Innacurate Speedo Reading
nitro159
PostPosted: 13:13 - 27 Dec 2009    Post subject: Innacurate Speedo Reading Reply with quote
Hi, I've got a basic chinese copy of a CG 125 and I recently worked out that my speedo is out by a good 10 Miles an Hour at speeds of 30 MPH and upwards, I checked this when I became frustrated with cars seemingly speeding away from me at all times, I put a GPS unit on my bike and rode around for about an hour at varying speeds and from just under 30MPH on the speedo, the GPS was reading 20 (give or take, seemed to fluctuate at that speed), When my speedo read 40, the GPS said 30 on the dot, and I was in harmony with the traffic! It did the same for 10MPH increments upwards to around 60 (scary) where the GPS read 60MPH but the speedo read just over 70.
Note the speedo is driven off of the front wheel, mechanical not a digital one.
Is there any way to adjust it myself without sending it off to a manufacturer or should I consider a new speedo? Any ideas or is this regular?
Also just before the pipe on the exhaust meets the bit where the exhaust widens toward the back, just underneath the back brake pedal, the exhaust appears to widen and appears to have had a piece of pipe welded between the downpipe and the part where it widens, the section is considerably noticeably wider in diameter and approximately 6 inches long.
Does anyone have any idea what this is because I haven't seen it on any other 125's.
Thank you in advance
Wayne
PostPosted: 13:22 - 27 Dec 2009    Post subject: Reply with quote
Probably not much you can do with the speedo to adjust it. Probably the easiest way to do it would be to put an overlay stickers on it with the real speeds.
oldbiker
PostPosted: 13:33 - 27 Dec 2009    Post subject: Reply with quote
All speedos are wrong and they are optimistic thats just the way they`r designed
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
PostPosted: 13:38 - 27 Dec 2009    Post subject: Reply with quote
Not by 30%! If the error is repeatable then Keith's solution is the simplest. Fit an overlat sticker on the face of the clocks.
The wider piece of exhaust - dunno, could it be a catalytic converter, or another silencer in the pipe?
stirlinggaz
PostPosted: 15:26 - 27 Dec 2009    Post subject: Reply with quote
hi,
ive found that most of the speedos on the chinky bikes i have had, have been inaccurate & a couple by as much as 20% +!
do what i do & fit a cheap bicycle computer. (the hard wired type)
very accurate, cheap & easy to fit.
(though you may have to improvise a bit, when fitting the magnets)
depending on the design of the magnets/fittings (make sure you can have a good look at it 1st before you buy as some of the magnets can be a pain to "stick" to the wheels- i have resorted to araldite before) & what type of wheels you have, it should be prettty much unoticeable.
cheers,
GAZ
PostPosted: 16:17 - 27 Dec 2009    Post subject: Reply with quote
A cycle speedo is not the cheapest option but certainly can be the most accurate.
I use a (discreet) £10 cycle speedo purchased from halfords and then used my (bulkier) GPS unit to calibrate it.
Had to purchase a neodymium magnet for £2 to get it to work correctly as the field strength of the standard magnet was not powerful enough to bridge the gap between the rim and the forks.
Even the cheap cycle units have the advantage of a trip meter and a clock.
jokmm
PostPosted: 20:04 - 27 Dec 2009    Post subject: Reply with quote
Hey there, you've got a similar bike to me then lol. I had this problem, but mine was under warranty so I got a new one put on. If it's the same as mine, it's basically a cable that is attached to the wheel and into the speedometer, and if this isn't rotating properly you'll get an incorrect reading. You could try disconnecting the cable and lubricating it, see if that helps. If not, replace the speedo drive.
Btw, what is your bike called?
If in doubt, give it a clout!
Current speed slave: Wuyang WY125
nitro159
PostPosted: 23:28 - 29 Dec 2009    Post subject: Reply with quote
Thanks for the quick replies guys! After a few more tests it can vary and i dont really want to rely on it for much longer, Im going to be getting a cycle computer and seeing what I can do with it, any ideas on the exhaust part?
@jokmm: Its a "Senke 125 - 4" Not sure what that'd mean compared to other chinese 125's.
Thanks again for all your help guys, very much appreciated!
Wayne
MaybeGuy
PostPosted: 23:33 - 29 Dec 2009    Post subject: Reply with quote
my chinese bike could do 100mph
Martay
PostPosted: 10:11 - 30 Dec 2009    Post subject: Reply with quote
100mph!? Is that it?!
My chinese 125 had an interesting feature. The speedo would show approx. 20mph while standing still, and the needle would hit the end stop under 0mph at anything above real 30mph. At a guess 155mph, but cant say for sure as the numbers stopped :p
Anyways, as has been said, an overlay on the clock. Or just put a small sticky dot or piece of label at genuine 30 + 70. They're the only speeds you really need to know. Dont spend too much on a cycle computer, i tried it, and killed it after 200ish miles.
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
stirlinggaz
PostPosted: 14:37 - 30 Dec 2009    Post subject: Reply with quote
half decent (wired) bicycle speedos cost around a fiver
PostPosted: 14:54 - 30 Dec 2009    Post subject: Reply with quote
Vincent wrote:
I thought GPS speed indicators weren't accurate either Confused Or are they just ok on flat straight roads Question
Depends on the actual one. There are ones designed for performance testing which are very accurate, but also not cheap. They will take the speed not from the change in position given by the GPS, but by using the doppler effect on the actual GPS signal.
Normal GPS will be fairly accurate though for keeping a constant speed in a fairly straight line without too many buildings, etc.
The last post was made 16 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.38 - MySQL Queries: 16 - Page Size: 88.59 Kb
