Tzr 50 oil/fuel mixture
Faraz
PostPosted: 00:26 - 02 Feb 2009    Post subject: Tzr 50 oil/fuel mixture Reply with quote
I need to up-jet the carb on my tzr because it has had a 70cc big bore kit fitted.
Anyone know how to alter the 2 stroke oil mixture?
Im told its a screw on the oil pump which I need to unscrew to allow more oil through.
Neutral
Just need more specific details.
Thanks. Thumbs Up Karma
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
PostPosted: 13:19 - 02 Feb 2009    Post subject: Reply with quote
Get a picture of the oil pump. If it's like the one on my RX-S I will be able to help.
If it's like mine it should be on the right hand side of the engine under a cover.
Faraz
PostPosted: 17:36 - 02 Feb 2009    Post subject: Reply with quote
Thanks guys.
Ill post pics when I do it.
'56 Yamaha MT-01
Blue_SV650S
PostPosted: 17:55 - 02 Feb 2009    Post subject: Re: Tzr 50 oil/fuel mixture Reply with quote
Neutral
Why do you need to re-jet?
i.e. why does a 70cc kit mean you need to run richer? Confused
Its common to up jet with a new zorst, but I've not heard of it with a big-bore ..
Remember by upjetting you are increasing the fuel to air ratio, not allowing the bike to pump more fuel (at the 'correct' ratio) .. for that you will need larger throttle openings or a larger carb ...
Faraz
PostPosted: 18:38 - 02 Feb 2009    Post subject: Reply with quote
I was told when you fit a 70 kit you need to upjet the stock carb or fit a bigger carb.
'56 Yamaha MT-01
Blue_SV650S
PostPosted: 21:05 - 02 Feb 2009    Post subject: Reply with quote
Assuming the stock carb would be a 'choke point' (pardon the pun) as say it is quite restrictive/small, I can see putting a bigger carb on would be a good idea (you now have the ability to pump more CC's per rev, you need to be able to let more CCs of air in, a bigger carb will allow greater flow of air (and consequent proportional fuel)) if you want to reap the full benefits of the extra CCs ... but I reiterate, I don't really see how changing the fuel/air ratio on the original carb is going to help/be required ...
Anyway - although I am not sure of the wisdom of up-jettiing - I digress slightly ... I can indeed see there might be a bit of a requirement for a smidge more oil though (as you now have more piston/barrel area) ... so in answer to the original question .. as someone else said, take a photo of the pump and we can then tell you how to adjust for extra flow!! Thumbs Up
Faraz
PostPosted: 23:21 - 05 Feb 2009    Post subject: Reply with quote
I fitted the 110 jet and incresed the oil mixture.
Bike now runs perfect.
'56 Yamaha MT-01
Blue_SV650S
PostPosted: 23:40 - 05 Feb 2009    Post subject: Reply with quote
Still don't understand the logic of upjetting, but glad it all worked out for ya Thumbs Up
The last post was made 17 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.93 - MySQL Queries: 16 - Page Size: 65.41 Kb
