R6 Stutters and Stalls?
Skynet-T800
PostPosted: 21:54 - 08 Aug 2009    Post subject: R6 Stutters and Stalls? Reply with quote
This has happened a few time now and the bike will be running normal and then at some point the throttle becomes not very responsive and starts to stutter as if its being starved of fuel it will continue to hesitate and then fire off very snappy and isnt smooth at all?
The engine wants to stall and if I pop in the clutch thats what will happen locking the rear wheel.
If I turn the ignition off and back on again its ok for a while?
Any ideas on whats going on its the FI model 04 plate.
I'm thinking its the Throttle Position Sensor??
Gazdaman
I did a trackday!!!
PostPosted: 18:42 - 09 Aug 2009    Post subject: Reply with quote
Blocked fuel tank breather causing a vacuum in the tank? Try opening the petrol cap next time it does it. If that sorts it, that's probably your problem.
Does it do it at all temperatures? Does it take a while to do it, or does it always do it?
Can you turn the bike off, turn it straight back on and it's ok?
Gaz
Skynet-T800
PostPosted: 07:18 - 10 Aug 2009    Post subject: Reply with quote
I've tried the fuel tank opening and thats ok.
If I turn the ignition off and then back on that seems to do the trick for a while.
I've only noticed it when under normal operating temps on A/B Roads where i'm in between 3 and 4th gears when leaning around a corner and when you start to roll on the throttle it hesitates like shit and will fire off not smooth and you get the feeling it wants to stall?
Under hard acceleration nothing wrong with it.
Noxious89123
PostPosted: 10:49 - 10 Aug 2009    Post subject: Reply with quote
What kind of revs? Low down or high up?
Some bikes can have unsmooth fuelling at low RPM and at certain revs where it's leaned out alot for emissions testing.
Is the bike new to you? If not, I assume it hasn't always been like this?
Skynet-T800
PostPosted: 14:40 - 10 Aug 2009    Post subject: Reply with quote
the bikes not new to me so know its a fault.
Mainly noticable around the 6k mark.
I understand about the fuelling issues with bike but this is really noticable after the repair probably fitting a power commander.
Yamaha think it the TPS from what i've said so I might just order the part and hope it's that!
Noxious89123
PostPosted: 14:43 - 10 Aug 2009    Post subject: Reply with quote
Ah ok. Before replacing the TPS, why not check that the connection surfaces in the wiring connector and clean and free of corrosion?
Skynet-T800
PostPosted: 15:07 - 10 Aug 2009    Post subject: Reply with quote
I've no idea where to look so i'll have to dig out the haynes manual.
Noxious89123
PostPosted: 15:59 - 10 Aug 2009    Post subject: Reply with quote
On my bike, it's on the sie of the carbs, so I'd imagine it'd be on the side of the throttle bodies.
The last post was made 16 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 16 - Page Size: 59.8 Kb
