CG125 kickstart fouling on exhaust
cazmal
PostPosted: 23:36 - 07 Mar 2009    Post subject: CG125 kickstart fouling on exhaust Reply with quote
I have a 1991 CG 125 with kickstart only. I need to fit a new exhaust, but want to sort out this problem first.
The kickstart is fouling on the exhaust and putting a dent in it. The join of the downpipe and the silencer is corroded so I wish to replace the exhaust.
Are there different exhausts available for electric/kickstart machines?
Anyone else had this problem and what did you do?
Thanks
PostPosted: 23:40 - 07 Mar 2009    Post subject: Reply with quote
Hi, i've not had your particular problem, but you can always try loosening the pinch bolt and re-aligning the kick start on the spline.
Pat
virus
PostPosted: 10:47 - 08 Mar 2009    Post subject: Reply with quote
Make sure the exhaust is mounted properly, if its twisted at the engine then it wont line up on the rest of the bike, also check your kickstart is attached firmly and not slid down the splines etc etc.
If the exhaust and the kickstart are in the right place, mark the exhaust where the kickstart hits it, then put a block of wood on it and hit it with a hammer to dent it in a bit, this will give you clearance.
John
own: 81 xs1100g...
webbaldo
PostPosted: 21:09 - 08 Mar 2009    Post subject: Reply with quote
the two exhaust mounting bolts on the cg, just under the passenger foot peg rust and snap easily, long before the chrome exhaust does. check them first
The last post was made 17 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.47 - MySQL Queries: 16 - Page Size: 41.87 Kb
