front brake is hissing
d-bug
PostPosted: 19:35 - 23 Aug 2009    Post subject: front brake is hissing Reply with quote
hi the front brake on my bike is hissing when i pull on the leaver ,
would that mean i need to bleed the brake ?
cheers d-bug Very Happy
cagiva mito mk 2 , cagiva mito evo 7 speed
Bikeless
PostPosted: 19:38 - 23 Aug 2009    Post subject: Reply with quote
Check your pads for wear.
Whosthedaddy
PostPosted: 19:43 - 23 Aug 2009    Post subject: Reply with quote
Could be that the brakes just need a damn good clean.
d-bug
PostPosted: 19:49 - 23 Aug 2009    Post subject: Reply with quote
ok cheers guys , but i have just had a look at the pads an its seems 1 is worn down more than the other !?
MattHirst
PostPosted: 21:17 - 23 Aug 2009    Post subject: Reply with quote
Can you explain a little bit more what the noise sounds like, where its coming from?
I ride a DRZ400SM and when i brake hard with the front i can hear a 'hissing', probably more of a whir, thought something was wrong to start with but it seems its just the noise it makes.
It could do with some 'stickier' pads and a bit of a clean but it brakes well enough to do awesome stoppies Razz
d-bug
PostPosted: 08:04 - 24 Aug 2009    Post subject: Reply with quote
well im doin the front wheel bearings today so i will have a look and a bit of a clean then take its out and let u know more about the sound if its still there after a good clean
Noxious89123
PostPosted: 17:53 - 24 Aug 2009    Post subject: Reply with quote
If one pad is wearin more than the other, then the pistons might be stuck in the caliper and need a good clean up to free them! If it's a sliding caliper, i coul be the bolts the caliper slides on are corroded or covered in crap, stopping the caliper moving as it should. Also what bike? A Mito?
Sintered pads make a kind of hissing sound as they rub against the brake disc.
damz
PostPosted: 03:24 - 25 Aug 2009    Post subject: Reply with quote
iirc vented/drilled discs make a hissing sound
Current Bikes RVF400 - 94
Cars: RX7 FD, Eunos Roadster
The last post was made 17 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.57 - MySQL Queries: 16 - Page Size: 57.64 Kb
