| warped one |
 warped one Banned
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 19:44 - 26 Jun 2009 Post subject: |
Your choice, but it's not something I'd fanyc doing unless you knew what you were doing.
I don't think it would be a good day out if they were to fail mid ride. ____________________ My Flickr |
| warped one |
 warped one Banned
 Posted: 19:48 - 26 Jun 2009 Post subject: |
I see your point there ham, but as a fabricator I can knock these things out, stiffen them, and then fit them.
Should be a doddle
Warped ____________________ amnesia - Never in the history of usernames has one been more accurate. Warped indeed. You sir are a fecking oddball. |
 ---- World Chat Champion
 Posted: 20:13 - 26 Jun 2009 Post subject: |
I made my own out of mild steel for my old GS500 and they were fine.I just used steel the same thickness of the originals
(think i painted mine with hammerite smooth to try and stop the rust)
The original ones were just mild steel anyway. ____________________ DRZ-400sm |
| Pete. |
 Pete. Super Spammer
 Posted: 20:15 - 26 Jun 2009 Post subject: Re: Making your own dog bones. |
| the warped one wrote: | I've gained myself a free shock off, Chriss (cheers mate) and wanting to fit it. Now here is a bit of a problem, my original has a sadle on one end and an eye on the other. the new one, has eyes on both ends, but is the right size and the right price.
Would it be possible to fabricate my own dog bones?
And what would you use?
I'm not sure because-
Mild steel - Easy to use but rusts,
Stainless steel - Harder but more expensive and harder to find,
Aluminium - Very light, but can crack if bent.
Warped |
Make them from mild steel and paint them. Stainless work-hardens when repeatedly flexed and has less tensile strength than steel. Aluminium alloy would work but you need to get the right grade. Cheapest, strongest and least likely to go wrong is steel. ____________________ a.k.a 'Geri'
| warped one |
 warped one Banned
| Blau Zedong |
 Blau Zedong Banned
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 21:00 - 26 Jun 2009 Post subject: |
i had the same problem when fitting a ducati 916 shock to my mito 350.
i made 2 brackets from aluminium, ally MIG welded them to the end of the shock, and compression fitted some hardened steel spigots to the new ''saddle'' to stop it wearing out. you could use TIG if you want it to be a bit neater, but a bit of filing will see MIG looking sweet.
Before (not my sofa thank fuck):
https://img6.imageshack.us/img6/8426/62a01.jpg
after:
https://img522.imageshack.us/img522/823/004fvw.jpg
i removed the bushing from the eyelet and compression fitted a machined sleeve in there to add a bit more support to the weld, then rammed a 12.8 hardened steel bolt through it and tightened it up to something stupid (over 100nm at a guess). if anything, i think its stronger than stock, and with the advantage of if the weld DOES fail, then the back end will drop about 50mm, but wont cause any fatal damage. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
The last post was made 17 years, 109 days ago. Instead of replying here, would creating a new thread be more useful? |
