reply with quote
ermm.. what do you guys think of getting a powerforce 70cc cylinder and head for a derbi senda 2004 would it fit ...?
URGENT!!!!
radek
hadden
PostPosted: 20:01 - 16 Apr 2012    Post subject: Reply with quote
why is it urgent?
it will fit but if you start trying to upgrade a 50cc then you will find after spending hundreds on a few parts,you need more parts to make the original parts work.it can turn into a big chain of money..is it worth it for a 50cc??
red bull gives you wing sting!!!
current:aprilia rs 125
previous:honda c90,honda cm 125,yamaha xt 550,2004 suzuki drz 400.(all used for off road back in the day)and a piagio zip 50cc..oooossssshhhh
Nope.
PostPosted: 09:18 - 17 Apr 2012    Post subject: Re: senda Reply with quote
URGENT!!!!
First things first, congratulations on resurrecting an old thread AND making a new one. That's REALLY the way to make friend around here Rolling Eyes .
Secondly, Don't even bother trying to get "MOAR POWERZ BRUV" out of a 50. At the end of the day, its a fag 50. Ride it as your supposed to, slowly. Wait until your 17, if its before January then do your test and buy a proper bike. If its after January then tough tittys, get a 125. It'll naturally be faster then almost any 50 without any unreliable, badly-done tuning.
The last post was made 14 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.66 - MySQL Queries: 16 - Page Size: 87.07 Kb
