Suzuki GZ 125 not starting
lard44
PostPosted: 20:37 - 22 Dec 2009    Post subject: Suzuki GZ 125 not starting Reply with quote
Not even turning over...
Go through the startup procedure, key to 'ON', clutch in, neutral, stand up, kill switch fine - hit the switch and ZILCH. Freshly charged battery too. No whirring, no clicking, no lights flickering...
Only picked up the bike last night, saw it and sat on it when running...could I have knocked something in transit?
Ruddy annoying, bet I've overlooked something simple but any advice no matter how stupid gratefully received!
27cows
PostPosted: 21:06 - 22 Dec 2009    Post subject: Reply with quote
Blown fuse, wire disconnected from battery, faulty/damp ignition switch, corroded/wet/trapped wire somewhere. Bound to be something simple.
lard44
PostPosted: 21:22 - 22 Dec 2009    Post subject: Reply with quote
I'll have a butchers tomorrow when its light and hopefully defrosted a bit...cheers!
Alexio
PostPosted: 21:24 - 22 Dec 2009    Post subject: Reply with quote
There's bound to be more than one "kill switch" on the bike, check them all (side stand etc. my CG won't start sometimes when it thinks it's in gear but isn't, false neutral and all that).
Otherwise, a weird electronic fault, possibly one of the ones suggested above?
27cows
PostPosted: 21:32 - 22 Dec 2009    Post subject: Reply with quote
I find just attacking everything with WD40, leaving it for ten minutes, then having another try often works wonders Smile
lisalin This post is not being displayed because the poster is banned. Unhide this post / all posts.
temeluchus
PostPosted: 03:13 - 23 Dec 2009    Post subject: Reply with quote
check if you have a sidestand switch, make sure its connected if fitted, and given a good dose of vitamin WD. Also pay close attention to the igntion kill switch and the starter button.
Does it bump start?
The Artist
PostPosted: 12:59 - 23 Dec 2009    Post subject: Reply with quote
call the person/place you bought it from and ask them how to start it.
lard44
PostPosted: 14:32 - 23 Dec 2009    Post subject: Reply with quote
I already did that before I posted here, she was as baffled as I was. I believe her too.
Aaaaanyway, she fired up fine this morning. Cut out a couple of times when I tried to change gear or give her a few beans at first, left her to warm up and then all was sawweeeet.
I wish I knew what I'd done differently Confused Jiggled a couple of wires, sprayed WD40 on anything that looked like it might be sticking, bizarre...hopefully just a one-off - thanks for the tips guys!
27cows
PostPosted: 14:39 - 23 Dec 2009    Post subject: Reply with quote
Probably water got in somewhere. It's always as well to have a can of WD with you when you're out riding.
Alexio
PostPosted: 15:38 - 23 Dec 2009    Post subject: Reply with quote
My first bike refused to work in the rain to begin with, it would just cut out. After attacking it with WD40 all was well, so I hope what ever you've done makes a difference and that you don't get caught out in the middle of nowhere!
The last post was made 16 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.65 - MySQL Queries: 16 - Page Size: 69.77 Kb
