| daytona55 |
 daytona55 Two Stroke Sniffer
| G |
 G The Voice of Reason
| Pie-Roe |
 Pie-Roe World Chat Champion
 Posted: 20:56 - 19 Nov 2009 Post subject: |
Full acerbis plastics for 67 quid on ebay. Everything apart from mudguards.
Pyro ____________________ Previous: GSF600, FZR600 x2, ZXR750, XT600 Tenere, CB125, CZ125, ETZ 250, ER5, CCM R30, DRZ400, RF600x4, RF900x2, GS500, VTR1000F, 640 SMC, CB250 NIGHTHAWK, GT550x3, GPX750 TE610, CB500, X11x2, SV650, ZING 125, TL1000R,CB250 Superdream, CBR1100XX |
| daytona55 |
| Itchy |
 Itchy Super Spammer
| Dom |
 Dom World Chat Champion
 Posted: 17:34 - 22 Nov 2009 Post subject: |
If you get the E make sure the electrics are okay. The light on mine had a habit of deciding not to work from time to time, and it would blow fuses for fun every now and then too. Try flicking the ignition on and off a few times, ditto the lights, and generally abuse it as much as possible on the test ride to make sure it's not a shitter. It's a Suzuki, so watch out for the build quality. Check everywhere for oil leaks, but in particular the output shaft (i.e. behind the front sprocket) as the seal there is prone to going and it's a bastard of a job to do if the old one has really fallen apart (mine had, naturally).
Get one with as little use and as few past owners as possible. Mileage doesn't really matter but where it's been done does. Aim for one that's only had light green lane use, ideally. As has been mentioned, some cosmetic damage is a given.
The E model is lighter and more powerful. It's the one you buy if you want to ride off road. It has a different carb to the normal bike.
Itchy, not everyone's going to Siberia. Get over this compression obsession already. ____________________ Photos and that |
| Itchy |
 Itchy Super Spammer
| tony_d123 |
 tony_d123 Nitrous Nuisance
 Posted: 18:55 - 27 Nov 2009 Post subject: |
A standard 400E runs fine on normal unleaded (95 ron). I had one for 3 years and they are good, generally reliable bikes and lots of spares available.
Are you going to ride it on the road or trail? The 400E will do both but electrics are very basic for the road and no pillion pegs etc. The DRZ's you have seen with digital speedos are probably all the 400S model. The 400E did not come with a speedo, indicators or brake light as standard, so most have been added later. The 400S is more road orientated but heavier, metal tank, slightly lower engine tune etc. The specs have not really changed since they were introduced in 2000 apart from graphics. The 400E was dropped in 2007 but reintroduced last year!
The only weakness (apart from the usual suspects) is the output shaft collar and oil seal. If it has been looked after, the owner will have changed the collar for a stainless one and new seal. If left they tend to go suddenly and dump all their oil, I have seen it happen miles from anywhere! I got my stainless collar off eBay and the seal from the local dealer, not very expensive.
As someone has already said, a full set of plastics can be had for less than £100 so aesthetics are not a deal-breaker. If you are going to ride it properly for trail riding, you don't want a nice shiny bike anyway.  |
| MattHirst |
 MattHirst World Chat Champion
 Posted: 21:36 - 27 Nov 2009 Post subject: |
The output shaft seal (known as the counter shaft when talking DRZ's for some reason) doesn't just 'fail' on its own. What happens is, where the front sprocket sits on the splines, it has to much 'free play'. So when drive is enganged, the sprocket slips on the splines a little, loosening the big ass nut and allows the shaft to 'slide' (floating shaft). This rags the fuck out of your seal allowing oil to go everywhere (including your rear tyre, not nice mid corner at 60!).
If left to long like this, it knackers you're 2nd gear bush. To test the bushing has gone, lift the rear wheel (paddock stand etc) and spin it in neutral, if it feels lumpy and tight then your 2nd gear bushing has gone. Obviously there will be some resistance but it will be obvious if it has gone.
Common fix is the 'loctite fix', you basically put a few drops of loctite on each spline and then put the sprocket on, removes the free play on the sprocket/splines.
Another problem to look out for is the ACCT failing, causing your cam chain to skip on the cam shaft sprockets dumping a few valves into your piston!
There is nothing else that really goes wrong with them. The headlight problem is just the plug on the back of the bulb vibrating off, nothing abit of blue-tack can't handle
ThumperTalk is your friend! ____________________ It's all fun and games until someone gets hurt, then it's bloody hilarious!!! |
| tony_d123 |
| MattHirst |
 Posted: 14:40 - 28 Nov 2009 Post subject: |
Oh sorry, i have only been a victim of the CS problem twice
As for the ACCT, it was redesigned around 2002/3 if i remember rightly which vastly reduce the number of which failed but it still happens. A MCCT can be picked up off ebay for around £25-£30 (or from america for around $30)
The nut coming loose isn't part of normal maintanace, it shouldn't come loose, period. The tab washer stops it actually coming off but it still comes loose enough to allow the shaft to move ____________________ It's all fun and games until someone gets hurt, then it's bloody hilarious!!! |
| tony_d123 |
| MattHirst |
 Posted: 20:36 - 29 Nov 2009 Post subject: |
I'll let you off then
Apart from the intitial oil pissing out everywhere problem mine has been bullet proof (only reason it happened again is due to the dealer's shitness).
It was done under warranty, even though they insisted that i just let it run dry, they wouldn't listen to the fact that it pissed out everywhere!. Despite there being oil all over the rear tyre, wheel, swingarm and photos of the corner that it happened...cock knockers!
Got a full top end rebuild out of it though, luckily the 2nd time it happened i stopped within about 20 yards so didn't damage the engine (well, we don't think). Turns out they stripped the front sprocket nut (threads) when putting it all back together. A new nut and tab washer and all is good
Anyway, back on topic. I wouldn't hesitate to have another DRZ if it wasn't for the simple lack of power (i ride with sports bikes so keeping up in fast bits can be an issue). 470 stroker with FCR MX? YES PLEASE  ____________________ It's all fun and games until someone gets hurt, then it's bloody hilarious!!! |
The last post was made 16 years, 290 days ago. Instead of replying here, would creating a new thread be more useful? |
