ZX6R G2 1999 steering problem, anyone help??
tpuck
PostPosted: 13:58 - 07 Jun 2009    Post subject: ZX6R G2 1999 steering problem, anyone help?? Reply with quote
Hi all,
I took a shot of my mates zx6r a couple of days ago, very scary!!
The bike feels very strange and corners really badly, as i tryed to work out what was going on i noticed that the steering seems very reluctant to steer then all of a sudden the bike would fall very quickly to the side of lean!! does that make sense??
i spent a wee while trying to counter steer both directions and it was the same every time, the result is massive over steer and a very uneasy feeling on the bike.
My mate has not long passed his test and has been saying that he cant get any confidence in cornering, i now know why.
i have checked the steering head bearing and there seems to be no play in it, could it still be the problem??
can anyone help? thank you
T
TUBZ69
PostPosted: 14:05 - 07 Jun 2009    Post subject: Reply with quote
it honnestly sounds like fucked headbearings mate, or the tyres could be squared off...
those who risk nothing, become nothing, achieve nothing....
c90 rvf 400, vfr 400, gpz 500, Gsxr 750, R1, Zx6r....
TUBZ69
PostPosted: 14:07 - 07 Jun 2009    Post subject: Reply with quote
PostPosted: 14:17 - 07 Jun 2009    Post subject: Reply with quote
Definitely check the tyres for squaring Thumbs Up
KevTM
PostPosted: 14:43 - 07 Jun 2009    Post subject: Reply with quote
squared tyres was the first thing i thought of..
if it feels like sh*t though it could be anything, low fork oil, wrong fork oil, buggered rear shock, wrong shock settings, dodgy bushes in the linkages, wrong tyre pressures even, misaligned rear tyre adjustment, front/rear height set up wrong.
Worth giving the whole thing a once over as it could be a combination of some/all of above. Wink
I take no responsibility for any damages that may be caused from the advice given.
Chriss
PostPosted: 14:52 - 07 Jun 2009    Post subject: Reply with quote
Had this on my Triumph, the tyres were over inflated to around 50psi.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
The Tot
PostPosted: 14:55 - 07 Jun 2009    Post subject: Reply with quote
Won't be surprising on an F/G 6R for the headbearings to go. Lean the bike on its side stand to get the front wheel off the ground and turn the bars from lock to lock - if it's notchy, then head bearings are shot - easy job to do. That's what happened to my 6R AFTER it was diagnosed that the tyres weren't square (only had them on for 1000 miles). But then again, there's no play.
If you can find the suspension settings from a haynes manual - put it back to stock. That'll be a cheap fix with a spanner.
If you want new boots, I can vouch for getting roadsmarts on the bike!
Never argue with autism
tofu-wtf
PostPosted: 10:08 - 08 Jun 2009    Post subject: Reply with quote
I have a G1 and I can tell you that the tyres dont have to be too squared off to get that effect.
I have just changed the tyres on mine and I was amazed at the amount of handling that had been lost.
IMO If the head bearings are OK, and that is like a 2 minute check, go get new tyres.
Eagles may soar.............but rats don't get sucked through jet engines!!
1999 ZX6r G1.....it makes me smile Very Happy
Fawbish
PostPosted: 10:23 - 08 Jun 2009    Post subject: Reply with quote
Me and Titz are the resident F/G gurus.
I am almost 100% certain it's headbearings. Does it feel notchy at slow speeds?
Fawbish
PostPosted: 10:29 - 08 Jun 2009    Post subject: Reply with quote
I've honestly found that even if a fair amount of swuaring has occured, its usually nowhere near as noticeable as headbearings. And a bike will still corner fine with squared off tyres if pressures are somewhere around correct, if the person is cornering properly.
Good pressure + Squared tyres = Very minimal effect
Bad pressure +Squared tyres = noticeable effect to the point of instability
Good or bad pressure + shit headbearings (notchy/fucked) = very noticeable shit handling Laughing
The Tot
PostPosted: 10:32 - 08 Jun 2009    Post subject: Reply with quote
What mileage is the bike? If its anywhere between 20-35k, and there's no history or receipts to check that it's done, then it'll probably be wise to change or do the following:
Arrow Grease rear shock joints and linkages
Arrow Change tyres
Arrow change head bearings
Arrow Re-gas and service rear shock
Arrow Change front fork oil
Once that's all done, it'll be as sweet as a nut. I noticed my bike go through the transition of being a stable, compliant turner to what you've just described there and the steps . The mitigating steps were taken in that order as the problem progressively got worse.
TheDonUK
PostPosted: 12:18 - 08 Jun 2009    Post subject: Reply with quote
Also check the front wheel bearings, worn ones can cause similar handling as to that which you describe...
Low tyre pressures will make it sloppy, but that double tip into corners is often bearings i have found.
What tyres are you running on it?
Fawbish
PostPosted: 13:00 - 08 Jun 2009    Post subject: Reply with quote
Arrow Change tyres
Arrow Re-gas and service rear shock Arrow Change front fork oil
Obvs still advised, but not essential I'd say. Unless theres genuinely a problem with it, mine has never been serviced, seen some harsh track use, and is still going strong at 27K.
Obvs, something that will need doing as time goes on like.
Same with the forkoil, as far as I know, never been changed Laughing Though will be doing it soon, as I have a weeping forkseal so will do the lot.
Oh, and I totally agree with rear linkages. Upto 22/23K, my bike hadnt really seen any "abuse" and there was a lot of play in the linkages. So much so that it failed an MOT. Def worth doing, got my full set of bearings for about 80 quid I think, a fair amount of hassle if doing it on the deck, what with full exhaust off etc Laughing
The last post was made 17 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 81.83 Kb
