hi i need expert help (oil)
 Topic moved: from The Geek Zone to The Workshop by G (20 Dec 2009 - 21:19)
punkrox
PostPosted: 15:39 - 20 Dec 2009    Post subject: hi i need expert help (oil) Reply with quote
hi i have a 50cc 2 stroke derbi senda bike but it is like splurting out oil from the exhaust does anyone know why this is.
please reply as i need to know rather than me take it to a shop and get ripped off when it could be a tiny problem thankyou.
Shaun
Likes 'em bent
PostPosted: 18:31 - 20 Dec 2009    Post subject: Reply with quote
Have you tried turning it off and back on again?
SoND
PostPosted: 19:35 - 20 Dec 2009    Post subject: Reply with quote
The workshop is this way.
panrider_uk
PostPosted: 21:07 - 20 Dec 2009    Post subject: Reply with quote
Wrong driver version?
Mark
jokmm
PostPosted: 14:34 - 21 Dec 2009    Post subject: Reply with quote
It's unburnt oil as it's a 2 stroke it burns oil aswell as fuel as you probably know and by the sounds of it it doesn't have anywhere for the excess unburnt oil to escape other than out the end of the exhaust.
If in doubt, give it a clout!
Current speed slave: Wuyang WY125
punkrox
PostPosted: 22:52 - 22 Dec 2009    Post subject: Reply with quote
hi i did turn it off then on but then it came out, still i wiped the like inside with a cloth and it still came splurting out,
also i checked the oil and theres none in there at all also whilst i checked this there was the water bit near it so i checked that and therer was no water in there either and we had only like not long ago filled it up sorry about the long post.
niceday
PostPosted: 22:27 - 23 Dec 2009    Post subject: Reply with quote
Hi, did you recently top up the water (with anifreeze added?). If so, it sounds possible that the head gasket (or o-ring) or bottom cylinder gasket may hav gone. It would be more likely the head o-ring. It's quite simple to replace, cheap too. Drain the radiator by removing the coolant pipe at where it joins the engine block. Disconnect the radiator hose on the cylinder head. Remove the spark plug. Remove the four nuts on the cylinder head (the other bolt head is a bleed screw, loosen this when refilling with antifreeze later). Note, loosen the nuts very gradually, ie loosen one slightly, then do the same to the one diagonally opposite then do the same with the other two. Then lift off the cylinder head. You will see a silicon o-ring and chances are a small bit will be missing or burnt. Put a new o-ring in. Put it back in reverse order, top up oil, top up antifreeze/water, start it up and enjoy! Good luck.
punkrox
PostPosted: 00:03 - 24 Dec 2009    Post subject: Reply with quote
owwwwwwwwwwwww lol that looks soo complicated how much would this cost at a motorbike garage to do would you say?
shadowbiker
PostPosted: 16:16 - 24 Dec 2009    Post subject: Reply with quote
when you say splurting out oil is it pissing out oil or just little bit showing on your number plate because thats normal in 2smokes
niceday
PostPosted: 17:28 - 24 Dec 2009    Post subject: Reply with quote
it's really quite simple, takes less than one hour. Only suspect this if you are losing water though.
punkrox
PostPosted: 22:32 - 24 Dec 2009    Post subject: Reply with quote
yes its more or less pissing out m8 lol
baldy
PostPosted: 15:42 - 25 Dec 2009    Post subject: Reply with quote
Why did you still run it if there was no oil or water?
I bet it's the wate rpump seals that have gone.
One day i will rule the world, just not today.
The last post was made 16 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 19 - Page Size: 71.59 Kb
