dellorto vhst 28 carb
jasepugh1984
PostPosted: 16:20 - 12 Dec 2009    Post subject: dellorto vhst 28 carb Reply with quote
my bike sits at 4.000rpm for about 5 seconds after i rev it high when its warmed up.Im trying to find a good diagram of the DELLORTO VHST 28 carb thats on my 2007 aprilia rs125,I wanted to try and see if theres a way to let slightly more fuel in because ive been told that it might be fuel starvation thats causing the problem.i dont have much experience with motorcycles but keen to learn,thanks.
Aprilia Rs125 2007 11kw (SOLD) - Honda CBR600RR 2008 (Current Summer Toy) - Honda Cb600 2000 (Current Work Commuter)
oldbiker
PostPosted: 16:56 - 12 Dec 2009    Post subject: Reply with quote
This might be of some help, dellortos tend to be very much the same, with only minor differances from one version to another
https://www.ducatimeccanica.com/dellorto_guide/dellorto.html
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
B10Hazard
PostPosted: 21:22 - 12 Dec 2009    Post subject: Reply with quote
If you want to increase the amount of fuel going through the system you have to buy a bigger jet. There not expensive and pretty simples to put in.
https://www.pjme.co.uk/acatalog/RS125-34mm-CARB-JET-PHOTO.jpg
Thatvshould help.
You should go to about 165 or 170
Dan
No longer any socks
hmmmnz
PostPosted: 21:25 - 12 Dec 2009    Post subject: Reply with quote
sounds more likely that you have an air leak,
with the bike idling spray wd40 at the carb and rubbers both sides of it, if the revs change then you have a air leak if not you can rule that out,
you havn't changed to a stupid pod filter have you??
if so put the air box back on
the humans are dead
I kick arse for the lord
jasepugh1984
PostPosted: 13:52 - 13 Dec 2009    Post subject: Reply with quote
yeah i will try that and see what happens,no i havnt touched the airfilter at all.it seems to do it when ive taken it for a ride and its well warmed up.
chillpill
PostPosted: 16:29 - 13 Dec 2009    Post subject: Reply with quote
how do you warm it up ? if you just let it sit at idle for a while you might of fouled the plug ? idling at low engine temperatures creates a excess build up of 2 stroke oil around the plugs electrode causing a weaker spark , try a new plug they cost about 4 quid from your local bike shop
jasepugh1984
PostPosted: 17:49 - 13 Dec 2009    Post subject: Reply with quote
yeah i did put a new ngk spark plug in it last weekend but it still does it,the old one didnt look fouled.
oldbiker
PostPosted: 21:38 - 16 Dec 2009    Post subject: Re: dellorto vhst 28 carb Reply with quote
jasepugh1984 wrote:
my bike sits at 4.000rpm for about 5 seconds after i rev it high when its warmed up..
It still sounds like it could be a tad weak on the pilot jet / air screw. (assuming the throttle cable is not sticking, and you have some slack in the cable)
A small adjustment of the air screw should do the trick 1/4 turn or so.
(if it`s back firing or popping at near to full throttle it`s a main jet problem, go up a size or two)
Dellorto jets go up in 2`s and 3`s
for example--100,102,105,108,110,112.--250,252,255 etc.
what others have said about air leaks is possible.
when running correctly the plug should be the colour of a biscuit rich tea or gingernut,
The last post was made 16 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.76 - MySQL Queries: 16 - Page Size: 60.21 Kb
