Strange Front Brake problem
shaba2000
PostPosted: 10:21 - 28 May 2009    Post subject: Strange Front Brake problem Reply with quote
Guys
The other day I forgot to take off my disk lock and tried to ride the bike. I managed to keep it up and limit the embarasment however now am having the following problem...
When the bike is moving and I press the front brake lever it just goes all the way in and doesnt stop the bike.
If I stop at the lights and keep pressing the front brake lever it hardens up as becomes normal and stops the bike from moving as normal.
I took off the caliper and cleaned it and examined all pipes for leaks etc and everything seems fine?
would appreciate any suggestions as I am riding on my back brakes only at the moment and am contstantly ready to dive off in case i need to do a emergency brake!
Its a kawasaki zx6r 1997 f3 model by the way Smile
kawasaki Ninja-zx6r 1997 (f3)
Ichy
PostPosted: 10:32 - 28 May 2009    Post subject: Reply with quote
only things I can suggest is that either 'somehow' air got into the system, should be sorted if you bleed them, or, the caliper has been twisted creating a bigger gap to the disc.
When you build up the pressure does it remain constant if you keep the lever held in?
shaba2000
PostPosted: 10:46 - 28 May 2009    Post subject: Reply with quote
Thanks for the replt Ichy.
When the bike is on standstill it remains constant and just like normal. Only when the bike is moving it does work.
I was thinking to bleed them this weekend to see if that resolves it but then if that was the case it wouldnt work even on standstill right?
Ichy
PostPosted: 11:27 - 28 May 2009    Post subject: Reply with quote
I thought of that as well Chris but would of expected the OP to mention the pulsing when braking.
It does sound like something is bent, got any photos, especially of the gap between the pads and disc.
Any way you can get the front wheel off the ground and give it a spin?
gavcarter
PostPosted: 11:34 - 28 May 2009    Post subject: Reply with quote
Sounds more likely to be a misplaced brake pad i.e it has moved or air in the line.....
I cant see any real damage being done from a disk lock
You 100% its not leaking though?
PostPosted: 11:47 - 28 May 2009    Post subject: Reply with quote
I would go with the idea of a fairly badly bent brake disk. Support the front end, spin the wheel and check for the disk appearing to wobble.
shaba2000
PostPosted: 16:37 - 28 May 2009    Post subject: Reply with quote
Thanks for all replies guys.
I will go home and put it on the front paddock stand and spin the wheel to check for a bent disc and i will also try what chr15 suggested about stopping and checking the front brakes when the lever is at its loosest.
100% sure there are no leaks also.
Will update you guys tomorrow of my findings.
Thanks again Thumbs Up
Blue_SV650S
PostPosted: 18:28 - 28 May 2009    Post subject: Reply with quote
Its a bent front disc. A fairly common result of a disc lock mishap!!
You can try and bend the old one back, but your chances of success are very slim!!
Its a new disc I am afraid Sad
PostPosted: 19:20 - 28 May 2009    Post subject: Reply with quote
Bent disk or carrier for sure!
shaba2000
PostPosted: 12:38 - 29 May 2009    Post subject: Reply with quote
guys I got it on the paddock stand and spinned the front wheel.
It is a bent front disc!!
Ah well something new learned and lucky its the end of month so new discs it is then!
thanks for all replies. Thumbs Up
The last post was made 17 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.83 - MySQL Queries: 16 - Page Size: 68.77 Kb
