Failed my MOT, worth me trying to fix it myself?
jp14
PostPosted: 18:01 - 03 May 2009    Post subject: Failed my MOT, worth me trying to fix it myself? Reply with quote
My yamaha rxs100 failed it's MOT the other day Embarassed due to head races being worn and front fork seals leaking (among a couple of other things) is it worth me trying to replace the head races and seals myself with some knowledge of using a spanner and a haynes manual, or paying over £100 for the garage to do it?
Thanks
KevTM
PostPosted: 18:42 - 03 May 2009    Post subject: Reply with quote
Not really that difficult unless you run into a problem. I say attempt it yourself, best way to learn Thumbs Up
One of the forks in one of my bikes was leaking, one of the previous owners had made a right mess replacing the seal.. there was parts missing and he hammered a washer in (instead of using the proper clip), ruined the inside of the fork leg Thumbs Down
creature
PostPosted: 19:01 - 03 May 2009    Post subject: Reply with quote
if your confident of your abilities then do it yourself...
if not then get it done by a bike shop.
Remember its your life on the line here !!!!!!!!!!!!!!!!!
Scotsman37
PostPosted: 19:02 - 03 May 2009    Post subject: Reply with quote
Depends what is causing the fork seals to leak? Either the seals have worn out or you have a scratch on forks that is cutting into seal allowing the oil to leak.
I would get a mechanic to replace your seals because if it still leaks then he will have to do it over again at his own costs not yours if he gives you a warranty for work carried out, unless he discovers that your fork(s) needs to be replaced due to long term wear & tear or a deep scratch by a stone.
My friend a long time ago had failed his MOT due to failed fork seals, because when the mechanic lifted the front of the bike physically upwards and discovered that a stone from the road must have scratched the fork low down when it was exposed when he no doubt accelerated. So not seeing it when off the bike unknown to him that scratch was slicing a groove into the seal.
mattsmith95
PostPosted: 00:15 - 04 May 2009    Post subject: Reply with quote
For all the work involved best let the bike shop deal with it, head race bearings are not that much of a problem but the forks could be a headache.
Best leave it to the shop as they do this sort of thing very often.
PostPosted: 01:38 - 04 May 2009    Post subject: Reply with quote
If you follow this logic you may as well buy a new bike. You can pick up T&T'd RXS's for sub £250 Fork seals and headraces will be at best 2 hours labour maybe 3 and the parts will be about £60.
The headraces went on mine too but I never fixed it as I got a bigger bike.
I've had 3 sets of bigger bike forks in bits, and there easy enough to do as long as you have some kind of seal driver
mikey 2659
cut off the cones carefully with an angle grinder and knock out the cups ,buy a set of taper roller bearings and drift in/on with the old parts,easier(no balls to lose),longer lasting,feel nicer,probably cheaper than yamaha prices.pack with suitable grease and DO NOT overtighten.both of my previous rxs were notchy on originals before 10k.it may seem like overkill but i got the bearings from an engineering suppliers cheap,he measured up the old parts,or you could try m and p.the fork seals are fairly easy to do,take care not to damage the leg when removing the seal,i used a large, close fitting socket back to front on an extension bar to drift the new ones in.when disassembling undo the top pinch bolts only to make removing the top cap on the leg with a 14mm allen key or similar tool easier.there is a spring under compression so undo carefully.i fitted motorcross style gaitors to protect the chrome legs from chips and corrosion.
jp14
PostPosted: 16:55 - 04 May 2009    Post subject: Reply with quote
mm, it sounds all pretty daunting, I think it'll be worth the extra £40 if the MOT station does it cos i don't need to pay for the MOT again so thats minus 28 quid. I can sort out the little problems my self relitivley easily.
And by the sounds of it i'm going to need some specialist equipmet so... I think, this time, the system wins..
Cheers for the advice Smile
dynamec
PostPosted: 17:35 - 04 May 2009    Post subject: fork sels and headrace bearings Reply with quote
we do forks and headraces weekly
can you support your bike? if it falls over could cause damage, some forks need special tools to disassemble too, plus you need the correct viscosity for oil to the correct level. inner races can be a pig to remove, often needing to be cut off with a disk.
knowing the gear we have and the safety issue. please only attempt if your realy confident mate.
dynamec motorcycle sales, tyres and service
mikey 2659
PostPosted: 23:15 - 04 May 2009    Post subject: Reply with quote
sounds like £50 per hour bike shop bull.putting weight on rear seat will hold front up,sae 5 or 10 fork oil,use 30p syringe to fill with correct amount then check level from top with ruler.buy the haynes manual,its all in there.last time a 'professional' touched my bike they adjusted the chain so tight i could not turn the wheel with both hands!A HONDA DEALER!!!!!! you only learn by doing.
dynamec
PostPosted: 12:16 - 05 May 2009    Post subject: Reply with quote
funny £50 an hour bulshit!!!
we only charge £35
costs us 4K a month on overheads too! If you have never done it you would never know.
I always encourage people to look after their machines. but only if they are sure of what they are doing.
oh yeah we get free tyre disposal, free oil recycleing, free insurance, free tools and consumeables and we have no mortgages to pay.........NOT.
NOT ALL SHOPS ARE THE SAME.
mikey 2659
PostPosted: 15:56 - 05 May 2009    Post subject: Reply with quote
WHOOPS,obviously i touched a nerve there!
clancy
PostPosted: 16:28 - 05 May 2009    Post subject: Reply with quote
there both pretty easy jobs, id do them yourslf for the sake of money.
headrace is straight forward, as for the forks....
its not to difficult, id advise using a guide from the internet and following it properly.
its not a huge job, 1-2 hours work.
leigh
KLX 300r
1016.5
PostPosted: 16:59 - 05 May 2009    Post subject: Reply with quote
Of course you should do it yerself.
If you've got a centrestand, a basic tool kit and maybe some circlip pliers it'll be a piece of piss. It's only a matter of confidence and if you get stuck or are worried about any of it, just post up on here and I'm sure that some will be happy to guide you along a bit.
Just think how satisfied you'll feel for having done it yourself and knowing that it's right and hasn't cost a fortune. You'll also be more confident when the next job comes along.
dynamec
PostPosted: 20:37 - 05 May 2009    Post subject: Reply with quote
mmm yes...... nerve touched. lol
all I am saying is if your confident and competent then go for it.
not everyone is.
the bodges ive seen can sometimes be lethal. some bikes that roll in here are horendous. we have an uncool wall full of it.
I have had pretty bad experiences in the past, just my point is not all dealers are the same.
PostPosted: 21:19 - 05 May 2009    Post subject: Reply with quote
You mean like pulling the dust coiver over the fork seals up, wadding a tightly rolled piece of kitchen towel under it then jamming it back down and taking it for a re-test.
I coulden't possibly condone that sort of thing Wink. I'd make sure I oiled all the nuts and bolts you'd need to undo to remove the forks so they look like they'd been off too. Whistle
Fitting a set of fork gaiters using jubilee clips or cable ties (which the tester is NOT allowed to remove) then taking it somewhere else for an MOT is another option I couldn't possibly condone. Shifty
You'll need to do the headstock bearings though. They can be a bit of a pain but there are plenty of threads about doing the job.
If you want the seals done at a garage, you can save a fair bit on labour by removing the forks yourself and taking them in loose. Then you aren't paying a mechanic to remove and refit them, something you can easily do yourself.
mikey 2659
PostPosted: 00:18 - 06 May 2009    Post subject: Reply with quote
no offence meant to dynamec or his motor bike shop but some of the work and advice i have received from 'PROFESSIONAL MECHANICS' in both car and bike dealers(HONDA AND VAUXHALL or should that be fiat?) has been inaccurate,misleading,dangerous,expensive,deceitful and just plain wrong.
neatbik
PostPosted: 07:04 - 06 May 2009    Post subject: Reply with quote
Im currently doing work experiance with Dynamec (martin) to go along with my college course.
As a fairly longstanding member on here i feel i can vouch for him, in that his workshop isnt your typical rip off palace.
We were both sick of getting poor service from dealers and paying way over the odds for tyres and parts, so the company was born.
We are all for people maintaining their own bikes, but there are a lot of people that havent the ability or time to do so.
One of the reasons we are in business? A KTM dealer in our neck of the woods quoted a customer £190 for a rear dunlop qualifier fitted - that to us seems like daylight robbery..
Mac_Black
PostPosted: 15:12 - 06 May 2009    Post subject: Reply with quote
I can also back up Nick and Martin, the point is that unless you are fully aware of what it is you are doing,
what belongs where and how different components behave and interact with each other then something as simple as overhauling forks could become very a very dangerous and expensive task.
I've recently overhauled my forks which are USD's,
replaced both of the races, top and bottom bearings and seals.
There are quite a few specialist tools that you will either need to by or fabricate, quite often the haynes will tell you that you need them, just not what they are.
Finding these tools can be a nightmare and is going to cost and your going to need to be very accurate if you have the skills to make your own.
Another point is about working safely on the bike,
for this sort of job you'll need the bike supported on either axle stands or by a winch, a ramp with a tie would be a very good idea,
you have to be very careful how you treat the forks and sometimes it can get quite frustrating especially if they've been bodged.
You should fully compress the forks before removal and allow them to fully extend for example to take the tension out of the spring, you should then loosen the top cap with only the bottom pinch bolts tight whilst still on the bike.
In this stage alone there is so much that could go wrong if you don't do things in the correct way, for instance there is the possibility that you could destroy the top cap and outer tube threads, failing to unload the tension on the spring can have the top cap shoot of at a devastating speed which WILL cause damage and injury.
Doing this sort of stuff at college in a professional and monitored environment I have to see that even we see allot of mistakes made and I can say I've made a few myself when I haven't been concentrating.
What Martin told jp14 was for jp14's own benefit so take the advice.
PostPosted: 17:01 - 06 May 2009    Post subject: Reply with quote
It is however an RXS100. It is a motorcycle most adults would be perfectly capable of lifting totally off the ground by themself (every time I take my H100 out of the lockup, I pick it up and carry it sideways 4 feet).
Buy a haynes manual. Read through the instructions, have a crack. A garage will almost certainly charge you more than the bike itself is worth to do both those jobs.
One thing I'd definately do is not waste my time fannying about with special tools and bits of broom handle taking the bottom fork bolt out. Take it to a nearby garage and ask them nicely to remove it for you using their air impact wrench.
jp14
PostPosted: 22:21 - 10 May 2009    Post subject: Reply with quote
I've ended up taking it into the garage; I know I would have just got frustrated with it and probably broken some more stuff, so I gave in Sad.
But.... it is not going to be ready till monday or maybe even tuesday which means I will have been a lovely sunny saturday and sunday without a motorbike Crying or Very sad!! Meaning i've had to cycle... on a bicycle!! Without an engine!!! And it's been great motorbike weather!!
Sorry, I just had to voice my frustration some how.
Thanks
Mudskipper
PostPosted: 23:03 - 10 May 2009    Post subject: Reply with quote
They tell you that, did they? You shouldn't have to pay the MOT fee again even if you do the repairs youself! Obviously within the whatever days limit on the sheet.
So it's NOT 28 quid less, the robbing bastards.
Do it yourself, I'm a girl and I did headrace bearings.
jp14
PostPosted: 16:33 - 11 May 2009    Post subject: Reply with quote
Interesting way of thinking about it, but it's too late now.
I think I could have done the head races but the fork seals seemed more complicated as I need an impact gun.
I am going to have to wait to see if it was worth me taking it there when they give me the price cos they have to order some circlips, meaning I won't have it back until probably thursday!! They could probably get circlips from homebase or something, it does seem like they're taking the piss, big time!
I am not happy having to revert back to pedal power after only a few months in the sadle of a motorbike Mad
PostPosted: 21:24 - 11 May 2009    Post subject: Reply with quote
They are probably the circlips holding the seals in and knowing the japanese, they will be a non-standard size so you HAVE to buy them off Yamaha.
Consider yourself lucky. I've been waiting 8 days for a weird, Honda only bearing costing £50 to arrive so I can put the back wheel back in my bike.
jp14
PostPosted: 12:36 - 12 May 2009    Post subject: Reply with quote
Yeah that's probably it, cos it is for the seals.
Ouch, i'm sorry to hear it!
The last post was made 17 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 134.01 Kb
