| chillpill |
 chillpill World Chat Champion
| MarJay |
 MarJay But it's British!
| SlimRick |
 SlimRick World Chat Champion
| Wozza |
 Wozza Brolly Dolly
| Paulington |
 Paulington World Chat Champion
| Kickstart |
 Kickstart The Oracle
| Paulington |
 Posted: 22:25 - 08 May 2009 Post subject: |
| Kickstart wrote: | | Paulington wrote: |
If you have more front end grip, then when you lean to take a corner, your front end will grip more than the back, which means if you turn sharp enough your front tyre will still grip while your back doesn't leading to a high/lowside. |
You stand some chance of catching it when the rear slides. You stand pretty much zero chance of catching it if the front goes. Hence having the rear slide first tends to be safer.
Keith |
Yeah, and obviously the reverse will happen if you have more rear end grip, like having a Diablo Corsa on the back and a plastic tire on the front. ____________________ "Four wheels move the body, two wheels move the soul."
CBT: 27/08/08. Theory: 04/09/09. Module 1: 16/09/09. Module 2: 01/10/09. |
| KevTM |
 KevTM World Chat Champion
 Posted: 22:30 - 08 May 2009 Post subject: |
I think this is more complex than, at least I, understand.
My thinking is that even with matched tyres the front & rear will have different grip levels at any given time, different loads on each tyre, etc etc.. Have you even lost both tyres at the same time? It's usually one or/then the other.
Perhaps that's why different tyres seem to work better on different bikes and/or for different riding styles?
To be honest I can't see there being much of a problem as long as you're not running completely different compounds, for instance, a hard/touring rear and a super soft front or something.
I could be completely wrong but surely there's some sense in there  |
| Wozza |
 Wozza Brolly Dolly
 Posted: 23:09 - 08 May 2009 Post subject: |
| KeV6 wrote: |
To be honest I can't see there being much of a problem as long as you're not running completely different compounds, for instance, a hard/touring rear and a super soft front or something. |
Pretty much what I was thinking.
Having a softer front tyre won't make the rear tyre have any less grip than normal, that's just daft. If you've got a crappy plastic tyre on the back, it's gonna slip no matter what you've got on the front.
I know of people who purposefully mismatch tyres to get a better lifespan out of the rear by sacrificing a little bit of grip, but keeping a softer tyre on the front.
For example:
Bridgestone BT-090 front, BT-92 rear.
Or Michelin Pilot Power front, Pilot Road 2 rear.
I wouldn't want to mismatch any old tyres, but thought-out mismatching is not uncommon. |
| Paulington |
 Posted: 23:55 - 08 May 2009 Post subject: |
| Wozza wrote: | Having a softer front tyre won't make the rear tyre have any less grip than normal, that's just daft. If you've got a crappy plastic tyre on the back, it's gonna slip no matter what you've got on the front. |
I didn't say it would, I said the front would have more grip, and therefore while it would still grip comfortably, the back tyre if it is a bit harder will slide on heavy cornering. It'd only be noticeable if you were pushing it though.
However, to keep the thread going in the intended direction..
My bike, going to lean into a corner it feels as if it doesn't want to lean, and when it does lean it feels as if the front end is going to drop away.
Any clues? ____________________ "Four wheels move the body, two wheels move the soul."
| Eddie Hitler |
 Eddie Hitler World Chat Champion
 Posted: 23:58 - 08 May 2009 Post subject: |
Yea, you ride a shitty bike and think you know everything about motorbikes. |
| Paulington |
 Posted: 00:02 - 09 May 2009 Post subject: |
| Eddie Hitler wrote: |
Thanks. .
If I thought I knew everything, I don't think I'd be asking a question about my bike now would I? . ____________________ "Four wheels move the body, two wheels move the soul."
| Eddie Hitler |
| Paulington |
| Eddie Hitler |
| lukamon |
 lukamon World Chat Champion
 Posted: 00:18 - 09 May 2009 Post subject: |
hes got a point though. 75mph? my c90 does 60mph  ____________________ killa wrote: Im an ass man myself |
| Ben. |
 Ben. World Chat Champion
 Posted: 00:36 - 09 May 2009 Post subject: |
depends what your mixing...
ive got a 2ct rear and a diablo corsa front, both got more than enough grip to get rid of any chicken stips, both heat up at about the same pace, and neithier will overheat on the road, so its fine. However i had a shitty michilin rear before i got the 2ct and that would over heat, and suddenly let go mid corner, the front would stay planted but the rear would slip, if your going to mix, allways get a grippier front, or get tyres that are of similar grip that you know you cant over heat... ____________________ follow my racing season
Race bike - R6
Road bike - sv650 |
| Paulington |
 Posted: 00:39 - 09 May 2009 Post subject: |
Malossi kitted RSes can do 100+ but only for about 15 minutes, mine is a reported 50cc cylinder, custom pipe, new carb and airbox + slipstreaming behind my Dad's bike.
Blah blah whatever, if you doubt it fair enough but if you want to debate it don't 'jack a thread to do it. ____________________ "Four wheels move the body, two wheels move the soul."
| Ben. |
| Eddie Hitler |
| keyser soze |
 keyser soze Scooby Slapper
| iooi |
 iooi Super Spammer
| garth |
 garth World Chat Champion
 Posted: 10:10 - 09 May 2009 Post subject: |
I like having a crap tyre on the back, it's fun  ____________________ You ain't a has been if you never was |
| Kickstart |
 Posted: 18:29 - 09 May 2009 Post subject: |
I would say that grip and handling are 2 different things. Sometimes you land up with both.
Sometimes (most of the time I would say) mixing different tyres wil be fine in normal use. Riding at the very limit probably not perfect, but then very few have the ability to really ride at that limit.
As to your handling issue with the RS50, first thing I would say to check would be the tyre pressures. Tyre wear can also have odd effects. A worn front tyre can often give the same handling as a front tyre that is low on pressure (ie, when you start to lean the bars want to turn into the corner).
| Joeb46 |
 Joeb46 Traffic Copper
 Posted: 22:24 - 10 May 2009 Post subject: |
i have odd tyres and i still managed to get my knee down today, not big or clever on a drz but never mind, something to tick off the list  ____________________ Current- Drz400sm- For sale
Kawasaki er-5 race bike# 106 |
The last post was made 17 years, 128 days ago. Instead of replying here, would creating a new thread be more useful? |
