what's the best way to capture brake fluid?
steppen22
PostPosted: 15:21 - 21 Feb 2009    Post subject: what's the best way to capture brake fluid? Reply with quote
Will it be okay to use an old squash bottle, or will this not be up for the job? A coke can or two?
I don't really want to pay for anything.
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
SoND
PostPosted: 15:22 - 21 Feb 2009    Post subject: Reply with quote
Should be fine.
tutton
PostPosted: 16:23 - 21 Feb 2009    Post subject: Reply with quote
A jug?
PostPosted: 16:28 - 21 Feb 2009    Post subject: Reply with quote
tutton wrote:
A jug?
Ideally though you'd want to put a top/cap on it to stop it being exposed to moisture in the air.
I've got a coke bottle for mine.
tutton
PostPosted: 16:30 - 21 Feb 2009    Post subject: Reply with quote
Ahh right i see, i dont reuse mine, but when flushing i use a jug when dropping out as its got a bigger top to shoot into than a small bottle neck Laughing
Phoenix
Twisted Firestarter
PostPosted: 22:02 - 21 Feb 2009    Post subject: Reply with quote
Well you shouldn't really reuse brake fluid, if there's a reason to drain it then put new stuff in, Dot4 is only a £2-3 for 500ml. Waste stuff you can put in anything except the cat, it kills them.
steppen22
PostPosted: 22:04 - 21 Feb 2009    Post subject: Reply with quote
how to dispose of?
just in a hedge?
Louise
PostPosted: 22:07 - 21 Feb 2009    Post subject: Reply with quote
Sparks uses his garage floor carpet, my wheels and a cloth Laughing Thumbs Up
Sparks!
Sir Tart-a-lot
PostPosted: 22:09 - 21 Feb 2009    Post subject: Reply with quote
I did use a plastic container.. until i pushed your bike over it and broke it... ah well, that's what carpets are for anyways.
PostPosted: 22:14 - 21 Feb 2009    Post subject: Reply with quote
I'm going to re-use mine as it's brand new fluid.
Phoenix
Twisted Firestarter
PostPosted: 23:16 - 21 Feb 2009    Post subject: Reply with quote
steppen22 wrote:
how to dispose of?
just in a hedge?
I'm not entirely sure to be honest, they say don't throw it down drains or in hedges but to dispose of it properly yet I don't quite know who takes used brake fluid or coolant other than paying a garage to take it. Civic Amenity sites only have facilities for used engine oil. I personally put it in sealed bottles and bin it, if you throw it on your garden you will notice that anything growing there will soon be dead.
Phil_G
PostPosted: 00:48 - 22 Feb 2009    Post subject: Reply with quote
likewise anti freeze
1997 Kawasaki ER 500 A1:- Once again, Its merely crap Smile
Robby
Dirty Old Man
PostPosted: 01:49 - 22 Feb 2009    Post subject: Reply with quote
Two things.
1. Why re-use? The only reason I can think of for possibly re using brake fluid would be if you're very tight, and changing your brake lines or something. Re-using it is still a bad plan, just see this as a good time to really clean out your system.
2. I stick mine in with my waste engine oil, which gradually accumulates in 25L drums. It will burn with a little encouragement.
Itchy
PostPosted: 01:52 - 22 Feb 2009    Post subject: Reply with quote
Capture it ? why? it tends to leak out anyway when I clean my brakes pop the pistons and it goes all over the cardboard sheet I've laid down , and I toss the sheet later on, heh don't get it onto concrete flags though as it stains it like grease for months.
cyberglass
PostPosted: 02:11 - 22 Feb 2009    Post subject: Reply with quote
Most council tips have waste oil containers take it down there.
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
Phoenix
Twisted Firestarter
PostPosted: 06:55 - 23 Feb 2009    Post subject: Reply with quote
Yes they do, brake fluid funnily enough is not oil though.
PostPosted: 11:21 - 23 Feb 2009    Post subject: Reply with quote
I use half a 2 litre coke bottle to catch my old fluid. Then I pour it into the drain with lots of water. Its an outside storm drain so I doubt it goes anywhere of consequence. Probably just to my kitchen tap...
Kal
PostPosted: 16:09 - 23 Feb 2009    Post subject: Reply with quote
It's not worth it, will be exposed to moisture in the air while you are pumping the brake out. Play safe and ditch, you wouldn't reuse a condom would you?
Kal...
Cigaro
PostPosted: 16:13 - 23 Feb 2009    Post subject: Reply with quote
If you put it in a coke bottle then aren't you actually better off chucking the bottle out with the rubbish?
owdamer
PostPosted: 16:14 - 23 Feb 2009    Post subject: Reply with quote
Well theres always the neighbours gardens then. Very Happy
mistergixer
PostPosted: 20:18 - 24 Feb 2009    Post subject: Reply with quote
Place a bar of chocolate on the garage floor and hide in the corner.
When a bottle of brake fluid comes along and takes the bait, leap out and get it in a headlock, subdue it with a few sharp taps from a reasonably heavy hammer.
Coat. Door. Gone.
Embarassed
Space Monkey #7
PostPosted: 21:03 - 24 Feb 2009    Post subject: Reply with quote
It's exposed to air as it goes into the brake reservoir, so in my eyes, it doesn't really matter.
The View Askew
PostPosted: 22:09 - 24 Feb 2009    Post subject: Reply with quote
At the recycle depot (tip) near me there is a used engine fluids unit where you can pour in such wastes.
There is a gap of 216 days between these two posts...
theopj
PostPosted: 22:05 - 29 Sep 2009    Post subject: Reply with quote
I just use an old coffee jar, I have the bleed hose going through a hole in the lid so it doesn't go everywhere if I knock it over. Worked really well when I did them a few weeks ago.
The local tip just told me to chuck it in general waste - along with small amounts of old petrol and diesel that I had in jars.
Suzuki Bandit SA 1250 & Honda CB750F2T
PostPosted: 22:17 - 29 Sep 2009    Post subject: Reply with quote
Its a 2 litre coke bottle that has been cut in half.
The last post was made 17 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 3.82 - MySQL Queries: 16 - Page Size: 134.73 Kb
