snapped bolt!
monkeyboy111
PostPosted: 14:00 - 26 Feb 2009    Post subject: snapped bolt! Reply with quote
i was going down the road and all of a sudden it stopped the head bolt snapped?
dunno what to do!!
Please Help?
virus
PostPosted: 14:03 - 26 Feb 2009    Post subject: Reply with quote
Remove the rocker arm that the thread is stuck in, take it to an engineering shop and get them to remove it, then get a new bolt in there.
John
own: 81 xs1100g...
Knacker
PostPosted: 14:04 - 26 Feb 2009    Post subject: Reply with quote
Was probably Torqued down to much or Faulty bolt
Best way to remove it is to take the head off which will leav enough to get hold of to remove Thumbs Up
Previous: K1 GSXR 1000
inchi55
PostPosted: 16:56 - 26 Feb 2009    Post subject: Reply with quote
Did the same thing myself. Managed to get it out with a hammer and a screw just hitting the edge of the bolt on a ridge and turning it a bit at a time. eventually got enough showing to get grips on and screw it out. If its in real tight you will be fucked i think.
past bikes-gt185, gsx250, gsx600f, gsx750f and now rf900/
yea suzuki man all the way.
Darth
PostPosted: 20:27 - 26 Feb 2009    Post subject: Reply with quote
Buy a new camera for a start! Mr. Green
Have used these with great success before on sheared exhaust manifold studs-
Blue point Screw extractor set
Sold my set a while back, think i paid about £60 for them which aint cheap but they were the shizzle!
ZaphodBeeble
PostPosted: 20:36 - 26 Feb 2009    Post subject: Reply with quote
Get a 4mm reverse drill bit and drill the centre of the bolt that's stuck. It might just spin it out. If it doesn't then stick a screw extractor in the hole you drilled.
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
PostPosted: 20:41 - 26 Feb 2009    Post subject: Reply with quote
Superdream?
In any case first get a new rocker-cover bolt. Then try to pick the broken bit out carefully. If you can't get it out, remove the rocker carrier from the head and drill the bugger out. I can't recall if that is threaded right through, but if it is just use a 3.5 or 4mm bit and drill from below, it should wind the bolt out no problem. Don't run the bike with the broken bit in there coz if it winds down onto the can it might ruin it. Looks like an easy repair I reckon I could get that out no problem.
The last post was made 17 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 52.04 Kb
