| chillpill |
 chillpill World Chat Champion
 Posted: 16:18 - 13 Dec 2009 Post subject: weird nsr starting problems |
right my nsr has decided to stop starting after a few weeks of not being used , theres a clicking noise every time i press the starter and i thought it was the starter motor relay but i was wrong , the clicking seems to be coming from the power valve servo ? after the starters pressed the servo will begin juddering slightly and continue this clicking noise . also the dash lights and headlights will dim when the starters pressed , i know they normally dim anyway but now they are alot dimmer and flicker slightly ?
i was hoping someone could shed some light on this situation ? i was thinking something in the power valve circuit has blown and somehow has caused that to be drawing current from the battery which means there inst enough for the starter to turn over ???? or maybe even reg/rec problems as i know a blown reg can caused some really weird electricalm problems . all help appreciated ,cheers
edit : i haven't mentioned battery because this one sonly about a month old , i don't have a multimeter right now as mines broken |
| crackpotterpi... |
 crackpotterpi... Renault 5 Driver
 Posted: 21:01 - 13 Dec 2009 Post subject: |
on the nsr when the igntion is put on the powervalve servo motor does actiivate,have you tried putting your headliights on and then trying to start as a general rule if they dull riight down then it is more than likely a battery or main connectiion fault.if you can get another battery or try jump starting it from a car battery that wiill eliiminate the battery  ____________________ 1990 jc20 nsr125-sold,2003 cg 125-sold currently no bike.........might get another 2 stroke me thinks much more fun |
| tvr321 |
 tvr321 Nitrous Nuisance
| chillpill |
| Carl_steveo |
 Carl_steveo World Chat Champion
| alains |
 alains World Chat Champion
The last post was made 16 years, 211 days ago. Instead of replying here, would creating a new thread be more useful? |
