Disc lock left on :(
kingsknight
PostPosted: 19:34 - 11 Jun 2009    Post subject: Disc lock left on :( Reply with quote
Warpped my front disk today by riding off with my disk lock on! Now when i spin the front wheel it spins freely till it hits one point in the disk then stops. It needs some effort to move wheel by hand but once its past the tuff bit it spins freely.
Took off the caliper and it looks fine! now there is a slight knocking sound coming from the caliper when you push it forward!
Ordered a new disc and it should be here saturday! I got no choice to ride it to work for the next two days but its only a 8 mile round trip!Will be taking it very easy thats for sure and using my back brake mainly! Iv got some new brake pads ill put in once i replaced the disc!
Just praying its just the disc which is fucked and not the caliper and disc!!!!
Ill find out saturday!
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
kingsknight
PostPosted: 19:35 - 11 Jun 2009    Post subject: Reply with quote
P.S i know im a tit lol
tutton
PostPosted: 19:42 - 11 Jun 2009    Post subject: Reply with quote
Disc will be bent,
always happens when people leave em on.
get a ruler and spin the bike with the ruler touching the edge of the disc see if it stays straight...
kingsknight
PostPosted: 19:46 - 11 Jun 2009    Post subject: Reply with quote
nope the ruler moves every time at the same part of the disc! has to be the disc then. Also iv noticed that the whole caliper moves slightly when the wheel becomes stuck!
Im now 95% sure its the disc!
tutton
PostPosted: 19:50 - 11 Jun 2009    Post subject: Reply with quote
Id be careful riding that as if its warped enough to move out enough to touch the pads lol.
Or if you need id desperatly, it will feel like its fading, as it will be strong as fook where its warped then go to normal braking around the disc, dangerious shit Laughing
kingsknight
PostPosted: 19:58 - 11 Jun 2009    Post subject: Reply with quote
Im push biking it to work! Dont want to risk it! Iv been reading some posts on here and it looks like quite a few people have done it!
If it was a biker bike looks like i could of smashed the caliper and disc!!!
iv ordered myself a reminder strip and new lock! the other one is fucked, the pin which went in the disc snapped in half!!! good lock yeah? lol
Tonka
PostPosted: 20:17 - 11 Jun 2009    Post subject: Reply with quote
Bad luck, matey Crying or Very sad
It was thanks to reading threads on here that the first thing I did when I bought my disc lock was attach a fluro bungie to act as a reminder. They're cheap as chips and very worthwhile - not that you're likely to ever do it again, but just in case Wink
Reppyboyo
PostPosted: 20:57 - 11 Jun 2009    Post subject: Reply with quote
Yup I did that on the very first day I bought my Speed Triple. Laughing
Was lucky though as the disc didnt bend.
Mudskipper
PostPosted: 21:08 - 11 Jun 2009    Post subject: Reply with quote
I too did this, only once though! Laughing Warped my disc but caliper was fine.
I think you're right not to chance it till it's sorted. Thumbs Up Not worth it.
hellobaby
PostPosted: 23:19 - 11 Jun 2009    Post subject: Reply with quote
lol, I just did this yesterday, had to call out the AA man since my lock was small enough to get wedged in between the disk and the inside of the front fork, only damage i sustained by the looks of it was a bent bit on the inside of the disk which was bent back, I dont think my disk has been bent but i will do the ruler test just to be sure.
its a bi@ch when its your own stupidity that costs you money
CBT - 10/05/08, Theory 7/05/08
andi
PostPosted: 07:08 - 12 Jun 2009    Post subject: Reply with quote
My disc lock got thrown after the second ride off Embarassed .
Before: Suzuki GT 185. Honda Superdream 250. Yamaha RD350LC. Suziki RG250. Yamaha FZS600. Honda CBR600F3
Now: Honda Fireblade 929
kingsknight
PostPosted: 17:42 - 12 Jun 2009    Post subject: Reply with quote
iv ordered a new disc should be here in less then 24 hours i hope!
Looks like a real simple job changing the disc on an XR! wheel off > Disc off > new disc on > wheel on > start riding!
5 8mm bolts holding on the disk! shouldnt take much more then 30mins to do!
ill let you all know how it goes. The thing is tho, i cant see an damage to the disc which is strange! but then again only needs to bend the disc 1mm to make the knocking sound im guessing
tutton
PostPosted: 18:48 - 12 Jun 2009    Post subject: Reply with quote
id laugh if the disc bolts rounded or or were a bitch to get out like on most bikes then you wouldnt be saying 30 min job Laughing
Clanger
Stirrer
PostPosted: 20:05 - 12 Jun 2009    Post subject: Reply with quote
I take it you managed to save the bike from going over and causing more damage!!!
trickysax
PostPosted: 07:57 - 13 Jun 2009    Post subject: Reply with quote
tutton wrote:
Disc will be bent,
Doesn't alwys happen, but is was has happen to you sadly. Hope it is an easy fix. Check the caliper mounting too, as this may be damaged. It is far too easy to do, but like Tonka said, get a bungee chord and use it every time you use the lock.
C̶u̶r̶r̶e̶n̶t̶ ̶b̶i̶k̶e̶ ̶-̶ ̶B̶a̶n̶d̶i̶t̶ ̶6̶5̶0̶s̶ ̶ Sad
Its not about the destination, its the journey that counts.
ajb
PostPosted: 10:15 - 13 Jun 2009    Post subject: Reply with quote
I have a disc lock with alarm, it's so sensitive that if I put the key in the ignition it beeps.
Also, I attach the lock BEHIND the caliper, so if I did try and ride off, it would only have about an inch of rotation on the disc before contact, thus minimising the momentum the bike would build up had it be fixed on the opposite side (effectively giving an entire rotation of the wheel (likely to be over a metre of travel distance).
CBR125R '05 > CB500 '00 > CBR600F '99
kingsknight
PostPosted: 09:24 - 14 Jun 2009    Post subject: Reply with quote
Replaced the disc which was a 10min job and everything is now fine!
Nope I didnt drop the bike as the lock snapped in half!!! was a cheap alarm lock!
PostPosted: 09:55 - 14 Jun 2009    Post subject: Reply with quote
I don't know why people haven't cottoned-on to this. The number of times I've suggested it to people an I nearly always got a blank-stare in return. Some even admitted they had bent discs by riding off then went ahead and put it on the front anyway.
My brother smashed the caliper right off his fork leg once with a disc-lock.
The last post was made 17 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.88 - MySQL Queries: 16 - Page Size: 104.05 Kb
