Dirt gurus - a question?
Imonster
PostPosted: 12:39 - 24 Oct 2009    Post subject: Dirt gurus - a question? Reply with quote
Tomorrow I'll be laning on my lady's bike - as it has been chucking it down I want to be running low pressures. On mine I'd probably run 8 in the back and 10 in the front, but I've got rimlocks, hers doesn't.
What do you reckon the lowest pressures I can get away with are? Having ripped the valve off her bikes front tube last week, I'm keen to avoid a repeat performance.
It's a light bike (Serow), if that makes a difference.
Ta muchly...
Those who make peaceful revolution impossible will make violent revolution inevitable.
yen_powell
PostPosted: 13:23 - 24 Oct 2009    Post subject: Reply with quote
I used to run 15psi on my DR350 with no rimlocks with no problem, probably could've gone a little lower. That was on MT21s.
XT1200Z and a DR350 in bits
colin1
Captain Safety
PostPosted: 14:25 - 24 Oct 2009    Post subject: Reply with quote
I've got a ttr250, which is basically a slightly bigger serow.
I've ridden it with flat tyres for a few miles without problems. Running with low pressures, defintely gives better traction for off road. Particularly the back wheel, on terrain where you would otherwise be spinning the back wheel, it just bites in.
I'm not knowledgable about these things, just talking about my experience.
I don't know what a rim lock is, so please tell me.
Imonster
PostPosted: 14:26 - 24 Oct 2009    Post subject: Reply with quote
Cool, cheers. Maybe go conservative option to avoid breaking her bike again tomorrow, and run at 16 rear, 18 front?
Imonster
PostPosted: 14:41 - 24 Oct 2009    Post subject: Reply with quote
My bike is a 95 TTR 250 Very Happy But sadly needs a service, hence stealing the Doris' tomorrow.
I know very little about rimlocks too - all I know is that without them I used to get loads of punctures, and now I don't. So far as I understand, they stop the tire spinning on the rim when things get slippy, you don't rip the valve out the tube. You can also run lower pressures with them in, giving you a little more grip when things get slippy.
They're not very expensive, and when installed it just looks like the tyre has two valves.
Like I say, not an expert by any means, but would recommend them purely because IME I get less flats than I did before I had them installed Smile
PostPosted: 15:05 - 24 Oct 2009    Post subject: Reply with quote
Yes, wouldn't really go much below 15psi or so without rimlocks, especially if it's got fairly knobbly tyres. Obviously can get away with a bit less on tyres that are quite road-biased, as they'll tend not to grip so much anyway.
As above, the rimlock basically clamps the tyre onto the wheel. Worth having if you're serious about off-roading.
Without them, the tyre can grip, but with little pressure in the tube holding the tyre onto the wheel, the wheel can spin inside it, ripping the valve off the innertube.
Running a very low pressure tyre (under 8psi) can cause pinch flats. Rockier terrain and more pressure needed. There's various ways to convery rims to tubless, but they're all a bit of hassle. The tubliss system I've got is quite good that it also acts as a big rimlock too.
Tonka
PostPosted: 18:22 - 24 Oct 2009    Post subject: Reply with quote
I've been running 15/18 on my little Honda, if that's at all relelvant to your situation.
I will be reducing this as it gets wetter, but was looking at 10/12 minimum.
Quote Me Happy
PostPosted: 18:27 - 24 Oct 2009    Post subject: Reply with quote
What would you go down to with rimlocks? Just out of interest.
Tonka
PostPosted: 18:45 - 24 Oct 2009    Post subject: Reply with quote
Not actually ridden a winter but have been advised that at a push go to 8 but staying in double figures is preferable.
I guess it's going to be a case of trial and error as the bike size, rider size and conditons all have such a big bearing.
EDIT: On extra thick tubes now
PostPosted: 19:28 - 24 Oct 2009    Post subject: Reply with quote
I reckon my rear must have been about 5psi on the 690 in a particularly 'gnarly' rocky section in spain at one point - but this is with the tubliss that means no tube and uber-rimlock. Pretty sure it would have caused some pinch flats if I didn't have it. 8psi is about the minimum with a heavy duty tube.
Wouldn't go much below 15 without rimlocks - if you remember my first dirt ride on the 690, that 'puncture' was due to the valve getting pulled because the (pretty road biased) tyre was at too low pressure without a rimlock. Luckily it only just stretched the rubber too much, rather than ripping it off.
S
PostPosted: 11:45 - 27 Oct 2009    Post subject: Reply with quote
I thought I knew but I checked online for a definition:
Rim locks are used to prevent tires from slipping around motorcycle rims. They are primarily used on off-road bikes and/or any application using low tire pressure for enhancing off-road traction. Aggressive off-road tires or under-inflated tires are prone to slipping on the rim under hard acceleration or braking. In such cases, a rim lock saves the inner tube’s valve stem from damage.
The last post was made 16 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 16 - Page Size: 71.74 Kb
