pitted piston
Cigaro
PostPosted: 19:31 - 23 Feb 2009    Post subject: pitted piston Reply with quote
Sorry for yet another brake question, but here is a picture of my piston:
https://img513.imageshack.us/my.php?image=piston.jpg
Firstly, it's supposed to be completely flat (apparently) yet it is pitted to buggery and looks like a big chunk has been knocked out of the top of it on one side (you can't see that so well in the photo).
Why has it gone like that, and can I sand it down or should it be replaced?
Cigaro
PostPosted: 19:39 - 23 Feb 2009    Post subject: Reply with quote
Also (forgot to mention), is there supposed to be a dust cover over the top of the piston? The RAC bloke said that was missing.
PostPosted: 20:12 - 23 Feb 2009    Post subject: Reply with quote
get yerself a piston kit it'll come with o-seal, piston and
otherwise known as a boot.
Pat
PostPosted: 21:35 - 23 Feb 2009    Post subject: Reply with quote
Suspect that piston has some kind of stuffer in it. Seen Kawasaki ones before with what looks almost fibrous, and had decayed a bit. Presume it is there to try and insulate the brake piston from the head of the brake pad.
Very few Japanese bikes have a rubber boot around the piston to protect it. Although there will be some rubber bellows around the pins the caliper slides on.
Cigaro
PostPosted: 21:38 - 23 Feb 2009    Post subject: Reply with quote
Cheers Kickstart.
Planning to pop the piston out, give it a bit of a clean up and see if it's scratched at all around the edge, if not then I'll just change the seals.
You're right in that it does have bellows around the sliding pins.
Just that the RAC bloke seemed sure it should have a dust cover (oh alright then, 'boot' Razz) on it.
alun111
PostPosted: 22:12 - 23 Feb 2009    Post subject: Reply with quote
If the face of the piston or the inside is pitted it doesn't matter... as long as the outside diameter is ok. As kickstart mentioned some kwaks have a some sort of bung in the piston... it looks like a wine bottle cork/cylindrical piece of wood.
The last post was made 17 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.27 - MySQL Queries: 16 - Page Size: 50.12 Kb
