rs 125 derestriction 2007??
neil281088
PostPosted: 16:23 - 20 Apr 2009    Post subject: rs 125 derestriction 2007?? Reply with quote
i have a 2007 rs 125 and a powervalve, blade, housing and rave controller from an older generation bike the connector on my old rave unit does not fit the loom of my new bike any suggestions or will i have to buy one to match my bike year? also does drilling the new generation cdi in the same place work to get rid of the dip? and will all the other old bike stuff ie solenoid cable blade be compatible? going in the garage end of this week and i cant seem to get any of these questions answered from any1 please help!!!! cheers neil
stirlinggaz
PostPosted: 22:11 - 20 Apr 2009    Post subject: Reply with quote
Hi,
all the older solenoid etc should fit.
as for actually plugging it im, havnt you got a spare connector somewhere?
heres the derestiction guide, might be something in there,
cheers,
GAZ
cheekythomas
PostPosted: 21:50 - 21 Apr 2009    Post subject: Reply with quote
You probably have the newer Euro3 model with the new style carb with TPS sensor etc... if so youll need a few parts to make it all work.
Carb needle, jets, decat exhaust etc...
cheekythomas
PostPosted: 21:52 - 21 Apr 2009    Post subject: Reply with quote
Here read this...
https://www.serviceaprilia.com/public/com_tech_/comuAprilia/Branch/gb/001-2007.pdf
stirlinggaz
PostPosted: 22:39 - 21 Apr 2009    Post subject: Reply with quote
erm...
thats exactly what i posted.
however it doesnt tell him where to plug in the solenoid control cable.
on pre2006 models it plugged into the main loom via a block connector on the right hand side, under tank & back towards carb.
sounds like hes saying theres no connector?
therefore no sense in connecting the pv blade up etc if there no power going to the solenoid.
cheers,
GAZ
edit : im reliably informed that the loom is still the same.
therefore your looking for a spare block connector, lol
as above on the right side. just back a bit from where solenoid bolts to frame.
follow the man loom back, & branching off it should be a short lenth of cable with the connector.
solenoid control cable plugs in there.
exits out the rear, under rear seat & into rave box.
cheekythomas
PostPosted: 14:57 - 22 Apr 2009    Post subject: Reply with quote
If you read the aprilia document, it shows you what and where... Wink
Mord
PostPosted: 17:11 - 22 Apr 2009    Post subject: Reply with quote
You can find it in 2008 (Euro3) bike.
https://i244.photobucket.com/albums/gg19/Mordoklej/HPIM5022.jpg
neil281088
PostPosted: 17:38 - 23 Apr 2009    Post subject: rs125 Reply with quote
apparently the guy in the garage says the rave controller plug (1999 model) does not fit my 2007 loom are they different or is he chatting balls
stirlinggaz
PostPosted: 19:53 - 23 Apr 2009    Post subject: Reply with quote
hi,
he's right...sort of.
if you have the new shape CDI, you dont need a "rave" box (powervalve control box)
but afaik the loom has the connection for the pv solenoid.
you dont need the rave box as its built into the CDI! (remember to get the hole drilled though)
bolt the pv housing complete with blade onto cylinder,
fit bowden cable, one end to pv blade other end to solenoid.
bolt solenoid to right side of frame. (holes are already there)
plug solenoid control cable into the elusive block connector.
change jets,spark plug etc.
enjoy.
GAZ
The last post was made 17 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.71 - MySQL Queries: 16 - Page Size: 62.02 Kb
