Cut out, now won't start
Steve-D
PostPosted: 16:39 - 12 Sep 2009    Post subject: Cut out, now won't start Reply with quote
On my way to work today, had done about 4 miles engine fully warmed up. Started to slow down for traffic lights, felt like it lost all power like running on 2/3 cylinders. Stopped at the lights and it just cut straight out. Pushed to the side of the road. Turns overs strongly, fuel in the tank and it [drunk] out of the fuel pipe when I disconected the tank. Checked the middle 2 plugs and they have a spark.
Still won't start.
Also have had a problem from cold with a misfire. Which is down to how much you open the throttle open it slow and steady its fine, whack it open, it misfires. But once the engine is fully warmed up it goes and causes no problems.
Dont suppose its linked in anyway, no idea what causes it, just learned to ride around it.
Any ideas? 99 R6 btw.
www.southwestbikers.com
Blue_SV650S
PostPosted: 16:58 - 12 Sep 2009    Post subject: Reply with quote
Fist thing to do is to test the other 2 cylinders for sparks.
How rapidly does it turn over? If it is with excessive ease, then you might have burnt the valves out ... Shocked
Steve-D
PostPosted: 17:17 - 12 Sep 2009    Post subject: Reply with quote
Checked them now, sparks fine.
Turns over normally doesn't seem faster than usual anyway.
Blue_SV650S
PostPosted: 17:31 - 12 Sep 2009    Post subject: Reply with quote
If you have 4 good sparks, then it isn't the ignition ..
So you are looking at the carbs next.
What is odd is how it won't start at all ... even if one had gone down, I'd expect it to run on 3 ... for all 4 carbs to go down at once is hard to believe.
Anyhoo, is it possible the carbs have come out of the inlet rubbers???
I think the next step is to go in and have a look at the carbs anyway ...
Steve-D
PostPosted: 17:36 - 12 Sep 2009    Post subject: Reply with quote
Yep, just sprayed petrol down the carbs where it joins the airbox, and it started, breifly. Rang a mate and he think its blocked jets.
Blue_SV650S
PostPosted: 17:38 - 12 Sep 2009    Post subject: Reply with quote
In ALL 4 carbs at once??? .... not convinced ...
But you need to get into the carbs and have a looksee either way, so you will soon find out!!! Smile
yuri2085
PostPosted: 18:31 - 12 Sep 2009    Post subject: Reply with quote
Were you running on reserve for the first time in a while?
Steve-D
PostPosted: 19:57 - 12 Sep 2009    Post subject: Reply with quote
Doesn't have a reserve just a fuel light.
Sorted now fuel pump was nackered, one off my kawasaki zx4 fits though so will do for a temporary fix until I can order a new one.
Cheers Thumbs Up
Blue_SV650S
PostPosted: 20:02 - 12 Sep 2009    Post subject: Reply with quote
Cheers Thumbs Up
Thought you said it was "sucking fuel"?? ... still at least it is sorted now!! Thumbs Up
The last post was made 17 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.49 - MySQL Queries: 16 - Page Size: 64.14 Kb
