Fork seals?
BenR
PostPosted: 18:30 - 27 Aug 2009    Post subject: Fork seals? Reply with quote
Hi after buying a set of fork seals for my rg 125 wolf from ebay & finding they didn't fit I went & paid £53 for genuine suzuki items only to now find they don't fit either! Evil or Very Mad Are fork seals generally too big, do you have to heat them up in order to fit them or something? Any help much appreciated. Thumbs Up BTW they're normal RWU forks not USDs (it's been a long time since I changed a set Embarassed )
PostPosted: 19:05 - 27 Aug 2009    Post subject: Reply with quote
You would normally have to drive them into position in the fork legs with a fair degree of force but they should slide over the stanchions fairly easily.
Put PVC tape round the top of the stanchion so you don't damage them as they slide on. A popular way to drive them into place (in the absence of the proper tool) is to use a bit of plastic water pipe that is wider than the stanchion but narrower than the seal. Slide the seal down over the stanchion so it rests against its seat, put the pipe over the top and tap it down with a mallet/block of wood.
serlant
PostPosted: 19:21 - 27 Aug 2009    Post subject: Reply with quote
53 quid fuck mate genuine yamaha ones for the XJ600 with 7 quid each, i didn't have any trouble getting the seals in, the problem I had was getting the top bushing in, so i drove it into place with a piece of pvc pipe as suggested above then used it to seat the seals.
The last post was made 17 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 16 - Page Size: 37.39 Kb
