How exactly do CDI units work? Does anyone know?
rob_scott92
PostPosted: 16:33 - 15 Apr 2009    Post subject: How exactly do CDI units work? Does anyone know? Reply with quote
hi everyone
my 1982 suzuki gs 125z is not running, i suspect its the CDI unit. does anyone know and understand how these work? i understand that there is a pulse sent to it and that the CDI manages it somehow to send a voltage to the ignition coil and that creates big good spark Razz , but thats pretty much the extent of my knowledge, and i'm not even sure if thats completely right Embarassed .
any help would be great! Very Happy
thanks
Rob
Dilusi
PostPosted: 16:40 - 15 Apr 2009    Post subject: Reply with quote
https://lmgtfy.com/?q=how+does+a+cdi+unit+work
PostPosted: 16:42 - 15 Apr 2009    Post subject: Reply with quote
Electronics wise I don't know.
However the basic idea is that the cdi unit gets a pulse to tell it when the engine reaches a certain point. From a series of these it knows the rpm. Knowing the rpm it can calculate when it wants to fire a spark, which might be X degrees after the pulse. The coil gets a constant feed of current, and to trigger the coil to discharge that constant feed is briefly interupted by the cdi unit.
rob_scott92
PostPosted: 16:45 - 15 Apr 2009    Post subject: Reply with quote
orite thanks kickstart, i realise now it may have been easier to check google but thought that theres many experts on this site, might have been worth checking here first!
thanks Very Happy Thumbs Up
finpos
PostPosted: 17:17 - 15 Apr 2009    Post subject: Reply with quote
In it's simplest form it's a big capacitor (i.e. tiny battery) with a transistor (i.e. switch) connecting that capacitor to the ignition coil.
The capacitor is charged by a dedicated coil in the generator. The ignition switch/kill switch earths this coil, so when the ignition is off the capacitor cannot charge.
There is a second sensor coil (or a hall effect (magnetic) sensor) next to the flywheel at a few degrees before TDC. This sensor is connected in turn to the transistor. When the sensor coil is triggered, the transistor opens up discharging the capacitor through the ignition coil, creating a pulse. Being a coil, it does what coils do when pulsed, that is creates a big spark on it's output. Multi-cylinder engines have additional sensors placed around the flywheel.
In order to advance the ignition as the revs go up, there is a bit of additional electronics in there that delays the signal from the sensor to the transistor depending on how fast the signals are coming in. This actually works upside down, slow pulses are delayed, fast pulses happen straight away.
As such, if you can use a meter, you should be able to measure all the input and outputs to the CDI to get an idea if it is working. Of course, it's much easier to swap one in that you know works!
f.
reckless_b
PostPosted: 16:18 - 16 Apr 2009    Post subject: Reply with quote
Hi Rob, go to
www.dansmc.com/MC_repaircourse.htm
its a fullish workshop training guide, it has a section on electonic ignition which should help, loads more aswell. Thumbs Up
40 years on the road on and sometimes off bikes with a very recent OFF
The last post was made 16 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 16 - Page Size: 51.5 Kb
