Is this gap between my seat and fairing meant to be there?
oJaXo
PostPosted: 18:31 - 13 Sep 2009    Post subject: Is this gap between my seat and fairing meant to be there? Reply with quote
just noticed it today and thought it looked abit odd,
any of you guys know if its meant to be there or something?
Cheers
https://i250.photobucket.com/albums/gg276/oJaXo/P9120043.jpg
Timmeh
PostPosted: 19:23 - 13 Sep 2009    Post subject: Reply with quote
At a glance, I'd have to say that's wrong, as the rear fairing should fit flush to the bottom of the seat.
Whosthedaddy
PostPosted: 19:53 - 13 Sep 2009    Post subject: Reply with quote
From grab rails or maybe hard luggage rack (as in base for top box)?
oJaXo
PostPosted: 20:19 - 13 Sep 2009    Post subject: Reply with quote
hmm, so is there a part missing where that gap should be or something like that?
PostPosted: 21:08 - 13 Sep 2009    Post subject: Reply with quote
Doesn't look like there is a part missing. It looks more like your seat isn't fitted properly.
oJaXo
PostPosted: 21:19 - 13 Sep 2009    Post subject: Reply with quote
oh right,
do you know how i could check if its fitted properly?
RudiRulez
PostPosted: 21:28 - 13 Sep 2009    Post subject: Reply with quote
search for some pics of your bike on google to see if its just yours or not.
oJaXo
PostPosted: 22:08 - 13 Sep 2009    Post subject: Reply with quote
good idea, il have a look but i might try and just find someone else with a 250 hornet and ask them
PostPosted: 08:10 - 14 Sep 2009    Post subject: Reply with quote
https://www.hondahornet.co.uk/250spec.html
im half asleep and cant see it all that well, but you might find its just like that mate..
Bat
PostPosted: 10:04 - 14 Sep 2009    Post subject: Reply with quote
Have you tried popping the seat off and refitting it?
PostPosted: 11:24 - 14 Sep 2009    Post subject: Reply with quote
That would be my suggestion too...
truslack
PostPosted: 14:14 - 14 Sep 2009    Post subject: Reply with quote
Could try PMing "DS55", he has a hornet 250.
Alexio
PostPosted: 14:21 - 14 Sep 2009    Post subject: Reply with quote
If you don't yet know how it's always a good idea to learn how to take your seat on and off. When you put it back on hopefully it will all just go on flush as it's meant to.
Bendy
Mrs Sensible
PostPosted: 14:40 - 14 Sep 2009    Post subject: Reply with quote
Or the rear fairing might not be on properly, thus not coming up to meet the seat.
Take the seat off, make sure the fairing's screwed on everywhere it's meant to be and then stick the seat back on.
oJaXo
PostPosted: 14:54 - 14 Sep 2009    Post subject: Reply with quote
thanks for the help guys
just looked on the hornet site and think it might be for the hooks that swivel out under the seat to fit through that gap?
but i still think it doesn't look right
will take the seat off and look at how the fairings fitted and see if i can find anything wrong tonight
cheers
Noxious89123
PostPosted: 20:06 - 15 Sep 2009    Post subject: Reply with quote
Do you mean the gap that runs all the way along, or just the little cut-out in the middle?
The cutout in the middle has a metal hook behind it, to hang your helmet from. You can then put the seat back on and it effectively locks you helmet on the bike.
If you mean the gap all he way along, then could just be that your seat isn't quite on properly. I have a gap, but probably only 1/2 that size. Does your seat bar it's weight on the subframe by little rubber blocks under the seat? Could be that the gap closes up a bit with the weight of a person on it...
oJaXo
PostPosted: 20:52 - 15 Sep 2009    Post subject: Reply with quote
thanks for the replies Thumbs Up
took the rear fairing off and nothing seems to be wrong with that all bolts and fixings on in the right places and everything.
did try to see if the seat would fit on any other different ways but couldnt see how it would, will have another go tommorow to see if anything is in the way of it closing or something silly like that lol
cheers
Bat
PostPosted: 08:26 - 16 Sep 2009    Post subject: Reply with quote
I could well be wrong, but if it's anything like the seat on the Hornet 900 I had, it looks like it might just need a good hard shove into place.
the grim reaper
PostPosted: 12:32 - 17 Sep 2009    Post subject: Reply with quote
Just a thought, do you have loads of crap under the seat and does the seat clikc into place with out pushing down on it. If the answers to those questions are 'no' and 'yes', then it is probably meant to be like that. Maybe also worth checking that the side panel is fitted correctly, loosen the bolts and see if it pops into place.
Cheers
Grim
oJaXo
PostPosted: 14:50 - 17 Sep 2009    Post subject: Reply with quote
never thought of that,
thanks for the help, will have a jiggle about on it later again Thumbs Up
The last post was made 16 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.73 - MySQL Queries: 16 - Page Size: 108 Kb
