jetting after fitting pod filters
squishio
PostPosted: 11:38 - 05 Oct 2009    Post subject: jetting after fitting pod filters Reply with quote
Hi All
Hoping someone can give me a rough estimate of what changes regarding jet sizes I need to make after fitting pod filters to my bike.
Bike - Kawasaki GPZ400R ('83)
Filters - K&N pod's
I'm about to place an order for a load of jets for another bike and thought I might as well get what I need for this one whilst I'm at it.
I don't know what is currently in there but I'm pretty sure it is on it's original jetting so with these filters I imagine it will run very lean as intake will be massively increased over the standard airbox. I haven't had it running (far from it at the moment) but need to get prepared.
So from other peoples experience what kind of jump will I need to make for jet sizing? I'm happy to order a few jets to be safe but just a estimate would be good!
Cheers!
Rich
Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250
temeluchus
PostPosted: 12:44 - 05 Oct 2009    Post subject: Reply with quote
A good rule of thumb is to go up 25% in jet size (ie if you have 90 stock go to 112.5).
depending on the bike you may need to go up more OR it may be less-oh the fun of jetting!
form the manual stock you have 102.5 so in the region of 125-127.5 is a starting point
squishio
PostPosted: 13:19 - 05 Oct 2009    Post subject: Reply with quote
Cool, very helpfull Thumbs Up
I assume pilots will need doing as well, correct?
will the needles need changing or am I good just with the pilot and main?
temeluchus
PostPosted: 15:05 - 05 Oct 2009    Post subject: Reply with quote
you may need to go up 1 or 2 sizes pilots, but often you can just open the idle screw by a bit for it to run right.
Ideally you'd want a new needle, but they aren't easy nor cheap to obtain and satisfactory results can be obtained with the stock needle usually.
prawny1
PostPosted: 21:00 - 05 Oct 2009    Post subject: Reply with quote
https://scootrs.com/tech.cfm?tip=tunecarb
this article is pretty informative for carb tuning, it is more for two smokes but gives you a pretty good idea of what to look for when setting things up.
The last post was made 16 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.42 - MySQL Queries: 16 - Page Size: 46.47 Kb
