How do I safely strip cbr125 to clean carb?
Gaz-t1esto
PostPosted: 15:55 - 25 Mar 2009    Post subject: How do I safely strip cbr125 to clean carb? Reply with quote
Having a few fueling problems and through trial and error I have come to conclusion that the carb is where the fault lies.
Problem is that when i open throttle, the bike isnt getting the right air/fuel mixture and its just dieing. it dies when I ride it too if i dont open throttle past so many revs. as a temp repair to get me home from work i increased the idle revs (little knob under carb that i turned a few times to satisfy my curiosity to see what it did). this did help however was only a temp job and now the bike isnt starting or when it does start it sometimes idles too high. tried turning the revs back down but the knob under the carb doesnt seem to be affecting the revs now.
To cut a long story short, i know it needs a good clean or replaced and wonder how is the best and safest way to remove the tank without fuel going everywhere and/or is there a tap on the bottom of the tank so i dont need to transfer fuel into a storage can. also, what tools will i require to clean the carb. obviously wouldnt be wise to use wire brush but is there certain spirits/spray cleaners i should or shouldnt use.
Thanks
Gaz
[edit - typos]
PostPosted: 16:16 - 25 Mar 2009    Post subject: Reply with quote
First off:
Carburettor cleaner from Halfords is your friend.
Secondly, following Robby's advice from a previous thread I would strongly reccomend NOT dismantling or fiddling with the carburettor before you have definately ruled out ignition or electrical problems. Carburettors have a habit of never quite being the same if you remove and/or dismantle them. Plus As Robby quite rightly says Carbs simply do not go wrong unless they are very very old or have really really contaminated petrol put through them. Particularly on such a new bike as a CBR125, you should not be seeing fuelling issues. Do a compression check, test the spark from the spark plugs and try to reset the carbs to factory defaults.
If you still have issues, by all means dismantle the carb but be aware you're opening a huge can o' worms by doing that.
Karma
Gaz-t1esto
PostPosted: 16:33 - 25 Mar 2009    Post subject: Reply with quote
MarJay wrote:
First off:
Karma
Have you ever rode your motorcycle at 80mph and all of a sudden ur body weight has been thrown forward because the engine is starving of fuel, revs droppping, throttle unresponsive....it feels like you have dropped 3 gears and let the clutch out. Its sh*t scary and my immediate reaction was to pull the clutch in and open the throttle more to stop it dying.....that didnt work, i was freeriding on the outside lane of a dual carriage way with cars infront, to the side and behind me and slowly losing speed and nothing i could do about it until i pull over (bump starting has been rather unsuccessful due to the starvation of fuel.... It has to be carb or fuel related as its happening whilst riding and not just at starting the bike up after a cold night or so.
i appreciate your input and its very much logical to what i had originally wrote however there is more to this issue that what i had typed that narrowly rules out part of your suggestion.
[edit - more typo's lol]
Finglonga
PostPosted: 16:41 - 25 Mar 2009    Post subject: Reply with quote
Sounds like its pinching up. If you turn a 125's ignition off you would not be thrown forward like that, after all its only a 125.
Simple fact is carbs don't get dirty nowadays, I have been riding over 25 years and never needed to clean a carb out.
Andy Sez....
F.Y.Y.F.F.
No, you're talking daft now. It could be heat related, it could be that a circuit in the CDI or electronic ignition is breaking down because of heat. It could also be something as simple as a kink in a fuel hose, or a blocked breather or something of that nature. So your bike dies whilst riding, that doesn't automatically mean you should dismantle the carb.
If a carburettor is working then it is working, its not likely to suddenly stop working whilst riding. What you're doing is jumping to a conclusion and then making the evidence fit your model. You are not scientifically diagnosing the problem.
It is still possible that it is the carburettor, but I'd try to do some more narrowing down of possibilities before you leap to random conclusions and potentially make things worse (like you may have done by adjusting the idle screw or something).
In addition, don't discard the advice from this forum because it doesn't fit your idea of what is wrong. At least give it a chance before you tell us to shut up etc...
{edit - have you checked the oil lately? edit}
PostPosted: 16:42 - 25 Mar 2009    Post subject: Reply with quote
Could be a few things instead of the carb.
However if you have been fiddling with a screw in the underside of the carb then that is likely the idle mixture screw. It has a small effect on idle speed but mainly adjusting it is likely to have really screwed up the mixture. It will have next to no effect on the mixture when you are riding at any speed.
Personal guess would be that the problem is a blocked fuel filter, blocked fuel tank breather or a kinked fuel line. Any of these will starve the carb of fuel.
Gaz-t1esto
PostPosted: 16:43 - 25 Mar 2009    Post subject: Reply with quote
Im not switching off ignition when this occurs. If i switch off ignition whilst in motion the bike continues to roll even if i have selected a gear and let clutch our. Can you please define what you mean by pinching up?
PostPosted: 16:47 - 25 Mar 2009    Post subject: Reply with quote
He means that if if was a carb problem it would slow just about as much as if you turned the ignition switch off.
If it is stopping violently then that suggests it is just nipping up (ie, lightly seizing). Which is FAR more serious than a carb issue (and pretty rare on a 4 stroke).
Gaz-t1esto
PostPosted: 16:51 - 25 Mar 2009    Post subject: Re: How do I safely strip cbr125 to clean carb? Reply with quote
I have checked the fuel line, no kink, checked the breathers and all clear (spoke with local garage who said run some thin oil through breather pipe and if it trickles out at bottom, breather is clear.....It trickled out....
This happened on my motorcycle prior to the engine being replaced. (piston destroyed a spark plug......well, destroyed doesnt cut it) unsure if this is related to the fuel issues but lets just say the garage couldnt bore it out as damage was quite severe. the only part of the engine not replaced when i bought the new engine was the carb.
Evidently, Its inevitable i am going to jump to conclusions as lightening doesnt strike twice in the same place.....I cant have two engines that completely go wrong. there must be a connection.
PostPosted: 16:53 - 25 Mar 2009    Post subject: Reply with quote
He means it sounds like its starved of oil and partially seizing up. He's saying that even if you cut fuel and spark to the engine at 70mph it shouldn't violently throw you forward. The only thing that would do that is a partial seizure of engine or gearbox, or potentially if your chain got caught on something or something along those lines.
Gaz-t1esto
PostPosted: 16:53 - 25 Mar 2009    Post subject: Re: How do I safely strip cbr125 to clean carb? Reply with quote
oil levels are fine. with preheat, its just below max, without preheating engine its roughly about the middle of the dipstick.
PostPosted: 16:54 - 25 Mar 2009    Post subject: Re: How do I safely strip cbr125 to clean carb? Reply with quote
Unless you are causing the problem without realising.
Gaz-t1esto
PostPosted: 16:54 - 25 Mar 2009    Post subject: Reply with quote
Thanks for clarifying that. Had me :S by the terminology.
Gaz-t1esto
PostPosted: 16:55 - 25 Mar 2009    Post subject: Re: How do I safely strip cbr125 to clean carb? Reply with quote
Whats that supposed to mean?
Neglecting my motorcycle, Poor riding skills?
PostPosted: 16:57 - 25 Mar 2009    Post subject: Re: How do I safely strip cbr125 to clean carb? Reply with quote
There is a connection if it is a chinese CBR125 copy rather than a Honda CBR125, and there is a connection if you aren't running enough oil.
Gaz-t1esto
PostPosted: 16:58 - 25 Mar 2009    Post subject: Re: How do I safely strip cbr125 to clean carb? Reply with quote
Its a Honda. Bought from a honda dealer, with honda decals all over it, including the service book. Its no chinese or jap inport.
stirlinggaz
PostPosted: 18:11 - 25 Mar 2009    Post subject: Reply with quote
hi,
if your certain your gonna strip the carb :
remove seats,
remove tank bolt (12 or 14mm socket iirc)
lft tank up & pull off the 2 hoses-but label them 1st!
ones vacuum & ones fuel.
pull the tank off, watching for those massive breathers that go down through the plastic bit next to carb.
fuel wont spill out as you need vacuum for the fuel to flow.
remove choke assembly (spanner 12 mm i think) from carb.
loosen throttle cable on the side of carb.
loosen the jubilee clip & pull the carb off, remembering where the hoses go.
theres not much can go wrong with they carbs, unless, as has been mentioned before, someone has been messing with the brass
mixture screw or the idle screw.(the one facing downwards,knurled edge)
cheers,
GAZ
The last post was made 16 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.64 - MySQL Queries: 16 - Page Size: 112.4 Kb
