GSXR Front Sprocket
banksy
PostPosted: 12:21 - 04 Nov 2009    Post subject: GSXR Front Sprocket Reply with quote
GSXR 600 K3
OK trying to remove front sprocket.
need help!
https://img402.imageshack.us/img402/7123/cimg3880.jpg
Basically theres the nut that holds the sprocket, a speed sensor rotor and an allen bold that holds the rotor on. The allen bolt had rounded off so I took to the angle grinder. The speed rotor has almost dissappeared and thankfully I managed to get the hole of the allan bolt off. The nut is fine and I'm trying as hard as I can with a huge breaker bar to undo it but it wont budge.
Im sitting on the bike with the brakes on and also using a penetrating spray but no joy.
Im worried its welded itself to something? Also now the front of the bit that the nut screws onto is looking a bit mashed.
Any ideas?
Thanks!
banksy
-CG125 07- -GS500F 04- -CBR600 98- -FJ1200 86- -XT350 91- -CBR900RR 01-
lonner
PostPosted: 16:32 - 04 Nov 2009    Post subject: Reply with quote
you need to put a piece of wood or a bar through the rear wheel to lock it.
then a longer bar and some one to hole the bike so it doesn't fall over
these nuts get incredibly tight god luck.
or pop down to a tyre place or garage for an air socket wrench to remove it
hth
PostPosted: 16:50 - 04 Nov 2009    Post subject: Reply with quote
Impact driver. Thumbs Up
Quote Me Happy
PostPosted: 16:58 - 04 Nov 2009    Post subject: Reply with quote
Defintely an impact gun, either air or electrically powered.
Ride it round to a local mechanic type place and ask them to crack it loose with their gun. Do it back up tight with your hand tools and ride it home (a bit gently) and undo it again.
banksy
PostPosted: 16:59 - 04 Nov 2009    Post subject: Reply with quote
I tried a broom through the wheel which stopped the bike moving, but all my weight on the bar did nothing. I spend literally all day looking on the web and found a source that says Suzuki use a gallon of locktite there and a blowtorch will loosen it up. I was going to try this earlier but was scared about all the grease and oil catching on fire.
I burned the bastard to hell and it didnt take much before it loosened up. Luckily all the threads are ok its just the end of the thing that holds the sprocket looks a little mashed.
I need to invest in an impact wrench though
banksy
el_oso
PostPosted: 19:06 - 04 Nov 2009    Post subject: Reply with quote
impact wrenches are cool. but not sure how much damage you have done to the nut.
scaffold pole works really well. you would be surprised how tight these things get. So far i have been fairly lucky but have heard some real horror stories.
if all else fails and you want to give up drill a line of holes in a line and split the bolt off
Duke 390
Car: Jeep Wrangler 4.0L
sickpup
Old Timer
PostPosted: 21:11 - 04 Nov 2009    Post subject: Reply with quote
Oh my fucking god!
Seriously if you did that damage to the nut and shaft stop now and let a bike shop try and sort the mess you have caused. If you're lucky they might be able to save the shaft.
That is a replacement sprocket not the original.
MaybeGuy
PostPosted: 21:30 - 04 Nov 2009    Post subject: Reply with quote
lol @ all of the above.
why did you need to take it off anyway? it looks fine.
Towton 1461
PostPosted: 01:39 - 05 Nov 2009    Post subject: Reply with quote
Crying or Very sad
This post is sponsored by QUILLIES LOZENGES. Suck QUILLIES for fast throat relief!
Quote Me Happy
PostPosted: 07:00 - 05 Nov 2009    Post subject: Reply with quote
Jeebus, just seen the pic (work blocks image hosting sites). An angle grinder should have been a last resort. I didn't realise you had done that to it.
I think it's time to let someone else have a look at it.
Noxious89123
PostPosted: 23:01 - 05 Nov 2009    Post subject: Re: GSXR Front Sprocket Reply with quote
Laughing Overkill much? Why not cut a slot in it and use a screwdriver, or try a pair of molegrips?
Unless you know what your fucking with, keep the hell away from destrutive tools like angle grinders!
The last post was made 16 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.37 - MySQL Queries: 16 - Page Size: 77.62 Kb
