| T0MMY |
 T0MMY World Chat Champion
 Posted: 13:44 - 03 Dec 2009 Post subject: XT350 advice/ possibly for sale in cambs. |
I haven't ridden my XT350 in a few months now as I damaged the ligaments in my right knee playing rugby which meant I couldn't start it (and even if I could I couldn't ride off road).
Thing is I'm considering selling it now but I can't get it to start I'm not sure if it actually has a problem or if I just can't kick it over long enough or hard enough to go but either way it always used to fire first kick hot or cold. Any ideas how I can get it starting this easily again? I've cleaned out the carbs, changed the spark plug and fitted a new ignition coil so far. I can't bump start it because the knobblies don't grip enough even in top gear
The other possibility is that i sell it as a non-runner but I'm not sure what I'd get for it like that? ____________________ ZX6R + CBR600RR |
| HoggyF |
 HoggyF Nova Slayer
| G |
 G The Voice of Reason
| T0MMY |
| G |
| T0MMY |
 Posted: 00:10 - 04 Dec 2009 Post subject: |
Maybe it has a weak spark then? I do try to drop my body weight onto it but it's a little awkward to do whilst maintaining forward momentum It's got a very low seat height for an off roader which doesn't help. ____________________ ZX6R + CBR600RR |
| benjami |
 benjami Nearly there...
| G |
 Posted: 08:34 - 04 Dec 2009 Post subject: |
I've done the being towed thing a few times too (though for other people's bikes and it's always seemed to be me that ends up being the one dragged along ).
Are you running beside the bike and jumping on? I would often dump the clutch as I landed on the bike.
On larger off-roaders it's sometimes hard to get a decent push down jumping to astride the bike, so I'll sometimes go side-saddle instead.
Think the spark plug thing is probably worth checking anyway - first off, just all the connections. Spent ages on my KTM350 with it being hard to start and swapping plugs. Just before I sold it found the HT lead was a bit knackered at the end, so cut it and re-attached and it started really easily . |
| T0MMY |
 Posted: 09:15 - 04 Dec 2009 Post subject: |
I reattached the HT lead when I changed the coil so I think it's OK, I checked it for continuity with a multimeter too.
My biggest problem is that I don't know if there is anything actually wrong with it or not as nothing should really have changed since it started perfectly! I might try towing behind a car though, that seems like the easiest way  ____________________ ZX6R + CBR600RR |
| yen_powell |
| T0MMY |
 Posted: 13:46 - 04 Dec 2009 Post subject: |
Already tried that unfortunately  ____________________ ZX6R + CBR600RR |
| yen_powell |
| dougalthedog |
 dougalthedog L Plate Warrior
| Gazdaman |
 Gazdaman I did a trackday!!!
| T0MMY |
| Gazdaman |
| T0MMY |
 Posted: 22:25 - 05 Dec 2009 Post subject: |
I'll have to take some tomorrow.
Just checked Ebay and this one the same age as mine just sold for £823 though it's currently starting of course! I reckon £600 is what I'd aim for if I sell it as a non runner then.
Mine is yellow and black and it's got a full stainless system like the one in that link. As I say though, I'll get some pics tomorrow and maybe knock up a proper for sale thread for it with all the details. ____________________ ZX6R + CBR600RR |
| T0MMY |
 Posted: 17:00 - 06 Dec 2009 Post subject: |
Ok, spent a while today checking over the electrical system and I reckon there might be a problem with the charge coil or the wires leading from it to the CDI unit. I want to take the magneto assembly out to check the connections but I need 2 special tools to do so according to the manual, a tool to hold the rotor and a flywheel puller Anyone know of a way to do it without these tools? ____________________ ZX6R + CBR600RR |
| Gazdaman |
 Posted: 18:26 - 06 Dec 2009 Post subject: |
You can use a claw puller to pull the flywheel off. But it's really not worth it. A puller is a few pounds. Using anything else really risks damaging it.
Is there definitely a problem? Or does it just need someone to give it a decent kick/bump start?
I'd definitely rule out you being a pansy first
Gaz |
| T0MMY |
 Posted: 00:00 - 07 Dec 2009 Post subject: |
Well, I know bugger all about electrical stuff but I tested the resistance across the various coils as described in the Clymer manual. The charging/lighting coils are fine but the charge/pickup coil seemed to show no continuity. This might be due to me measuring it wrong, a genuinely knackered coil or a broken wire between the coil and the CDI unit but either way I'd like to find out. I'll put it back together anyway and try tow starting it behind a car first but if that doesn't work I'll buy the necessary tools.
The bikes in bits so I didn't take pics but I have some from my camera phone from over the summer. Makes me miss it a bit actually
I do still have the rear indicators, luggage rack and really gay extended mudguard thing by the way but took them off to save weight/prevent them getting broken. ____________________ ZX6R + CBR600RR |
| HoggyF |
 HoggyF Nova Slayer
| T0MMY |
 Posted: 23:11 - 07 Dec 2009 Post subject: |
Thanks, I'll give that a go It does seem a bit random that a coil would have given up like that without the bike being used. I did the valve shims not long before I stopped using it too and it was a bitch to start the first time after that but I did ride it since and it ran fine so I didn't mess up the timing or anything.
Those are the tyres it came on and they're great on road but hopeless in mud obviously but it was very dry round here over summer. It's got the knobblies on now which are great in mud but I think the road tyres are maybe better in gravel bizarrely. ____________________ ZX6R + CBR600RR |
| T0MMY |
 Posted: 12:25 - 13 Dec 2009 Post subject: |
RESULT!!!!!!!
I was checking over the wiring connectors again and as I moved one of the blocks a wire literally just fell out It's got one of the spade type connectors on the end and it had totally snapped off, should be an easy fix. I've bodged it for now and it started after 3 kicks Can't believe that was all it was after 3 months of sitting there, though in fairness I've hardly looked at it in all that time. I need to solder another spade thing onto the wire and she should be all sorted, the bodge won't last 2 minutes on a bumpy lane although I took it for a spin on the road.
The wiring block in question is over the engine beneath the tank and I wonder if I broke the wire when I took the cam cover off to do the shims?
Anyway, I'm probably still selling it so I'll put up a proper for sale thread shortly. PM me if you want to have a look/ride. ____________________ ZX6R + CBR600RR |
| T0MMY |
 Posted: 13:45 - 13 Dec 2009 Post subject: |
Sorry for the triple post but I took some pictures on my camera phone just now which I may as well post up too. It's a bit dirty at the moment but you get the idea, as you can see it looks like it just rolled out the showroom  ____________________ ZX6R + CBR600RR |
The last post was made 16 years, 291 days ago. Instead of replying here, would creating a new thread be more useful? |
