Bike Cover
Mark65
PostPosted: 19:28 - 17 Oct 2009    Post subject: Bike Cover Reply with quote
Opinions pls
Motorax Tyvek or this one from argos which seems to have good reviews.
https://www.argos.co.uk/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&catalogId=1500001801&productId=1500510849&langId=-1&engine=froogle&keyword=Deluxe+Motorcycle+Cover&_$ja=tsid:11527%7Ccc:%7Cprd:7400311%7Ccat:Motorcycle+Accessories
Thnx
Mark
Whosthedaddy
PostPosted: 19:32 - 17 Oct 2009    Post subject: Reply with quote
Just be aware that in constant use some paint on the extremities may eventually rub off.
A cover is only there to keep the severe wet, rain and snow off but also needs to breathe to prevent moisture accumulating and causing more problems.
God bless the garage!
Mark65
PostPosted: 19:36 - 17 Oct 2009    Post subject: Reply with quote
I have a garage its just for the day when i get to work as i cant use the warehouse to store it any more.
Mark
Whosthedaddy
PostPosted: 19:39 - 17 Oct 2009    Post subject: Reply with quote
I did think about a cheap cover when at work as its in the open but, after nearly an hour commute the engine and twin exhausts are pretty damn hot and would probably melt a cheap one.
willis1337
PostPosted: 19:46 - 17 Oct 2009    Post subject: Reply with quote
Depends what you want it for. The one you've selected is okay but its v thin and will let the worst weather in. I would say get this if you just want a quick cover for your bike which you would leave exposed to the elements anyway, or as a dust cover in a garage.
Alternatively if you have no garage but want a cover that weill keep out all weathers, protect the bike and is a pretty good bit of security kit too (provided you put your locks through the holes meant for them) then get an Oxford Stormex cover. THese will cost you £60 but they fit the bike well - I have a large for a gsxr1000 and its perfect, great protection, the bike is kept outside all the time - this keeps off everything. Also I can put it straight on while the exausts are hot (it's sheilded where necessary), you couldn't do that with the other cover, it'd melt. Basically its a blanket / quilt compared with a polythene sheet.
nasty
PostPosted: 20:37 - 17 Oct 2009    Post subject: Reply with quote
Don't even bother with the Argos one as they're not "Waterproof", they're only shower proof, any serious rain and it just soaks through - I've gone through 2 of them.
The Oxford Stormex is great, that's my next cover Thumbs Up
At the moment though I use a MotoGP rain cover which is a very good fit and IS waterproof Thumbs Up
https://www.mandp.co.uk/productinfo/566795/Bike-Care/Bike-covers/MotoGP
ZX6R F3
Throttle
PostPosted: 20:46 - 17 Oct 2009    Post subject: Reply with quote
I used this cover on my CG. I have no garage so just left this on all year round. Worked a treat for me and kept the bike nice and clean. Never had problems with rain getting in, was a nice cheap solution for me at the time.
Mark65
PostPosted: 10:13 - 18 Oct 2009    Post subject: Reply with quote
I can pick up a DuPont Tyvek cover for £15
I would like one of the good ones but its a bit steep price wise, i had my seat off and side panels and soaked everything in ACF 50 that was exposed. plus its a rough area i work in and if they cant get my bike they would prolly take the cover.
So really its the tyvek or the argows one at this price i think.
Breathable Bike Cover Tyvek
Tyvek Breathable
Dries the bike
· TYVEK® is made from 100% high density polyethylene (HDPE)
· Made from environmently friendly material, incorporating advanced technologies specifically aimed at reducing wastage, preserving precious resources, and safeguarding nature
· TYVEK® is water resistant to a water column of 220cm
· Seams are made from a special thread which expands in humid conditions
· TYVEK® TopCover® is highly resistant against tearing and is extremely light
· Our covers weigh on average only 200g each
· Reflects up to 83% of the solar spectrum
· Uneffected by most chemicals, TYVEK® is highly repellent and it is excellent at keeping small particles like dust, sand, pollen and pollution away from the vehicle surface
map
Mr Calendar
PostPosted: 13:53 - 18 Oct 2009    Post subject: Reply with quote
Once upon a time I had the Hein Gericke Tyvek cover.
It was damn good with one flaw.
That was when used extensively (bike parked outside for 6 months) it becomes very fragile and rips easily. Ended up almost covered in Duct tape to hold it together, inside and out. At which point I gave up and replaced it.
Just my thoughts.
map
Mr Calendar
PostPosted: 14:53 - 18 Oct 2009    Post subject: Reply with quote
On the basis I needed a spare got the Argus one for convenience.
These are the warnings.
1. Never allow your cover to come into contact witha hot exhaust or engine
2. Do not cover a wet motorcycle, always allow to dry before using the cover.
3. Never store your motorcycle in string direct sunlight when using this cover.
4. Do not use this cover on a motorcycle that has been resprayed during the previous 3 months.
5. Do not cover your motorcycle for longer than 3 days without removing it to check for condensation or water and allow to dry. Ensure your motorcycle is dry before replacing the cover.
6. This cover is not designed to protect your motorcycle from sunlight exposure to UV. Tays can cause the material to degrade.
7. Do not use this cover on vintage/classic motorcycles.
So on the basis of the above I'd go with the breathable cover for the same money. If you tell me where from I'll get one too Very Happy
HTH Thumbs Up
The last post was made 16 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.54 - MySQL Queries: 16 - Page Size: 75.81 Kb
