20,000 mile service
eddclarke
PostPosted: 19:26 - 14 Sep 2009    Post subject: 20,000 mile service Reply with quote
Does anyone have a rough price for a 20,000 mile service on a 05 Yamaha FZ6, I think its due to have the valves adjusted, as it is starting to make a slight ticking noise.
Thanks
Ed
Honda XR125L 06 ----> Yamaha FZ6 05 + ex SAS XR250 --> VFR800 + XR250r
Dalemac
PostPosted: 02:46 - 15 Sep 2009    Post subject: Reply with quote
Depends where you take it! tbh i would do it all myself, valves arent hard to do if you have the tools!
Dale
YBR125 -> GPZ500S -> SL1000
J D
PostPosted: 07:16 - 15 Sep 2009    Post subject: Reply with quote
Mine cost about 400 quid but the place i took it to are robbing bastards (Pro bike)
Peter3hg
PostPosted: 11:21 - 15 Sep 2009    Post subject: Reply with quote
The service is supposed to be at 24,000 miles, not 20,000.
Handsome
PostPosted: 12:03 - 15 Sep 2009    Post subject: Reply with quote
Bilston ?...
temeluchus
PostPosted: 15:50 - 15 Sep 2009    Post subject: Reply with quote
300 quid ish to get the shims looked at. Also depends on how many shims need to be replaced and not exchanged.
The rest is easy enough to do yourself.
the grim reaper
PostPosted: 16:05 - 15 Sep 2009    Post subject: Reply with quote
Valve clearances are every 42k Kilometers, so 26,250 miles. The actualt check is so easy to do, rocker cover off, remove blanking plate to turn engine over and remove spark plugs. A set of feeler guages and away you go.
If you're paying someone else to do it, it shouldn't cost more than £200 tops, unless you're getting other things done at the same time. Also ask for the old shims, if they replace any.
Grim
J D
PostPosted: 00:15 - 17 Sep 2009    Post subject: Reply with quote
NSR-AD wrote:
Bilston ?...
Newbury, fuckers broke my indicators as well Mad
temeluchus
PostPosted: 11:09 - 17 Sep 2009    Post subject: Reply with quote
Its shim under bucket so the cams have to come out and the head but be partially disassembled so its not that easy unfortunately.
the grim reaper
PostPosted: 11:36 - 17 Sep 2009    Post subject: Reply with quote
Unless I'm missing something, surely the clearances can be checked without dismantling the engine and removing the cams??
Grim
temeluchus
PostPosted: 17:03 - 17 Sep 2009    Post subject: Reply with quote
Why is everyone on this forum such snotty bastards Wink
Sorry yes check.... You dont need to dismantle the head but even if one shim has to be changed then the lot has to come off.
The last post was made 17 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 3.68 - MySQL Queries: 16 - Page Size: 71.32 Kb
