| alun111 |
 alun111 World Chat Champion
 Posted: 19:14 - 11 Jun 2009 Post subject: Cg125 no spark |
Similar to the other topic, but single cylinder. I thought I'd start my own thread for obvious reasons.
1988 cg 125 BRJ - been standing for a total of about 2 years, I revived it about a year ago by cleaning the carb, putting fresh fuel in the tank and cleaning the plug, it started up with a bit of persuasion.
This time, no dice. I done all of the above, as well as fitting a new plug - no spark.
As far as I know the only things that could prevent it from sparking are.... points, ht lead, cap, coil.
I don't know how to test any of them!
If any one can help me I'd greatly appreciate it, I'm trying to get the bike back on the road for my brother so we can get rid! I've already ordered a new throttle cable and air filter, and I plan on rebuilding the front forks as well as respraying the tank and petsealing it.
Cheers! ____________________ Summer: '00 Honda CB600F Hornet
Past Bikes: Lifan LF100-5 Lifan LF125-A Honda C70 |
| Tribal-Wolf |
 Tribal-Wolf Two Stroke Sniffer
 Posted: 19:25 - 11 Jun 2009 Post subject: |
Here is a manual for it that might help CG125 |
| alun111 |
| Creepin Moses |
 Creepin Moses Nova Slayer
| alun111 |
| Pie-Roe |
 Pie-Roe World Chat Champion
 Posted: 07:24 - 12 Jun 2009 Post subject: |
Ok
As far as I'm aware, points won't make a difference to actually getting a spark, running is a different matter, it's what I got told for a '73 cb125
Check the ht lead all the way back to the coil for any cracks/grazes in the tubing, gently pull the rubber tubing back from the cap and give it a good going with wd40. (in fact take the plug out of both the head and the lead, spray both ends with some wd40, as well as the area around the coil)
Coil, multimeter it, I have no idea what it should be making however.
Pyro ____________________ Previous: GSF600, FZR600 x2, ZXR750, XT600 Tenere, CB125, CZ125, ETZ 250, ER5, CCM R30, DRZ400, RF600x4, RF900x2, GS500, VTR1000F, 640 SMC, CB250 NIGHTHAWK, GT550x3, GPX750 TE610, CB500, X11x2, SV650, ZING 125, TL1000R,CB250 Superdream, CBR1100XX |
| alun111 |
| finpos |
 finpos World Chat Champion
| alun111 |
| alun111 |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 20:15 - 13 Jun 2009 Post subject: |
There's a chance that the CDI may be duff.
If the link's a haynes manual, then there'll be a table of results that one should be expecting on the multimeter when testing the coil, along with instructions on how to test the coil. I found it a bit weird on the old CB125TDC, but it made sense after re-read it, and put the beer down...
Also, apologies for asking the patronising question here, but are all the other electrics OK? i.e. Lights, horn and so forth. You've not mentioned the state of them. Could just be a dead battery... ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| alun111 |
| robocog |
 robocog Traffic Copper
 Posted: 23:18 - 13 Jun 2009 Post subject: |
Have you checked the fuse? <- obvious stuff first
If ok check for 12v at the coil (or 6v if its that old)
(on the coil there should be a + feed from ignition switch)
Points could be foobarred as already put forward which would stop the coil from making the spark
The coil's HT lead could also be broken, or I suppose the cap
Its a pretty simple system if its anything like my old points CG and relatively little to go wrong so shouldn't take long to sort or turn out too expensive
(worth a quick look behind the headlight for any connections that have come adrift or look bad?)
Will have a look in my manual tomorrow as I'm sure there were resistances mentioned for the coil so it may help you rule it in or out of the equation
Regards
Rob |
| alun111 |
 Posted: 01:07 - 14 Jun 2009 Post subject: |
No I haven't checked the fuse.... but surely nothing would work if that had gone (assuming you're talking about the glass one on the positive lead to/from the battery).
I haven't checked for voltage at the coil... should there be 12v when It's been kick started or just when the ignition switch is on?
So you reckon if the points were out of clearance/stuck/burnt etc it could cause it not to spark then?
I will check in the headlight - I was actually going to do that today but forgot!
Cheers, and I hope to hear from you soon with the resistances (and if you could explain how to check for them that would be great too). Thanks again  ____________________ Summer: '00 Honda CB600F Hornet
| baldy |
 baldy World Chat Champion
| robocog |
| alun111 |
| robocog |
 Posted: 16:42 - 14 Jun 2009 Post subject: |
Not clever enough to do multiple attachments in a single post so please forgive my multiple postings
Attached should be the coil test procedures
It must have been the manual for my CJ that quoted the primary and secondary coil resistances so aplologies for suggesting that I may have them
Hopefully the coil test procedure attached will be enough to prove its capable of generating some spark at least
...just looked closely at the diagram I attached earlier and I think I may be taking complete arse about batt voltage on the black/white line with ignition turned on, also the fuse so apologies for throwing a curve ball there
with ignition on and kicking the bike the black and white wire should have "some" voltage, otherwise its the genny thats bust or points being held closed
a close look shows the voltage may even be ac -directly generated by the generator going to the points and on to the coil and the black white wire that goes on to the ignition switch is infact just grounded to "stop" the engine from running when in the off position
Love it..the more I look at it I can't believe how simple the bike is
so a test would be to chuck a bulb onto the back white wire going to the coil and kick like a mad bugger to see if you can get it to flash?
or a multimeter set to ac volts (one lead to black white wire and other to chassis /earth)
....with spark plug out would help things spin over
Once again sorry for the duff info in first postings, should have at least glanced at the wiring diag before assuming it was anything remotely like any other ignition system I had ever seen before |
| robocog |
| robocog |
 Posted: 16:47 - 14 Jun 2009 Post subject: |
I don't seem able to attach any more - perhaps I have hit my quota or something ?
so have popped it on my webserver
https://www.robocog.dyndns.org/cg125/cg125%20coil%20test.jpg
The diagram shows a 6v bulb which I guess relates to the early early CG so if your test battery is 12v I would be inclined to use a 12v bulb
(or a multimeter set to voltage)
Regards
Rob
edited to add I will flip the image the right way up shortly
I'm avin one of those days.. I think I've been out in the sun too long |
| Creepin Moses |
 Posted: 17:16 - 14 Jun 2009 Post subject: |
Hey Rob, I use Photobucket for my attatchments, then on each pic I want to show here I copy the img code for the pic on photobucket and paste it into my msg here. Photobucket is free for making your own photo albums too.
Davey
https://i300.photobucket.com/albums/nn13/HellRider27/DSCF0290.jpg
See what I meen. ____________________ Bomb disposal expert, if you see me runnin, try to keep up. |
| alun111 |
| robocog |
 Posted: 18:05 - 14 Jun 2009 Post subject: |
Maybe
also scanned the genny test diagram and plonked on my server
https://www.robocog.dyndns.org/cg125/genny test.jpg
Unfortunately the manual I have is a bit "iffy" regarding the early 12v brazillians and requires lots of referring to 6v stuff and the genny continuitiy values are not jumping out at me so not sure what resistancy they should be - or it may be that the test as shown is only looking for open circuit issues?
I guess by putting a multimeter to show resistance
one lead going to frame earth and the other to the black/white wire that goes into coil connector
slowly turning engine (by using bolt on flywheel?) should show continuity that is switching between dead short (as good as zero ohms) when the points are closed and some other value (generator coil resistance that is not quoted in my manual) when points open
If the meter is showing dead short all the time when you turn engine over slowly it could well be the points have welded themselves shut?
and if it flicks between dead short and completely open circuit it could be the genny coil is buggered
Good luck and let us know how you get on
The good thing is theres loads of spares for these machines still available and cheap and they are nice and simple to work on
Regards
Rob |
| alun111 |
| robocog |
The last post was made 17 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
