Gilera DNA 125 won't start
gilera125
PostPosted: 17:40 - 01 Oct 2009    Post subject: Gilera DNA 125 won't start Reply with quote
The engine turnsover, but the carb won't take in fuel, i tried puting fuel directly in the carb still nothing. No oil in the engine because just bought and courior requires seller to take oil out. Don't want to put oil incase the engine will not start anyway. The spark plug does give a spark (tried dipping in petrol and not starting).
WON'T START
robbobnob
PostPosted: 20:08 - 01 Oct 2009    Post subject: Reply with quote
LOL! that's all.
ryhardcastle
PostPosted: 20:34 - 01 Oct 2009    Post subject: Reply with quote
Rolling Eyes
dlatch
PostPosted: 17:43 - 02 Oct 2009    Post subject: Reply with quote
fill engine with oil before u do anything even cheap stuff won't cost much
then take carb off and check float has not got stuck in transit which would stop fuel getting in
if u pour petrol in it will never start as it will just foul the spark plug instantly.
funmonkee
PostPosted: 21:49 - 02 Oct 2009    Post subject: Reply with quote
Are you try to start and engine with no oil in it Question
I would advise again that Karma
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
prawny1
PostPosted: 16:56 - 03 Oct 2009    Post subject: Reply with quote
firstly fill the engine with oil (it only takes about a litre any way) then check that the kill switch is on and that the petrol and vacuum tap hoses are on and not leaking,
turn the engine over a few times and check if the fuel is getting into the carb from the tank by undoing the drail plug at the bottom of the carb, If fuel comes out but it still won't start then the next step would be to check for a spark,
If you have a spark at the lead when checked using a spare plug check that the plug in the engine is sparking and is not wet with petrol,
If the plug is wet replace it with your new spare plug and try again (best to replace it anyway even if it was dry), if the plug was dry then try spraying easy start or carb cleaner into the carb If it fires up then the carb probably wants cleaning.
If your still having problems try using both keys as the immobiliser may have reset itself, there is a sticky section at the top of the workshop somewhere that I posted links to scooter immobiliser codes and reseting precedures ages ago.
found the link here you go https://www.wotmeworry.org.uk/manuals/
If still no luck then checking the valve clearences is always favorite on those leader engines when they get hard to start as they do like to tighten up.
The last post was made 16 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.38 - MySQL Queries: 16 - Page Size: 49.88 Kb
