Some undescended testicle violated my baby :(
Visitor Q
$25 whore
PostPosted: 15:44 - 25 May 2009    Post subject: Some undescended testicle violated my baby :( Reply with quote
Just got out of work, dying of man-flu (might as well be malaria then, it's all going black Sick ) to find my bike where I left it.
Had a nice cig, then noticed a barend suspiciously like mine lying on the floor.
Bastard bolt had been snapped clean in half, and all the throttle tube was cracked.
Then found my disclock was wedged between the stantion and disc, completely stopping the wheel (with a nice chunk out of the locks robber sleave).
Managed to unwedge it and theres no apparent damage to the disc (no pulsing etc), and the throttle does just about work.
Bastard. Lots of extra scratches to my already scratched bike, but its the principle about that too Evil or Very Mad They were MY scratched from proper slides, not some mongoloid trumpet cunt wanting to play biker.
*Breath*
Anyway, there appears to be a CCTV camera that would of had a perfect view, but knowing the NHS it wasn't on. If it is though, what can I expect as an outcome? I phoned the fuzz and got a crime number, and they're going to ask security for footage. FYI, never let 118118 put you through, rinsed £6 of credit in 5 minutes Crying or Very sad
I'm ringing the local Honda garage to ask how much to fit a throttle tube and grip (gonna be lumpy, you have to rip the carbs off to get the cables off to get the tube off). Bar end was scratched to hell and bolt snapped, so £15 for them. And because the guy is obviously a tit, I'll get a new endcan, indicator and brake lever (or the money to replace them) if I can, because they are far more fucked then before. It's the principle damnit.
Anyone had experience of this? What was the outcome?
(Apologies for the weird prose, I'm on a lot of substances to try to battle the green monkey disease I've been exposed to).
rottie007
PostPosted: 16:17 - 25 May 2009    Post subject: Reply with quote
yeah sadly I have...
the monkey used to be prime target for gettin bits twisted off it, god knows how many air filters, had the plug cap stolen once !
took to covering the loose bits with CV grease (green and seriously sticky) stopped it all dead.
no doubt some toe-rags walking about with green fingers as the stuff is nigh on impossible to wash off as it just smears an smears
Visitor Q
$25 whore
PostPosted: 00:53 - 26 May 2009    Post subject: Reply with quote
Lol @ 186 people coming in because of the strange thread title Laughing
Post you bitches.
nick606
PostPosted: 01:08 - 26 May 2009    Post subject: Reply with quote
ok ill admit it this thread has tricked me 183 into viewing it. Crying or Very sad
Flip
There are some total tossers about Bonny. Sadly one of them found your bike.
PostPosted: 01:15 - 26 May 2009    Post subject: Re: Some undescended testicle violated my baby :( Reply with quote
Sounds odd.
I bet you can get the tube off by removing the handlebar and sliding it out.
Reassembly is the reverse of the above.
Even if the cables need detaching, you can unhook the throttle cables on my VFR (Which probably has the most complex carb setup you're likely to see on a sportsbike) without disturbing the carbs themselves. Admittedly you have to take the side plastics and tank off but that's all.
Visitor Q
$25 whore
PostPosted: 01:22 - 26 May 2009    Post subject: Re: Some undescended testicle violated my baby :( Reply with quote
How much? Laughing
Cables are tight on the tube (push and pull remember), I've managed it once by brute force, and a month or two later the cable snapped RIGHT there (where I was forcing it).
Which means you at the least have to adjust the hell out of them, which is a tank and airbox off jobby. But even Haynes says get them off the carb cams, which requires taking off the carbs (and eventually getting them back on again), not a fun job on the CBR.
I'll be doing it myself, but he'll get the Honda quote.
PostPosted: 01:40 - 26 May 2009    Post subject: Reply with quote
Be the first set of Japanese carbs I've ever seen that you have to remove to detach the throttle cable(s).
There again, The newest Jap. bike I've owned is ten years old. Perhaps they have plumbing new depths of design lunacy in recent years?
Don't tell me they've started putting the throttle pulley between carbs 2&3 instead of on the end again? That is, as my younger brother is fond of saying, "a cunts game".
Visitor Q
$25 whore
PostPosted: 01:46 - 26 May 2009    Post subject: Reply with quote
Yep, it's in the middle hidden away underneath them. You have to take them off and rotate them 90degrees to have a shot at doing them. Took me and a mate about 2 hours to change the throttle cables over.
Ah well, it's rideable as it is, and I can sort the bar end out with the spares from the other side that I screwed straight in to the weight with a random bolt. Still, very irritating.
Glad I have crash bungs though.
Paulington
PostPosted: 06:36 - 26 May 2009    Post subject: Reply with quote
118118 To put you through to what, the police? Laughing
Sucks about your bike man, I've come back to my bike regular to find the sprocket lock wedged in the chain guard, cunts.
Hopefully something gets done. Thumbs Up
Visitor Q
$25 whore
PostPosted: 09:12 - 26 May 2009    Post subject: Reply with quote
Local police. You don't use 999 for trivial crimes.
mr.kris
PostPosted: 10:01 - 26 May 2009    Post subject: Reply with quote
umm you dont need to have the carbs off at worse you need to remove the clip on to make the cables lose but you dont need to take carbs off
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
Poseidon
PostPosted: 10:17 - 26 May 2009    Post subject: Re: Some undescended testicle violated my baby :( Reply with quote
Says it all really!!! Laughing
If I remember correctly, you can send a "subject access request" to the NHS to get hold of the CCTV footage... usually a small fee (up to £25). I could be wrong, but I seem to think that it's all under the data protection act.
Sorry to hear about your bike though! It's never nice to hear things like this!
Love it!!! Thumbs Up Razz
1977 Honda CG125
Visitor Q
$25 whore
PostPosted: 10:21 - 26 May 2009    Post subject: Reply with quote
I'm failing to see 'CBR 600' on your list of previous bikes. It's in Haynes for fuck sake.
NSR Mick
PostPosted: 10:39 - 26 May 2009    Post subject: Reply with quote
Must be right then. Laughing
Visitor Q
$25 whore
PostPosted: 10:49 - 26 May 2009    Post subject: Reply with quote
When Haynes says you 'may want to do X', it usually means that it's going to be a pig even if you do that, and you're deluding yourself if you don't.
I changed the throttle tubes once before with everything but the carbs off, and had to wedge the cables in and out with fuckloads of brute force and screw driver. As mentioned, one of them failed a month or two later. Now I have nice new cable I don't quite fancy destroying them in the same manner, capeche?
Visitor Q
$25 whore
PostPosted: 10:57 - 26 May 2009    Post subject: Re: Some undescended testicle violated my baby :( Reply with quote
Will be phoning security as the pigs (after spunking all that money talking to them) said 'well, it's over the 2 hour window we bother with, so erm, yeh, let us know if you work out who it is'. Going to make sure the don't delete the tapes from yesterday and if needs be I'll watch em, even at 10 times speed its only half an hour. You won't have to go slowly though, one second the bike will be standing, the next it won't.
One thing I think it might be though, yesterday was the first time I've parked on the right hand side of the door. Maybe someone out on the phone or having a fag decided to lean on it, not realising it would fall over past a certain point.
Gotta love the police, 'oh, if it's someones sat on it and its just fallen over, then thats not a crime cos it's accidental'. Right, so when I accidentally ram someone elses car I'll remember that.
Poseidon
PostPosted: 11:18 - 26 May 2009    Post subject: Re: Some undescended testicle violated my baby :( Reply with quote
It should be fine, most places keep CCTV footage for about a week before it's deleted. We have the new fangled harddrive systems at work... Keeps stuff on there for a month before it's lost!!!
1977 Honda CG125
Visitor Q
$25 whore
PostPosted: 11:25 - 26 May 2009    Post subject: Re: Some undescended testicle violated my baby :( Reply with quote
This is the NHS, they have several hundred cameras in the place, usually in pairs (looking the same way Thinking). I reckon half of them don't work, and of those they probably don't record anything.
It's a shite hospital. Oh well, I'll give em a go.
Poseidon
PostPosted: 11:31 - 26 May 2009    Post subject: Re: Some undescended testicle violated my baby :( Reply with quote
Is that the new NHS slogan??? Laughing
1977 Honda CG125
Visitor Q
$25 whore
PostPosted: 11:33 - 26 May 2009    Post subject: Re: Some undescended testicle violated my baby :( Reply with quote
Lol, quite possibly Laughing
Visitor Q
$25 whore
PostPosted: 11:48 - 26 May 2009    Post subject: Reply with quote
Oh how I love our largely nigerian workforce Rolling Eyes
Anyhew, they reckon;
1 - I can't view the tapes, because I don't have clearance and it would make it inadmissable
2 - They can't view the tapes without the police.
Which coupled with the polices 'We can't watch 6 hours of tapes, we have a 2 hour maximum' essentially means this tit has got away with it.
Fucking useless cunts.
Knacker
PostPosted: 12:19 - 26 May 2009    Post subject: Reply with quote
If someone stole my bike id be straight on the 999 my bike is more important than some ol dear getting burgurled she's probably had a good life , I havent even lived yet and how am i supposed to do that without a bike Shocked
Previous: K1 GSXR 1000
Mister James
I want to believe!
PostPosted: 12:57 - 26 May 2009    Post subject: Reply with quote
Meh, there's no law against it - although they aren't really under any obligation to show you the footage. As one of the usual justifications for us being snooped on by CCTV is that it helps prevent/solve crime, you'd think they'd be a bit more accommodating.
Now they are definitely talking bollocks. In most cases police don't sit there beavering through massive piles of CCTV tapes - the victims/organisations (pubs, hospitals, shops) look through it, find the relevant bit and THEN show Old Bill.
Sounds like you need to stir up a bit of fuss with someone.
I think that whatever mong told you that was trying to get across that it wouldn't be criminal damage if it was a genuine accident - ie someone stumbling into the bike as they walked past.
Act
S 1(1) Criminal Damage Act 1971
Points to prove
Without lawful excuse
destroys/damages
property
belonging to another
intending/reckless as to
the destruction/damage
To my mind, a member of the great unwashed sitting on a bike without permission of the owner would be acting in a manner reckless as to it sustaining possible damage - making it an offence regardless of intent.
Some old codger wobbling past and bumping into it by mistake would not be reckless, and thus would not commit an offence.
Your analogy of ramming a car is a little different, as you'd probably be committing a moving road traffic offence, independently of any criminal damage!
Mister James
I want to believe!
PostPosted: 13:00 - 26 May 2009    Post subject: Reply with quote
If you'd ever had to sit with some poor old duffer who'd been the victim of a distraction burglary, you might think differently.
I don't think I've ever felt quite so angry and ashamed of society in general - and I've had a bike nicked before.
People who prey on the good nature of old codgers are vermin, and are up (or down, I suppose) there with paedophiles in my estimation.
The last post was made 17 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.51 - MySQL Queries: 16 - Page Size: 153.56 Kb
