front lights not working nsr 125
wayne1069
PostPosted: 11:14 - 22 Jun 2009    Post subject: front lights not working nsr 125 Reply with quote
for some reason my front lights have stoped working . the rears work ok ...when put ignition on and switch the lights all i have is the highbeam light come on the dash have checked the hi an lo switch looks ok i cant understand there not even side lights ..has any one else had this fault and if so what was the fault
cammy mack
PostPosted: 11:34 - 22 Jun 2009    Post subject: Reply with quote
have you tried changing the bulbs Thinking
wayne1069
PostPosted: 11:48 - 22 Jun 2009    Post subject: Reply with quote
no but have tried disconnecting one at a time to see if there is a short
steo
PostPosted: 13:25 - 22 Jun 2009    Post subject: Reply with quote
take the bulb out & have a look at the filaments inside the glass to see if they're blown, if they are then replace the bulb. if you need to install a new one, make sure it's the proper voltage & amperage for your bike or it could blow again. if the head light does go again then it's maybe more than just a bulb issue.
Polo
PostPosted: 13:37 - 22 Jun 2009    Post subject: Reply with quote
Have you upgraded the bulbs to more powerful ones? I did that and melted the holders.
My mum smells your fingers
wayne1069
PostPosted: 14:06 - 22 Jun 2009    Post subject: Reply with quote
No upgrading of bulbs i think it a wire fault so will have to go into a shop to be repaired
Mr Hammers
PostPosted: 14:39 - 22 Jun 2009    Post subject: Reply with quote
Bit quick to give up on it, aren't you..?! Wiring might seem complicated, but break it down and it really only comes down to a wire going to and from somewhere.
A Guide To Powerbands
wayne1069
PostPosted: 16:56 - 22 Jun 2009    Post subject: Reply with quote
spent a whole day on this not to up on electrics mechanic i am fine , looking at he wiring looks like it been repaired before so it better that i give it to some one who knows about it cause i dont wanna cause any more damage
alains
PostPosted: 17:09 - 22 Jun 2009    Post subject: Reply with quote
look at the connectors fixed somewhere near the bottom yoke or at the light switch on your right handle
salty21
PostPosted: 17:15 - 22 Jun 2009    Post subject: Reply with quote
if someone has already bodged an area of the loom, that would be an ideal place to start, if it were me i would count myself lucky i had a hint of where the problem mighnt be. dont throw in the towel, just have a poke about before you go paying some apprentice to do it for you Laughing
The last post was made 16 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.38 Sec - Server Load: 2.11 - MySQL Queries: 16 - Page Size: 66.59 Kb
