| spitfire123 |
 spitfire123 Could Be A Chat Bot
 Posted: 14:49 - 11 Nov 2009 Post subject: Running pre-mix. do i need to upjet? |
hi all,
want to run pre-mox on my cagiva mito as i just dont trust the feble oil pump.
Now ive heard someone before that if you dont run injector and go on to pre-mix you have to upjet the carb?
if se do u upjet it by 5 or somthing, and run a 50:1 ratio?
sick of heat ceizure and the oil pump failing.
cheers  ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| Blau Zedong |
 Blau Zedong Banned
 Posted: 14:58 - 11 Nov 2009 Post subject: Re: Running pre-mix. do i need to upjet? |
| spitfire123 wrote: | hi all,
cheers  |
The pump is the same Mikuni one Suzuki have used for years so it should work OK (usually they either pump or not). If you do go premix you'll have to remove the pump, block off the oil point at the carb and then upjet (also possibly up the pilot jet too). ____________________ 18:54:48 Rob Fzs: jews don't give away stuff for free
18:54:59 Rob Fzs: unless its their clothes/ hair/ golden teeth |
| ms51ves3 |
 ms51ves3 Super Spammer
 Posted: 16:21 - 11 Nov 2009 Post subject: |
Not so sure. Oil will add to the viscosity of the fuel and change how it flows (although probably not that important). However main jets are marked in different ways. Sometimes by flow (in which case your calculation is probably right) and sometimes by diameter (in which case your calculation would mean a 6~7% larger main jet to make up for the 3% oil).
| MarJay |
 MarJay But it's British!
| spitfire123 |
| MarJay |
| Blue_SV650S |
| spitfire123 |
| spitfire123 |
| MaybeGuy |
 MaybeGuy Super Spammer
| spitfire123 |
| spitfire123 |
| spitfire123 |
| MaybeGuy |
 Posted: 19:35 - 12 Nov 2009 Post subject: |
cagiva mito carbs are for cagiva mitos ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Blue_SV650S |
 Posted: 19:53 - 12 Nov 2009 Post subject: |
Wow Spitfire123, have you porked Buddy's missus or smmin?!?  ____________________ The purpose of life is to fight maturity. |
| spitfire123 |
| spitfire123 |
| spitfire123 |
| spitfire123 |
The last post was made 16 years, 270 days ago. Instead of replying here, would creating a new thread be more useful? |
