| Martay |
 Martay World Chat Champion
 Posted: 16:37 - 25 Aug 2009 Post subject: Loose rear sprocket? |
Hi,
Adjusting the chain on my 125, i noticed the rear sprocket feels loose. The 4 nuts that are holding it on ARE tight, but the studs are moving within the wheel. There is no rotational movement. I tried to video it on my phone if it helps
https://www.youtube.com/watch?v=BAdCJQI4-kE
Is this to reduce shock through transmission, or is something wrong?
Many thanks ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express  |
| mr rip |
 mr rip Scooby Slapper
 Posted: 17:05 - 25 Aug 2009 Post subject: |
That's the cush drive.
The rear sprocket is bolted to the outside of a circular metal casting with a series of segments cast onto the inside face of it (called, imaginatively enough, the sprocket carrier). This slots into gaps in the hub of the rear wheel which are packed with rubber blocks.
As you correctly surmised, this is to give a smoother transfer of power from the engine to the rear wheel.
Worth remembering that the sprocket carrier has a bearing in it in addition to the two rear wheel bearings.
If the play in the cush drive becomes excessive, you either need to replace the rubbers or spaxce them out with slices of inner tube.
Here is a picture of a rear wheel with the sprocket carrier removed.
https://www.wenga.net/ellingly/posties/thumbs/cush_drive_rubbers_mounted.jpg
I do think there is a bit much sideways play in yours though. I wonder if the bearing is ok or if there is a spacer missing between the hub and cush drive or if the wheel nut is a bit loose. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| lukamon |
 lukamon World Chat Champion
its called a "cush drive" different types exist but most common is the one where the holes the sproket bolts go through are rubber blocks, when you open the throttle the slack in the chain is taken up with a jerk, the rubber softens the shock  ____________________ killa wrote: Im an ass man myself |
| Martay |
 Posted: 20:13 - 25 Aug 2009 Post subject: |
Awesome, thanks for the info
Il pop the wheel out and have a peek tommorow.
Thanks again  ____________________ Eat well, poo hard
| veze |
 veze Trackday Trickster
 Posted: 20:31 - 25 Aug 2009 Post subject: |
and as stink wheel says, there is a sprocket carrier bearing in there. it is and idea to check it for sideways play to make sure the bearing is good. i check mine everytime i oil my chain for piece of mind.  ____________________ tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300 |
| sickpup |
 sickpup Old Timer
| bandit |
 bandit Two Stroke Sniffer
| Martay |
 Posted: 11:52 - 26 Aug 2009 Post subject: |
Hi,
Yes there is a large circlip holding the sprocket on.
The bike is 'supposed' to be under warrenty still so il get the bike shop to replace them.
Many thanks for the advice  ____________________ Eat well, poo hard
| sickpup |
 sickpup Old Timer
| binge |
 binge Emo Kiddy
The last post was made 17 years, 22 days ago. Instead of replying here, would creating a new thread be more useful? |
