Chain lube
bgfs
PostPosted: 18:18 - 29 Dec 2009    Post subject: Chain lube Reply with quote
Whats the best chain lube to use. My bike a Suzuki GSF 650 K9SA came out of the factory with a white grease over the chain which seemed pretty good. What is it and how do I get it?
BGFS
Coxyzxr
PostPosted: 18:29 - 29 Dec 2009    Post subject: Re: Chain lube Reply with quote
Castrol chain wax. Only way to go.
I tried most stuff. Recommended to me and I've never looked back.
£8 halfords.
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
veze
PostPosted: 16:33 - 30 Dec 2009    Post subject: Reply with quote
gp - products super chain lube!. better than the non fling stuff i find because that stuff just collect muck and dirt.
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
arry
PostPosted: 16:48 - 30 Dec 2009    Post subject: Re: Chain lube Reply with quote
£8 halfords.
Agreed, it's what I use too - and has been very good
PostPosted: 18:02 - 30 Dec 2009    Post subject: Reply with quote
Old engine oil. It's free.
neatbik
PostPosted: 19:51 - 30 Dec 2009    Post subject: Reply with quote
Ive used Castrol chain wax and found it to be crap - all it did was attract grit to it which then ground its way into the chain.
Ive got a lubeman fitted now, i just use engine/gear oil in it, depending what i pick up first in the shed Thumbs Up
covedude This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Mark65
PostPosted: 20:15 - 30 Dec 2009    Post subject: Reply with quote
90w gear oil few quid for a litre.
Quote Me Happy
PostPosted: 08:13 - 31 Dec 2009    Post subject: Reply with quote
Old engine oil, chainsaw oil etc. No need for expensive, small cans of lube.
arry
PostPosted: 10:39 - 31 Dec 2009    Post subject: Reply with quote
Not found that, TBH, well no more than I had done with engine oil - if anything I've found that it's less splattery so I spend less time on chain maintenance as I don't have to degrease the whole surrounding area.
It's lasted me ages as well, so in terms of use it's not exactly what I'd call expensive Smile
oldbiker
PostPosted: 13:05 - 31 Dec 2009    Post subject: Reply with quote
I use a scottoiler and any oil that`s nocking around, never liked the chain greases and chain wax, too thick and attract to much grit which then gets ground into the chain
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
Chriss
PostPosted: 13:58 - 31 Dec 2009    Post subject: Reply with quote
I find Castrol Chain Wax is useless crap stuff, I've got two tins of the stuff you can have for free if you actually like it. Example from Stinkwheel linked for supporting evidance.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
geordiecbrblo...
PostPosted: 16:05 - 31 Dec 2009    Post subject: Re: Chain lube Reply with quote
Worst I've-just-got-a-new-bike-thread ever! Mr. Green
TUG
PostPosted: 16:41 - 31 Dec 2009    Post subject: Reply with quote
I've used all sorts, it generally doesnt matter because its free for me, and i do it every other day so i get no problems.
Dirt and grit is caused by lack of maintainance and do you know who are the worst people for it?
Yes, scott oiler owners, their chains are black, and seize up, its horrid.
Haz ER-5, innit!
Noxious89123
PostPosted: 01:08 - 01 Jan 2010    Post subject: Reply with quote
Not a chance, my chain has loads of miles on it and still looks nearly new Wink
Syx
PostPosted: 11:44 - 04 Jan 2010    Post subject: Reply with quote
The usage of Castrol picked up some grit and ended up wearing a hole in my crankshaft oil seal - annoying.
However I still use the stuff, as it's easier to regularly clean the crap off the chain than degrease the entire left hand side!
evoboy
PostPosted: 12:04 - 04 Jan 2010    Post subject: Reply with quote
If im in a rush, ill use chain lube.
If im cleaning the bike ill use engine oil and a toothbrush.
APT Motorcycles
johnsmith222
PostPosted: 01:48 - 05 Jan 2010    Post subject: Reply with quote
I disagree.
The only people who own a scottoiler and have a black and siezed up chain are the ones who either don't use it or haven't set it up correctly.
A scottoiler doesn't do anything if you don't actually use it.
arry
PostPosted: 12:44 - 05 Jan 2010    Post subject: Reply with quote
well I've cleaned the bike over the weekend, got the chain absolutely sparkly and left it in the garage with just Castrol chain lube on it. If I get back from 4 days away and it's gone rusty etc then I'll agree with you all and bin the rest of the can Very Happy
By the way - has anyone else used Muc Off chain cleaner? I swear it's just WD40 in a fancy can and hideously overpriced?! It smells the same, looks the same, and has about the same effect?!
TUG
PostPosted: 15:00 - 05 Jan 2010    Post subject: Reply with quote
david_m213 wrote:
I disagree.
A correctly set up scottoiler used in conditions other than clean dry roads pick up the same dirt as normal chain lube.
You have to clean your chain like you would your bike to keep dirt at bay. This also increases chain life.
I think you may have missed my point, most scottoiler users just forget about maintaining their chain as the scottoiler is "doing" the maintainance. It takes me about 5 mins to propperly clean their chain for them and clean the rest of the lube off the bike even with brake cleaner.
Haz ER-5, innit!
Noxious89123
PostPosted: 20:20 - 05 Jan 2010    Post subject: Reply with quote
XlonewolfX wrote:
david_m213 wrote:
I disagree.
Tarring us all with the same brush etc. I clean my chain every time I wash my bike. Which is once a week when I'm actually riding it.
And a scottoiler will result in your chain picking up alot less crap, as the oil isn't sticky like spray on lube.
TUG
PostPosted: 21:05 - 05 Jan 2010    Post subject: Reply with quote
I'm actually face palming, i didnt say "ALL SCOTTOILER OWNERS NEVER CLEAN THEIR CHAINS" did i? In my experience i've had to clean off alot more grit and dirt from bike swing arms, huggers, sprockets, chains, and it was once so bad i actually took off the sprocket cover on the front and scraped all the crap out for him.
I repeat again, I didn't say "ALL SCOTTOILER OWNERS NEVER CLEAN THEIR CHAINS" and if you thought i was implying that then i suggest you dont take what i say so literally.
Haz ER-5, innit!
evoboy
PostPosted: 21:12 - 05 Jan 2010    Post subject: Reply with quote
Lmao at the fanboys.....
Scottoilers are not God.....they are just good Laughing
APT Motorcycles
yen_powell
PostPosted: 09:25 - 06 Jan 2010    Post subject: Reply with quote
I use any old oil lying about. Not bike oil anymore, that got too expensive, currently using years old bottle of Halfords car oil. I get the back wheel in the air (no centrestand) and using a squeezy bottle I turn the back wheel and drop oil on the inside run O rings. Sometimes I start the engine up and run the bike in 1st gear to help spread the oil through the chain links using centrifugal force.
I re-oil every few weeks in dry weather and after riding in heavy rain. Basically I keep the O rings looking moist.
I use DID X-ring chains, my current chain has done about 35,000 miles and is still in fine fettle (the front sprocket needs replacing though), I think my bike is particularly kind to chains, as is the mainly motorway mileage I do.
I used scottoilers from the mid 80s till 3 years ago. Still got my last oiler, but couldn't be bothered to fit it to my current bike, may get round to it eventually.
XT1200Z and a DR350 in bits
The last post was made 15 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.28 - MySQL Queries: 16 - Page Size: 135.86 Kb
