Security for a SUZUKI DR350s
dan3411
PostPosted: 14:17 - 22 Apr 2009    Post subject: Security for a SUZUKI DR350s Reply with quote
What sort of security can i install on the bike?
it's a 1991 model.
Alarms
Immobilisers
Cheers in advance for any advice guys Wink
Suzuki Bandit 600N
Finglonga
PostPosted: 14:58 - 22 Apr 2009    Post subject: Reply with quote
You can install anything you can on any other bike, the only limitation is how deep your pockets are.
Andy Sez....
F.Y.Y.F.F.
dan3411
PostPosted: 17:02 - 22 Apr 2009    Post subject: Reply with quote
i wanted to fit an immobiliser and an alarm.. but i assumed it needed to be an eletric start to have an immobiliser on it. Is that not the case?
Suzuki Bandit 600N
yen_powell
PostPosted: 17:50 - 22 Apr 2009    Post subject: Reply with quote
I used to have 1990 DR350S, it didn't need an immobilisor, any potential thief would be dead from a heart attack before getting it started from cold.
I would think they are more liable to lift the thing into a van so perhaps physical security would be better than electronic/electrical.
You could always fit a hidden switch that kills the ignition, like Suzuki did when they fitted the sidestand switch down where it can collect all the water and mud. Very Happy
XT1200Z and a DR350 in bits
c_dug
PostPosted: 18:01 - 22 Apr 2009    Post subject: Reply with quote
I used a hidden switch on my TDR it worked a treat Thumbs Up
I'd recommend a decent chain IMO Almax are the best for chains, also mayby a ground anchor Thumbs Up
c_dug
dan3411
PostPosted: 18:12 - 22 Apr 2009    Post subject: Reply with quote
lol ^^ the soles of my feet are all bruised from trying to start it with silly shoes.
Cheers for the advice guys i will go with a hidden switch and good chain and ground anchor route. Thumbs Up
Suzuki Bandit 600N
c_dug
PostPosted: 18:20 - 22 Apr 2009    Post subject: Reply with quote
A good way to make a temporary ground anchor is to use a barrel of some sort, drill a big hole through it and put a pipe through the hole, big enough for your chain to go through.
Then just fill the barrell with cement or concrete and you have a non permenant ground anchor, it might not be fixed to the floor but it would take a bloody strong thief to pick the barrell and the bike up Laughing
c_dug
yen_powell
PostPosted: 18:39 - 22 Apr 2009    Post subject: Reply with quote
I sussed it in the end, I used to turn the fuel tap on, open the drain screw on the carb until fuel started to flow out then close it. Used to start cold okay then.
Oddly, hot starting was never a problem even when the bike had been upside down in a ditch once an old crusty trail rider gave me some tips..
dan3411
PostPosted: 08:32 - 23 Apr 2009    Post subject: Reply with quote
I think now i have it sussed.. Smile i have to admit i wasn't particularly sure what the little lever was (decompression lever) the other bikes i had before didn't have it. I find that if you kick it down to the point that it flicks back out again then do a full kick it starts straight away more or less.
If anyone could give me a little info on how it works/ It's actually purpose on the bike would be great?
Am i right in saying it just rotates the crank untill it gets to the compression stage (both valves closed?)
Suzuki Bandit 600N
Finglonga
PostPosted: 12:07 - 23 Apr 2009    Post subject: Reply with quote
Vincent wrote:
AFAIK, the DC lever just opens a valve on the head to make it easier for you to kick the motor into the right position for starting.
As above it is so you can get the engine to TDC, then turn the valve off and start the bike.
With a small 350 engine it doesn't really need it and can be started without it easily. I had one on my KLR600 and I rarely used it but it did bite back a few times and left me with a sore ankle.
Andy Sez....
F.Y.Y.F.F.
yen_powell
PostPosted: 18:21 - 23 Apr 2009    Post subject: Reply with quote
Click the decompression lever so it's in. Put your foot on the kickstart and push it gently downward until the lever clicks open on it's own. You may have to let the kickstart up and repush a few times before it happens.
Anyway, when the lever clicks open, it's time to let the kickstart up and kick it normally, best with out touching the throttle at all (hot or cold).
If you've dropped or crashed the bike, don't thrash about kicking till you go purple and keel over. just turn the ignition off, hold the decompression lever in with your hand and open the throttle to max. Gently kick the bike through about 3 times (keeping the decomp lever in). Then start as paragraph 1 and 2 above, should start first go.
dan3411
PostPosted: 22:36 - 23 Apr 2009    Post subject: Reply with quote
I presume you have never had a DR350s?
Cheers for all the advice guys really helpful
C_dug
Current - 1998 kawasaki GPZ500
Past - 1999 suzuki TS50x, 1998 kawasaki GPZ500s
Every time i ride my new bike i miss my old bike even more Sad
Please tell me you don't miss the TS50x i had one of those when i was 16 ... could barely get me over a speed bump (slight exageration but was a very gutless bike)
Suzuki Bandit 600N
Finglonga
PostPosted: 22:45 - 23 Apr 2009    Post subject: Reply with quote
Not owned one but CG Chell in Stafford used one as a courtesy bike and had one for the day. . . . Why?
Andy Sez....
F.Y.Y.F.F.
c_dug
PostPosted: 22:58 - 23 Apr 2009    Post subject: Reply with quote
HAHA nooooo although i did have some fun on the TS in some woodlands Thumbs Up
The bike i miss the most is my TDR Crying or Very sad given the oppertunity i'd swap back in an instant, the GPZ is the same speed, if not quicker, but its so much less satisfying to ride Thumbs Down
c_dug
dan3411
PostPosted: 23:21 - 23 Apr 2009    Post subject: Reply with quote
I was trying to say that they are notoriously a bugger to start dispite their small engine capacity.
Suzuki Bandit 600N
Finglonga
PostPosted: 13:46 - 24 Apr 2009    Post subject: Reply with quote
That's what I mean, I only had it for a day so wasn't an issue. I was used to kick starting a 600 so a 350 giving me jip wouldn't stick in my mind. Wink
Andy Sez....
F.Y.Y.F.F.
The last post was made 16 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 16 - Page Size: 102.56 Kb
